Gen5DIY
Old 07-07-2012, 08:10 AM   #3991
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
I want to see that Fed Ex truck!!
Ah, your 1/2 ton will be fine for now. Just make sure the brake controller for the trailer brakes is adjusted properly and you are good to go.
You know a dually is built specifically for crazy towing but the 1/2 ton set will save you that $65K for now. If you get the itch just have J FedEx his truck down to you to 'borrow' for a while.
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 07-07-2012, 08:12 AM   #3992
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Originally Posted by Gotthat02fire View Post
Someone say Blower Truck??? I know someone!!! That's my enclosed in the back round just for you!
Nice...
Beautiful Truck as well... I was looking for a beater when I ended up with a 2012... Price point for what you get would have been hard to beat... I looked at some used 3/4 ton diesels, just didn't want someone elses headaches... i know there are really good used ones out there.. but often you don't know until it's too late...
I was actually making that reference to Doug stating he needed to talk to mike... I have no need of a blower, unless I want some compound boost... That would be sic....
I'll be fine with my truck, or better than fine as I really like it... It's roomy, comfortable, pretty good gas mileage, until I hook this trailer on it with the car on the trailer... but it'll do what I need for now...
With the good guidance I've recieved, and the parts I'm adding, it ought to tow quite well...
Thanks Again B.
Old 07-07-2012, 08:20 AM   #3993
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Nice...
Thanks Again B.
Hey R,
I am sure it is somewhere else in your thread so forgive me if this has already been covered, but put the biggest tranny cooler you can fit on it. That is such a common point of failure on a 1/2 ton.
Sounds like you have it all covered. Cool stuff.
Bet you can't wait to get back to dry land.
-B
Old 07-07-2012, 08:32 AM   #3994
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Hey R,
-B
Well, I'll describe what I know of the truck, and tell me if more is needed...
It has the heavy tow package... With this there is the HD trans cooler, and a HD oil cooler...
The truck has the 3.92 rear gears and there is a tow haul button on the dash... Based on what little I know or have been told about that, It locks out the upper overdrive, and increases the fluid pressures, and changes the shift points...
With brakes on all four wheels of the trailer, and a properly adjusted trailer brake controller, which I'll check with the guys at the trailer place to ensure how to properly set it... I'll have every patch of contact with brakes... and the 5200 lb axles have bigger brakes than the 3200 lb axles...
Ratings are what they are, and should be taken with a grain of salt, but Dodge list this one with 11200 lbs tow capacity, not including the weight of the truck... I take that with a big grain of salt... but it should handle 7500 or so with the preparations I'm making. I'll haul it to Fredericksburg for the Pedders install, and back... and if it still doesn't feel good I'll use my father in laws truck for the Fest... I'll have all my add on items on the truck by then...
Old 07-07-2012, 08:37 AM   #3995
speedster
SST...
speedster's Avatar
Sounds like it is setup to the level you need. Now just add Brandi and your trailer and you should be good to go !! Nice...
Old 07-07-2012, 08:51 AM   #3996
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Thanks B,
I forgot to add, the drivers info center has a screen for monitoring the trans temps...
Do you know off hand what the ranges are and what the critical numbers are for impending trans failure... I have no idea with Autos...
Old 07-07-2012, 10:53 AM   #3997
speedster
SST...
speedster's Avatar
Thanks B,
I have used these two charts forever...
http://www.txchange.com/heatchrt.htm
http://www.digi-panel.com/trannyoil.htm
Old 07-07-2012, 11:06 AM   #3998
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Thanks B.
That's perfect... I printed off both of them and will carry them with me...
Old 07-07-2012, 11:26 AM   #3999
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Size:  3.5 KBName:  smiley-talk002.gif
Size:  1.0 KBName:  bbq.gif
Size:  51.3 KBName:  1338.gif
Size:  7.2 KBName:  boardoo-eating-smiley-2187.gif
Size:  4.4 KBName:  talk.gif
Size:  1.0 KBName:  talk.gif
Size:  1.6 KB <<<<<<<<<<<<-------- Hey Rob, is this how you feel?
Old 07-07-2012, 11:49 AM   #4000
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Dude, You and those emoticons...
Lol.. I wish I was in a boat headed home...
Just found out that I may have to be on a rig in Pascagoula Miss on the 8th of August... I get home on the 6th or 7th... That means I would have to drop the car off at the shop, or in the garage... store the trailer, get stuff around the house taken car of and drive like hell to get there... I'll have to be ready to start work at 6:00 on the 6th...
I sent a note to my supervisor asking if they accounted for this when they asked me to trade rigs... I did tell them about the Fest and that I wasn't going to miss it.. Hopefully they allow me my four weeks off and then I'll be on a three on three off schedule...
Time will tell... and PQ... is the party post for being the 4000th poster in this thread... If so, cool...we'll tip a cold one to that in three weeks..
Old 07-07-2012, 11:53 AM   #4001
PQ
Booooosted.
PQ's Avatar
Dude, that totally sucks. Ugh............... That might put a darkish cloud over the fest for you?
4000th poster.
I didn't realize.
Old 07-07-2012, 12:00 PM   #4002
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
4000th poster.
I didn't realize.
Wait a min... I say just hold on a minute here...
There aint nothing gonna put a darkish cloud over the Fest for me...
If I had to be on the rig Monday after the Fest, I'ld arrange for someone to drive my truck home and get the car put away... and fly down to Pascogoula....
Remember last year... car broke half way there... didn't slow me down.. well it did slow me down a bit but only physically...
It's the Fest... I'll be there, happy as a clam, regardless of the situation...
<< none of this... Just >>> and maybe some of ...
Old 07-07-2012, 12:05 PM   #4003
PQ
Booooosted.
PQ's Avatar
Fair enough.
I'm that guy who get's pissed on Saturday night that he has to go to work on Monday morning.
Glad you caught that in bold, I was going to jump all over it. LOL
Old 07-07-2012, 12:10 PM   #4004
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I'll tell you what... you feel froggy, go ahead and jump... but know this...
I'm gonna jack up the landing....
225.8, camaro of the week, drive shaft specialists of tx, dss, erl, henderson performance tech, i am second, rockland standard gear, slayer billet quad carbon, texas mile, the circle, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
