HeadlightArmor
Old 07-13-2012, 08:09 PM   #4103
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I'll post down here in the little box since it appears I'll have to wait a month for whatever Pq posted to download
Old 07-13-2012, 08:19 PM   #4104
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
You can't see that pic?
Old 07-13-2012, 08:20 PM   #4105
Mr Twisty
Mr Twisty's Avatar
Just dont over think it...as I tell my trainees all the time...
I'll take a stab at it... the answer to #1 is..... Potato's ?
But seriously, my first thought would be to create tension on one side of the drill pipe.
-- Benjamin Franklin
Mr Twisty is online now   Reply With Quote
Old 07-13-2012, 08:29 PM   #4106
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I can now... It took about ten minutes to download...
But the pipe in this case is over 10,000 feet long, mostly straight down... or it's more than 2000 PQ's... laid end to end... or about the distance his car can cover in thirteen minutes...
Stress on one side of the pipe could cause it to bend, but how do you rotate the pipe, turning the bit, and maintain the tension on one side of the pipe...
Old 07-13-2012, 08:34 PM   #4107
Mr Twisty
Mr Twisty's Avatar
If you can't bend the pipe, then you'll have to change the angle of the rig to point it like a gun barrel.
How deep is it to the sea floor?
How much does 10,000' of drill pipe weigh?
Common sense says once you have thousands of pounds of pipe hanging, no matter the direction, it's gonna say, "Screw this, I'm heading toward the center of gravity!" (straight down)
Old 07-13-2012, 08:42 PM   #4108
PQ
Booooosted.
PQ's Avatar
Not much more either. hahaha
I was always amazed at how they could do that without breaking and bending many pipes.
Old 07-13-2012, 08:54 PM   #4109
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
The pipe is quite flexible... and it's very heavy... A joint of pipe can weight from 20to over 150 lbs a foot... depending on the type of pipe, drill pipe, drill collars, or hevi-weight... When we get to the bottom of this hole with the various styles and sizes of pipe, we are roughly running a 420,000 lb hook weight... We have rigs with a 2.5 million lb hook weight rating...
On this particular well, it's about 400 feet to the ocean floor... This is quite shallow water for us... This well we are on the total depth is 16,200 + feet, while the TVD, or total vertical depth is only around 12,000. This indicates there is some directional drilling going on... but again, the pipe is spinning, the rig is not tilted and yes the pipe wants to head to the center of gravity... so.... ???
I've actually been on rigs in shallow gas fields where the TVD was less then 5000' but we would run over 15,000 feet of pipe in the hole... Horizontal drilling...
Old 07-13-2012, 09:10 PM   #4110
Mr Twisty
Mr Twisty's Avatar
Ok... here's what you do... you mount a big ass't gyroscope above the drill head...
Ima hafta think on this... how DO you make a pipe bow a certain direction... you can make a bow bend by adding tension on one side with a bow string... but you don't have enough space to work with.
DAM YOU! I was gonna go to bed early tonight, too LOL
Old 07-13-2012, 09:15 PM   #4111
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
I'm with you. Drilling is one those things I've never been able to wrap my brain around. Especially horizontal!!
Redemption is offline   Reply With Quote
Old 07-13-2012, 09:15 PM   #4112
Redemption
Just Because!
Redemption's Avatar
Really cool btw, thanks for Ed-u-ma-kating us.
Old 07-13-2012, 09:22 PM   #4113
Mr Twisty
Mr Twisty's Avatar
My son worked on a crew installing underground fiber-optic cable. They had a drilling machine that could follow a prescribed route underground, and come back up at the exact point they needed..... crazy
Old 07-13-2012, 09:31 PM   #4114
Mr Twisty
Mr Twisty's Avatar
When you blow mud in the hole, does it come out the center of the drill head, or can the drill head be lubed on one side more than the other? If you could pin-point the mud, you could conceivably make the drill head cut the higher lubed area faster, making it turn eventually... maybe... dammit
BTW, I see mud wagons everywhere in Oklahoma... where do you get your mud? Can you recycle it?
Old 07-13-2012, 09:46 PM   #4115
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
My blind guess is that there's a specialized drill "bit" that uses the pressure from the drilling slurry to hydraulically alter the angle of deflection of the drill "bit." Maybe use some kind of flexible collars that are required to be put between sections of pipe, but I'm not sure how you'd control where those collars allow flex and where hey don't allow flex.
But beyond that, I haven't got the foggiest
I was originally going to say maybe there's a GPS controlled drill bit, but I've always wondered how accurate GPS would be 10,000 feet below the sea floor when I can't get my darn phone to pick up a signal just from inside my car
My VIN = 2G1FK1EJ9A9105017
Old 07-13-2012, 10:11 PM   #4116
Mr Twisty
Mr Twisty's Avatar
That's a good point.... how do they even know they're drilling is offset?
.... sounds like a conspiracy theory to me
225.8, camaro of the week, drive shaft specialists of tx, dss, erl, henderson performance tech, i am second, rockland standard gear, slayer billet quad carbon, texas mile, the circle, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
