Emblempros
Old 08-18-2012, 10:39 PM   #4607
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Robert:
I may have some 3.55 gears for you to try out.
Old 08-18-2012, 10:53 PM   #4608
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Robert:
You going bigger or smaller...
Old 08-18-2012, 11:00 PM   #4609
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
Here you go bro. A new sig for the Texas Mile.
Old 08-18-2012, 11:29 PM   #4610
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Nope I am in Texas.
Old 08-19-2012, 10:46 AM   #4611
Darth_Emma
Darth_Emma's Avatar
Probably going to 3.25 gears.
Old 08-19-2012, 06:06 PM   #4612
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Good choice. We used that ratio in the SST.
Old 08-19-2012, 06:21 PM   #4613
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Rob,
Are you stateside in this time frame: September 11th - 18th, 2012?
Old 08-19-2012, 08:46 PM   #4614
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Rob,
I'm stateside right now, just in Mississippi on a rig, shipyard type stuff...
I leave the 18th to come back to work next hitch
Old 08-19-2012, 08:58 PM   #4615
JusticePete
VIR Specialist
excuse me while I go pout.
Old 08-19-2012, 09:29 PM   #4616
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
What's the deal.... Pm me...
Old 08-27-2012, 08:50 PM   #4617
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
So, hurricane Issac got me sent home early... On the clock though, so no complaints...
Brandi is in the hospital, and we are starting the exploratory surgery to discover the problem... It seems I might be a victim of Aeromotive... And their fuel pumps...
My last day prior to leaving for work, I went for a short ride and stopped in at a place for a grand total of 40 or so seconds, walked back out and the car had died... Tried to start it, fuel pump is running but no... ZERO fuel pressure... And this is with a grand total of less then seven hours run time...
We are going to drop the rear cradle, pull the fuel tank and see what we see... When this occurred three weeks ago, Corey came to where Brandi quit, and then went to my house to help install the winch, and we used that to load her and get her to the shop...
While the tank and rear section are out, we are going to do a battery relocation and then cut out the wheel well and cover that with sheet metal... The nitrous bottles will sit on top and the parachute frame will be built and installed under there... Well install the parachute frame and bracing, and install an external battery shut off switch.
This is in preparation for my upcoming mile runs...
We also received a box of .120 wall thickness tubing bends and some straight pieces, so the handmade exhaust manifolds will be built over the next few weeks... Then we'll hook up the boost controller and see what we see...
Ought to be amazing...
Old 08-27-2012, 09:44 PM   #4618
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
I'll share this and take it for what it is worth but when we were searching for a fuel solution for my car, I suggested Aeromotive to Ron.....he thought about it for about .000003 seconds and said NO WAY an Aeromotive pump is going in this car. They have had horrible experience with them in the past and one twin turbo corvette owner ended up on the side of the road THREE times.
I hope that isn't in the cards for many of the other Aeromotive users on here as I know that pump has become quite popular. Good luck getting it back on the road.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 08-27-2012, 10:06 PM   #4619
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Thanks bro, Corey has a plan, and it doesn't include any other Aeromotive pump... Like was mentioned... The pump is running, but we think the impeller isn't... We'll see what Aeromotive has to say and go on... And Corey is in agreement with Ron... We were hoping their new pump for the Camaro was an improvement... Guess not...
Old 08-27-2012, 10:20 PM   #4620
jrpxxii
jrpxxii's Avatar
I can say that I am running 2 magnafuel pumps which is overkill but is also a great backup in case 1 pump ever fails. They are extremely quiet compared to aeromotives as well. I have tried several setups with dual and triple pumps and these magnafuels are the way to go. Hope you figure it out and it didnt hurt anything too bad.
225.8, camaro of the week, drive shaft specialists of tx, dss, erl, henderson performance tech, i am second, rockland standard gear, slayer billet quad carbon, texas mile, the circle, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
