BORLA
Old 08-27-2012, 10:28 PM   #4621
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Well at least the Hurricaine is good for something... a little extra prep for the mile
Good stuff..
Old 08-27-2012, 10:47 PM   #4622
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
So, hurricane Issac got me sent home early... On the clock though, so no complaints...
Brandi is in the hospital, and we are starting the exploratory surgery to discover the problem... It seems I might be a victim of Aeromotive... And their fuel pumps...
My last day prior to leaving for work, I went for a short ride and stopped in at a place for a grand total of 40 or so seconds, walked back out and the car had died... Tried to start it, fuel pump is running but no... ZERO fuel pressure... And this is with a grand total of less then seven hours run time...
We are going to drop the rear cradle, pull the fuel tank and see what we see... When this occurred three weeks ago, Corey came to where Brandi quit, and then went to my house to help install the winch, and we used that to load her and get her to the shop...
While the tank and rear section are out, we are going to do a battery relocation and then cut out the wheel well and cover that with sheet metal... The nitrous bottles will sit on top and the parachute frame will be built and installed under there... Well install the parachute frame and bracing, and install an external battery shut off switch.
This is in preparation for my upcoming mile runs...
We also received a box of .120 wall thickness tubing bends and some straight pieces, so the handmade exhaust manifolds will be built over the next few weeks... Then we'll hook up the boost controller and see what we see...
Ought to be amazing...
The real good news is the pump had the courtesy to fail while Brandi was at idle and not under boost
Good stuff..
When is the mile?
Old 08-27-2012, 11:42 PM   #4623
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Originally Posted by jrpxxii View Post
I can say that I am running 2 magnafuel pumps which is overkill but is also a great backup in case 1 pump ever fails. They are extremely quiet compared to aeromotives as well. I have tried several setups with dual and triple pumps and these magnafuels are the way to go. Hope you figure it out and it didnt hurt anything too bad.
We are going to configure dual 400 l/hr pumps with a Hobbs switch... Run pump all the time and the second one when boost hits 1 psi...
Good stuff..
yup, and we need the time... I'm going to pick up the manifold flanges from Glen in the am and then start tearing the exhaust out to start on the jigs... I'll also map out the cuts and bracing for the parachute frame...
When is the mile?
October 26-28...And amen on the being at idle... Nothing was hurt as far as the motor was concerned... As far as we can tell...
Old 08-29-2012, 07:35 PM   #4624
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
So, the rear cradle, the fuel tank and exhaust manifolds are out of the car... The exhaust manifolds include the turbo package... We'll start building the jigs and prepare for the custom built exhaust manifolds.
I'm going to order the parachute frame, mount, and chute itself and we have mapped out the cuts for mounting it....
Thanks Russ for the new Texas Mile Signature
Old 08-29-2012, 11:23 PM   #4625
JusticePete
I leave for SEMA the 27th...
Old 08-29-2012, 11:55 PM   #4626
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
How long is your driveway.... Might need to make a few speed runs prior to going to the mile...
Actually, We will be down there probably thursday evening friday saturday and sunday....
Old 08-30-2012, 08:38 AM   #4627
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
With my GoPro's, I'm sure
My VIN = 2G1FK1EJ9A9105017
Old 08-30-2012, 09:43 AM   #4628
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Mount 'em up....
Old 09-01-2012, 02:38 AM   #4629
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
So, I spoke with Bob at Ed Quay race cars and I am on the hunt for a volunteer to take their car there for them to use as a template to build me a spoiler before the Texas Mile Run.
Corey and I are considering a Weldon fuel pump system with a surge tank... The Lingenfelter dual fuel pump system in the tank and a separate cell for the Weldon... The Lingenfelters will supply the cell and the Weldon will supply the fuel rails from the cell....this will provide plenty of fuel for most any situation.
We are still waiting to hear from Aeromotive about what happened with my less than eight hour run time rule pump....
Tuesday we'll start building the jig for the exhaust manifolds... Ought to be fun...
Old 09-01-2012, 09:55 AM   #4630
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
That is what I was going to do with my car too but I didn't want a cell in the trunk. I guess I am still trying to pretend it's a street car.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 09-01-2012, 10:13 AM   #4631
Mr Twisty
Mr Twisty's Avatar
Ed Quay race cars in Pottstown, Pa?
Just a stones throw from Philly/NYC/Allentown/Harrisburg?
-- Benjamin Franklin
Old 09-01-2012, 11:48 AM   #4632
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
We looked at the twin walbro's and there is a lot of flow capacity drop off at the higher ranges of their capabilities... I'm sure they would be fine for the quarter but we aren't sure with mile runs and open road racing...And that beast you drive is a race car... Street legal, but still a race car, just like mine
search me, I'm Guessing that's where it is... I have a thread started in the PA regional area and there are a couple of folks that are looking into it...
Old 09-01-2012, 03:04 PM   #4633
JusticePete
Old 09-03-2012, 07:49 PM   #4634
CamaroSkooter
Whenever it finishes uploading and youtube finishes processing..... Enjoy the video
225.8, camaro of the week, drive shaft specialists of tx, dss, erl, henderson performance tech, i am second, rockland standard gear, slayer billet quad carbon, texas mile, the circle, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
