Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress.
Old 11-11-2011, 04:40 PM   #1801
Dangeruss
Mmmmm...nitrous.
Dangeruss's Avatar
Drives: Camaro LSX
lol, I figure about 250 lbs of metal...(and it's probably not that much...) but... it ought to hold up to some serious launches... I'll be thrilled to be able to do the first burnout with both tires since the build...
I've got some focused work areas where I need to try to get rid of some surface scratches... hopefully tomorrow I'll manage to get those out...
Nice!
Old 11-11-2011, 09:35 PM   #1802
andredmg
Big Nasty
andredmg's Avatar
Drives: Chevys lots of em
Very Nice!!!
andredmg is offline   Reply With Quote
Old 11-11-2011, 09:52 PM   #1803
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
Looks great, but those bushing appear to be the wrong color.
Old 11-13-2011, 07:18 PM   #1804
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: LS-3 429 TT with other odds-n-ends
Phone call coming you're way Pete, as I need to at least get the diff bushings for the front two journals... I think I read where you recommend the Delrin for the back one and yours for the two fronts... Bearing in mind, noise isn't an issue for me, just what works the best...
Brandi is headed to the hospital in the am... When I get her back she have a better built trans, the new DSS rear axles, drive shaft, and the turbo issue will be fixed...
I'll try to find a good evening to take her to the track and wring her out a lil bit...After the diff gears are broken in...
She'll still only be on drag radials...
Old 11-13-2011, 09:06 PM   #1805
Merc
COTW 12/5/11
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM
Merc is online now   Reply With Quote
Old 11-13-2011, 09:32 PM   #1806
andredmg
Big Nasty
andredmg's Avatar
Video
Old 11-13-2011, 09:36 PM   #1807
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Originally Posted by andredmg View Post
Video
When we go to the track in a few weeks, depending on my work schedule, I'll get some video... If my doctor releases me next week, then I'll be hustling to get back to work after over 4 months off... but, videos will be forthcoming, and pics of the various install work parts....
Old 11-13-2011, 10:45 PM   #1808
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Drives: #22 Tom Henry Racing 2010 2SS/RS
the infamous drag radials....
Old 11-14-2011, 01:42 PM   #1809
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
yeah, the same ones that have never even had a burnout on them...
Old 11-14-2011, 03:44 PM   #1810
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
What??? Randy's didn't count???
Old 11-14-2011, 04:45 PM   #1811
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Smile
You mean when he tried to roll them over...
Old 11-14-2011, 11:04 PM   #1812
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Old 11-14-2011, 11:13 PM   #1813
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I did get some good news today... my new input shaft is at the shop, as is the new output shaft made from 9310 material with the output shaft bearing.... So, the transmission should be good to go after we get those and a few other goodies in it... The DSS stuff should be shipped by the end of this week, or early next week... So, it's coming together...
Old 11-14-2011, 11:28 PM   #1814
Merc
COTW 12/5/11
Merc's Avatar
Who supplied the shafts and how many $$$?
Old 11-14-2011, 11:53 PM   #1815
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
GM for the input shaft, we will micro polish it prior to installation... Got the output shaft aftermarket... Pm sent....
Old 11-14-2011, 11:59 PM   #1816
Merc
COTW 12/5/11
Merc's Avatar
Old 11-15-2011, 03:45 PM   #1817
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
On a side note, I got a text from Corey and he has ordered my boost controller, an AMS 1000 and a shift light...
Glad to hear that you are installing the AMS controller. It is a MUST with a manual transmission. It will take some time to dial in, but you will be a full .5 sec faster or more compared to if you didn't have it. Nice.
Old 11-15-2011, 10:56 PM   #1818
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
between the nitrous and the boost increase, I need something to manage everything...other than shifting gears and steering the car....
Old 11-15-2011, 10:59 PM   #1819
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
I missed this.. can you educate me?
Old 11-15-2011, 11:10 PM   #1820
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
This is a boost controller, arguably the best available today for controlling boost through a myriad of settings... It can be set for time, rpm, gear etc... It can be set to increase or decrease the boost in any gear and at any rpm... for example... If you running a crinkle wall slick, you can launch really hard and when the car is going through the shake zone, the boost can be retarded and help prevent wheel hop, then as the tires settle down, the boost comes back on to full pressure... and the nice thing is the available variety of settings... Like Bruce said, it will take some time to dial it in, but once it's there, it only takes minor tweaks for track conditions... I posted up about it in another thread and Ted came on and said it is the best on the market... I tend to agree... It's expensive and requires lots of wiring, but thats ok... if it saves a motor and driveline at the same time it's lowering times tremendously, then I'm all for it...
There is no need for changing springs or manually dialing the boost... you set it, and it does the rest... we are also installing a shift light and we'll short shift 1st gear a little and then progressively get a little higher in each successive gear... first gear spins up so dang fast it's unreal.....
The Nitrous will be used to make up the difference from what we can get on the boost with the current fuel system capacity... With the fuel cell under the hood, and 117 octane race fuel to mix with the nitrous, we should be able to easily get up into the 1300-1400 hp range I'm hoping for... on the ground... I could live with 1200 but... for the mile, I want all I can get...
Old 11-16-2011, 06:22 AM   #1821
garcmol
garcmol's Avatar
I'm guessing this boost controller will account for the 1/3 of a second shift between gears? That's the only thing I would worry about, and I'm pretty sure you have already thought of that good sir! All that spooled up boost and race fuel and nitrous plus 1200++ ponies then disengaging/engaging the clutch in the mix seems, to me, like a TON of tweaking will be called for.
Old 11-16-2011, 06:53 AM   #1822
speedster
SST...
speedster's Avatar
R has a great response below.
We kept waiting for the AMS2000 to come out figuring by the time the SST was done it would be out. So we finally found someone who's 'soon' was longer than ours. (It STILL says that on their webpage 18 months later). Went with the 1000 which is an incredible unit.
The boost controller can save your motor with a manual trans. It reacts much faster than a human. (It has a 50 MHz processor) It uses direct clutch and shift inputs. It has a dedicated shift based mode R can use.
Old 11-16-2011, 07:25 AM   #1823
garcmol
garcmol's Avatar
Very cool! The shift points, to me, and the clutch engaging/disengaging seems it would be the most violent stage on anything with boost. Now, next question, what happens to the spooled boost with 1200++ ponies when you do shift? Is there a dip? Or, at the hp level, would you even notice a dip??
Old 11-16-2011, 09:28 AM   #1824
speedster
SST...
speedster's Avatar
It loses all possible boost, but R compensates by ripping out a huge methanol fart directly to the turbo intakes... Sorry, had a Mental Squad relapse...
Old 11-16-2011, 09:38 AM   #1825
JusticePete
Needs Lowering
So much for breakfast.
drive shaft specialists of tx, dss, erl, henderson performance tech, mike@thepowdercoater, pedders, rockland standard gear, rx catch can, slayer triple carbon clutch, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
