| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
![]() Drives: Black 2SS/RS M6 Join Date: Mar 2010
E85 and SCT Tune
so my question is this will the stock fuel system handle E85 with just simple bolt ons like headers, cam and intake, cat back exhaust. I have a friend that is running an 06 GTO making 630 hp to the wheels on E85 and his stock fuel system was able to handle it, the only thing that he had to add was a boot a pump because he was running out of fuel pump. So will the stock fuel system in the camaro handle 450-475hp on E85, looking for feedback from people that have experience with E85 and E85 tunes.
nobody, nobody running E85 with no forced induction?
![]() Drives: 2010 Camaro Join Date: Jul 2009
I ran E85 with a cam and headers the fuel system kept up the only change was to larger injectors. I used siemen deka shorty 60's
It won't be possible with the stock injectors
Mods: TVS2300, 3.2 pulley, American Racing Headers, Custom Cam, Coil Overs, Tuned for E85, 610RWHP* 570RWTQ
Follow me on Twitter www.e85lsx.com |
Before. The stock pump was good with the cam, exhaust and E85 all i did was change the injectors and tune it. It was probably around 450-475rwhp.
Now with the blower I am running a dual pump setup.
#6 |
Did the stock injectors run out of duty cycle, what was the need for new injectors was it the supercharger. The stock 47 lb/hr fuel injectors wont keep up with the demands of E85.
#7 | |
with a cam and E85 I ran 60lb/hr injectors now with the blower I'm running 80lb/hr injectors (these are rated at 3bar )
#8 |
#9 |
Hptuners, to tune for the E85 all you need to really do is change the stoich value in the tune. You just have to know the blend if E85 you have, here in NY it changes with the seasons
#10 |
thanks for the info, just trying to get an idea if what i need to do and if it is worth the time and money to change to E85.
#11 | |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
#12 |
Ted, can you shine a light on this for me i have talked to several people about E85 and havent got a solid answer. will the factory fuel system be able keep up with the demands of E85 with bolt on like headers, cat back, and cold air intake and a cam in the future. i have been told that the stock 47lb/hr injectors will be able to keep up, so just trying to get a solid answer. thanks.
#13 |
Camaro➎ moderator
E85 will corrode the stock fuel system and basically anything else that is plastic or rubber that it comes in contact with.You will have to change all your lines.
#14 | |
If the car is all stock then yes but with a few bolt ons and a Cam NO. Ted.
#15 |
I have a friend that has been running E85 for four years now and no problems with it. The car is stored winters and no problems with it he justs makes sure to run the car dry as much as he can before storage.
#16 | |
Camaro➎ moderator
But if you are ok with it, go for it.
| Thread Tools | |
