Old 01-06-2011, 08:13 PM   #1
martinezj454545
Drives: 2011 Camaro LS V6
Question Wiring diagram for turning signal lights.
I was doing the led behind the mirror lights mod to be used as a turn signal and the driver side turned out good and its still working, but when i tapped into the passenger side front turn signal all my lights inside the car started flashing and then the car and lights wouldnt turn on for about 4 hours. Does anyone have a diagram or know what wire to tap into for the signal lights(hot wire and ground) cuz now i am scared of actually doing it without actually knowing for sure this wont happen again, pictures would be good if you have them. Thanks
martinezj454545 is offline   Reply With Quote
Old 01-06-2011, 08:52 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Do you mean the front and do you have a RS car.
Old 01-07-2011, 01:02 AM   #3
martinezj454545
yes the front signal lights and no i have a LS model
Old 01-07-2011, 01:41 AM   #4
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
See if this will help....
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 01-07-2011, 03:42 PM   #5
martinezj454545
okay so when i tap into the right turning signal light i noticed that the lights was flashing faster than usual, this also happen before the car had that problem above. What does it mean if its flashing faster than usual/?
Old 01-07-2011, 03:53 PM   #6
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
You need a resistor, the car is thinking you have a turn signal bulb out!
c_LoW29 is offline   Reply With Quote
Old 01-07-2011, 06:32 PM   #7
meschwenk
meschwenk's Avatar
Take a look at this http://www.automotivelightstore.com/...er50w6ohm.aspx
meschwenk is offline   Reply With Quote
Old 01-08-2011, 01:00 PM   #8
martinezj454545
@C_LOW29 you kind of gave me a idea and it worked lol i was testing the lights with the connector not plugged into the actual bulb so basically the car thought it was out. But after testing it a couple times with the LED on the mirror and the connector plugged in it work like a champ lol. Sometimes you miss the simple picture but thank everyone for the help. Will post pictures soon.
Old 01-01-2012, 09:10 AM   #9
2010SSRSM6
2010SSRSM6's Avatar
Check out this thread.
http://www.camaro5.com/forums/showthread.php?t=96213
diangrahm, front lights, lights, turn signal, turn signal mirrors
Angel Eye Mod (93-97 Camaros) CamaroSpike23 4th Generation Camaros 105 05-12-2014 04:17 PM
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
FOG LIGHTS ON RS blueforza Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 04-17-2011 08:04 PM
Halo Lights & Driving Lights 87irocz 5th Gen Camaro SS LS LT General Discussions 34 02-01-2011 10:04 AM
lights wont go off Parrish 4th Generation Camaros 3 09-09-2009 10:11 AM
