01-08-2011, 01:06 PM | #1 |
Drives: 2011 Victory Red Auto 2SS Join Date: Aug 2010
Black exhaust pipes
I am running a unmodified SS. Have about 4100 miles on it and both exhaust pipes are black. Is that normal?
Always thought they should be a gray if mixture is set correctly. Mileage is a little lower than I expected. |
01-08-2011, 01:45 PM | #2 |
The tune from the factory is a little rich for safety reasons, hence the carbon on the tips.
01-08-2011, 04:09 PM | #3 |
The Hof
Drives: 2010 IOM Camaro 2SS/RS Join Date: Jan 2010
Pig rich IMHO
01-09-2011, 05:15 PM | #4 | |
It would seem to me that running rich would carbon up the heads and cause problems and also hurt gas mileage. |
01-10-2011, 08:42 AM | #5 |
Drives: GM anything Join Date: Sep 2009
It's only at WOT. The car does NOT run rich just driving around.
01-10-2011, 08:54 AM | #6 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Right, because in closed loop the O2 sensors keep things in check. But like the OP, I wonder why the tips are so black?
She is only memory now. |
01-10-2011, 02:05 PM | #7 |
01-10-2011, 03:33 PM | #8 |
It's black envy. The pipes want to match the body IMO
01-10-2011, 06:55 PM | #9 | |
Back in the day when we had good fuel the pipes would be gray. Or switch to race fuel and they turn gray. Ted.
www.jannettyracing.com
01-11-2011, 01:03 PM | #10 |
Although the tailpipes on my SS are still dark thanks to "environment friendly fuel", the amount of soot has been reduced at least 75% since I installed a catch can.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
01-12-2011, 04:48 PM | #11 |
I was under the impression that the 10% mix were cleaner burning. If it leaves a black residue, don't see how that could be true. Must be one of Al's miss understandings.
Thread Tools | |
Similar Threads | ||||
* > * > * > * BLACK FRIDAY SALE STARTS NOW! * < * < * < * | CamaroScotty | Dealer Camaros for Sale | 8 | 11-26-2010 04:10 PM |
Please help me choose.... | sfgiantsfan9 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 11-22-2010 10:34 AM |
Curious about the new v6 / exhaust diameter sizes | WCFB-Russ | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 16 | 10-28-2010 08:14 PM |
2LT exhaust options | Guardian1816 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 3 | 01-12-2010 09:28 PM |
black stuff on exhaust | jeffny09 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 18 | 10-18-2009 04:16 AM |
