Old 04-27-2011, 04:22 PM   #29
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Originally Posted by Moriartii View Post
This is a nice write up.
Couple of things:
1. Would you be willing to go back and edit your pics, specifically pointing out the clip locations and what not? You can use mspaint to do this.
2. Also did you mess any clips or break any fasteners when doing this?
I ask these two questions only because this looks like a major pain and this photo right up is excellent. With the addition of the fastener points it would make it perfect.
Cheers
K
I agree; for noobs like me who'd be stupid enough to attempt something like this it would be nice to see the connector points, tools used, and the technique used to pry off the pieces.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 04-28-2011, 09:35 AM   #30
YOUNGnRECKLESS
Building the Beast
YOUNGnRECKLESS's Avatar
Drives: 2010 VR LS3
quick question here, i have an amo and sub and aftemarket speakers are my next venture. When I installed a new DDIN head unit, upon raising the volume more than halfway, my speakers would distort. does this just mean i need new front and rears? or should i get a 4 channel amp when i replace them as well? Sorry to post here, but no one has been able to answer me anywhere else....would love some help
YOUNGnRECKLESS is offline   Reply With Quote
Old 04-28-2011, 09:47 AM   #31
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
I think it means dont raise your volume more than half way.
I believe it would be a good idea to replace the speakers as the OEM ones dont have a huge range (range as in power handling), so when you send more power to them you are over driving them I believe.
Or if you have the aftermarket amp connect to the speakers you could try changing your gains I forget it is it raising or lowering them.
Cheers
K
Moriartii is offline   Reply With Quote
Old 04-28-2011, 12:46 PM   #32
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
that seems odd that at 50% volume your distorting. are they REALLY loud and distorting or just distorting at moderate volume?
Its possible that there is something in the Metra kit thats causing the distortion and you just dont hear it at low volumes. There are a lot of connections between the head and the metra
Its possible that your overdriving the speakers (as Moriartii stated)
Its possible that the powered amp in your head unit is THAT bad... though with most mainstream heads, your going to get a much cleaner signal than an OEM head and it will be stable to a higher volume...
If you DO decide to get new speakers, I would suggest an aftermarket amp to power them instead of the amp within the head unit... while not typically as bad as you are describing, they are notoriously poor performers.
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 04-28-2011, 01:41 PM   #33
YOUNGnRECKLESS
Building the Beast
Drives: 2010 VR LS3
thanks for the info fellas!!!!
It's at a high volume. I have a Pioneer 3200bt and when i hit volume 20 or higher they distort, but the volume goes to 30 or more I believe....was just wondering.
I like how loud they are, just sometimes you always want more haha.
Again, thanks for the advice, I'll look into it somemore
Sean
Old 04-28-2011, 04:38 PM   #34
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
The speakers just can't handle that much power. When you get replacements they'll handle it much better. I think the stock speakers are only rated for 20Watts and that Pioneer unit probably puts out 50Watts. I can turn my Pioneer up to around 25 or so without any distortion on my Kicker speakers.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, ported throttle body, Stainless Works headers and exhaust, Skid Mark garage E85 kit. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 05-05-2011, 01:30 PM   #35
nancygrl
銀幽霊
nancygrl's Avatar
Drives: '17 Z71 Truck
Excellent write up/procedure. Although I've done plenty of installs over the years, I think I'll wait a little bit before attempting this. Certainly an "Add to Favorites"
Previous rides: '17 ZL1 M6,'16 2SS/A8, '15 1SS/1LE/M6, '13 Hotwheels RS, '11 2SS/M6
nancygrl is offline   Reply With Quote
Old 01-19-2012, 02:53 PM   #36
kiteman
Drives: 2012 45th Camaro, 2SS/M6
old thread so apologies for the revival. but why can't you just remove the speaker covers and pull the 6x9s out and replace them that way? i totally don't see why it's necessary to pull any panels out since after all, you're replacing speakers only and not panels. any explanation or help is appreciated.
kiteman is offline   Reply With Quote
Old 01-19-2012, 08:37 PM   #37
jfcody3962
Newbie
jfcody3962's Avatar
Drives: 2016 2SS
speakers are top mounted into the rear deck. they have to come out from the top and the only way to get them out is to remove the entire rear deck. The speaker grill tops do not just lift off.
2016 2SS
A8, Mag Ride, NPP, Sunroof, MRR MO17s in gloss black, 275/35 front, 305/35 rear, painted calipers
jfcody3962 is offline   Reply With Quote
Old 01-19-2012, 08:55 PM   #38
kiteman
wow that sucks. way easier just to add a sub and disable those 6x9s than replace them with some 6x9 woofers...
Old 02-20-2012, 05:42 PM   #39
ecko04
Drives: Too many to list
These were a certified P.I.T.A. ...put a stamp on em'
ecko04 is offline   Reply With Quote
Old 02-21-2012, 09:01 AM   #40
PIPE
Hating prius's since 1997
PIPE's Avatar
Drives: 2010 Camaro 2SS/RS (JENNA)
Old thread but great write up. Just to give my .02, I kept reading how the back seat back was such a PITA to get off the hinges. When removing mine I decided to spare the headache and just take a chance by removing the 4 bolts and 1 nut that hold the back seat bracket down. Was so much easier and also was able to do this by myself without scratching any interior. A few pics of the seat with bracket attched below.
PIPE
PIPE is offline   Reply With Quote
Old 03-17-2012, 12:06 AM   #41
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
Chad's ZL1 is offline   Reply With Quote
Old 04-10-2012, 11:14 AM   #42
montej23
montej23's Avatar
Drives: 2011 VR Camaro
Good write up and comments all this does not appear to be very difficult and will be doing this very soon in the near future.
montej23 is offline   Reply With Quote
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 69 08-19-2017 10:09 PM
My JL 12" and JL 250 amp install VIDEO AND PIX! TAG UR IT Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 02-12-2011 01:03 AM
Please help with speaker install!! camaro10rs Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 03-13-2010 12:32 AM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
