Gen5DIY
Old 01-09-2011, 03:13 PM   #1
08-G35s/6MT
08-G35s/6MT's Avatar
Drives: racecars
How much tube sand should you put in your trunk ??
I put 10% of curb weight(360 lbs., 6 bags of 60 lbs) in my trunk, so now I know what it's like to drive a 2-ton Cadillac CTS or a Camaro, I'm telling you this is awful ! I kid, I kid...But I usually have a 57/43 f/r weight distribution, since I added 10% to the back I should now have a 47/53 f/r weight distribution(corrected figure with added weight), so I'm like a Maserati Quattroporte or a Porsche 911. It feels like it rides a tad smoother though the steering is a touch lighter, looks like a put a lowering kit on it(the smallest of wheel gaps), so anyways... From what I've read this will help alot in snow, is this a good amount ?
Though it isn't "squatting" too extremely.
1 1/2 fingers gap for the back wheel gap. (used to be 2)
3 fingers gap for the front wheel gap.(used to be 2 1/2)
08-G35s/6MT is offline   Reply With Quote
Old 01-09-2011, 04:00 PM   #2
ssrs2011
Drives: 2011
ssrs2011 is offline   Reply With Quote
Old 01-09-2011, 04:02 PM   #3
montreal2010yellow
montreal2010yellow's Avatar
With all the electronics on a Gen5 you only need snowtires. Sand bags are a very old way to put weight but you don't need that anymore.
Old 01-09-2011, 04:09 PM   #4
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
take that out of there the car is heavy to begin with and you will just put undo stress on your car
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 01-09-2011, 04:10 PM   #5
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
I have 200 pounds in the trunk of mine and I still can't get up the incline of my street. Even with a light dusting I still have to go in reverse when I exit my driveway onto my street to get a running start up the incline. I've had 2 other Camaros and 2 Firebirds and this car is the worst on the snow. Two days and I'm done. It's in the garage. lol
GbrilliantQ is offline   Reply With Quote
Old 01-09-2011, 04:13 PM   #6
08-G35s/6MT
Drives: racecars
Well the Camaro is 52/48 to begin with, my G35 is 57/43. f/r weight dist. It's just the equivalent of having to average sized dudes sitting in the back seat, it's a sedan so that's like the whole purpose of it, so I would think it's just fine(though I realize I might be a little slower, use more gas, etc.; I am safer I guess you could say because of the weight, plus I have more even weight distribution and won't fishtail/spin out as easily).
Old 01-09-2011, 04:15 PM   #7
PatsSS
PatsSS's Avatar
Drives: Black 2SS/RS
Send a message via ICQ to PatsSS
Sounds like it's too much, if it is squatting that hard, I'd take some out. Like probably five of them, then if you get stuck, open up the last one and throw some under the tires.
PatsSS is offline   Reply With Quote
Old 01-09-2011, 05:18 PM   #8
vwilson686
vwilson686's Avatar
Drives: 2010 Cyber Gray 2LT/RS
so are you running with snow tires or the RS P-zeros.....???
vwilson686 is offline   Reply With Quote
Old 01-09-2011, 05:45 PM   #9
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
Rear weight bias could cause oversteer (fishtail spinout)..especially when slippery. Added weight also decreases MPG a bit.
http://en.wikipedia.org/wiki/Oversteer
upflying is offline   Reply With Quote
Old 01-09-2011, 06:32 PM   #10
INTIMIDAT3R
Drives: '11 2SS/RS L99, '12 2LS LFX
Sand belongs in the desert. NOT a Camaro.
Your steering/control is up front. Putting too much weight in back raises the front end of the car, reduces the friction on the front tires, and reduces steering AND braking power.
I have NEVER used sand bags in ANY of my vehicles and I live in Iowa. Drive like you're supposed to and you don't need them.
INTIMIDAT3R is offline   Reply With Quote
Old 01-09-2011, 06:33 PM   #11
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
My snow tires rock, I drive up hills in 3-4 inches of snowy slush and have no issues......
I had all seasons last year and didn't like them much. I switched to the Snow and Ice tires and it is awesome.
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 01-09-2011, 06:53 PM   #12
08-G35s/6MT
Drives: racecars
My car is usually 57/43, f/r weight distribution. Too little weight in the back makes oversteer harder to control, like a Mustang or truck. If there is weight in the back and you slowly, but surely, go around a corner you have much more control. Like a pickup truck with an empty bed versus with weight in it. Also the weight in the back makes it more stable when going a steady speed in one direction, versus wildly fishtailing if you steer one direction slightly ?
Old 01-09-2011, 07:38 PM   #13
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
My SS with Pzeros seems to get around fine in light snow. Being heavy pays off.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 01-09-2011, 07:40 PM   #14
GbrilliantQ
¡ʇuɐıןןıɹq
The P-zeros. I know thats the problem, but I have a beater for the winter now.
battery in the trunk, great idea, however... evilbeef54 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 02-10-2012 06:14 PM
Where's the best spot in the trunk to put a sub? Duper Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 09-25-2010 05:07 PM
Gun safe in trunk? Fogey 5th Gen Camaro SS LS LT General Discussions 88 06-26-2010 12:09 PM
Any hints on how to remove nuts from inside trunk lid? OHIOSS 5th Gen Camaro SS LS LT General Discussions 25 06-09-2010 11:49 PM
they put a cover in the trunk lid jordan 572 5th Gen Camaro SS LS LT General Discussions 10 03-18-2009 12:13 PM
