Old 01-09-2011, 06:23 PM   #1
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
Unhappy Had a great idea!....but didnt work :(
I was walking through walmart and saw one of those multi USB port devises(where One USB port becomes 4). So I got all excited thinking how cool it would be to be able to charge/select my phone, the girls phone, USB stick, and another device all at once! So I bought it, hooked it all up...and fail :( Nothing would be recognized that was attached to the multi USB ports. What a roller coaster of emotions... Maybe its the cheap 12 dollar USB port I bought. Thought it was a good idea.
CamaroC-17 is offline   Reply With Quote
Old 01-09-2011, 06:30 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Well, it was a good idea.
Old 01-09-2011, 06:32 PM   #3
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
2G2BT
Besides. As slow as my car charges my phone, I'd burn up a tank of gas to charge more than one at a time.
GTAHVITs car charged my phone from almost dead to full charge about as fast as a wall unit will. My car takes about 4 or 5 times longer.
Old 01-09-2011, 06:35 PM   #4
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
Yeah that sucks... would be a good idea though. Pretty sure that the owner's manual says something about it not being able to recognize such devices.............. or maybe it was a TSB that spelled it all out for us.
KeepItGreasey is offline   Reply With Quote
Old 01-09-2011, 06:41 PM   #5
Kahdir
Kahdir's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
LOL!
Went through a similar roller coster ride with trying to make a 500GB Western Digital Passport Drive work :(
Damn iPhone 3G 4.0 update
Kahdir is offline   Reply With Quote
Old 01-09-2011, 06:47 PM   #6
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
The reason for the devices not to work on the USB port of the Camaro is a power issue, the port can't handle more than one device at the time.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 01-09-2011, 06:50 PM   #7
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Service Information
2010 Chevrolet Camaro | Camaro VIN F Service Manual | Document ID: 2535739
#09-08-44-013C: Info on USB Command and Control Multimedia Player Interface/List of Supported Devices - (Oct 5, 2010)
Subject:Information on USB Command and Control Multimedia Player Interface/List of Supported Devices
Models:2010-2011 Buick Enclave, LaCrosse
2008-2011 Cadillac CTS
2010-2011 Cadillac Escalade Models, SRX
2009-2010 Chevrolet Cobalt
2009-2011 Chevrolet HHR, Malibu
2010-2011 Chevrolet Avalanche, Camaro, Equinox, Silverado, Suburban, Tahoe, Traverse
2011 Chevrolet Cruze
2010-2011 GMC Acadia, Sierra, Terrain, Yukon
2009-2010 Pontiac G5, G6, Solstice, Solstice Coupe
2009-2010 Saturn AURA, SKY
2010 Saturn OUTLOOK
All Equipped with Convenience and Connectivity Package - RPOs KTA, KTB, SRJ, U4H, UUI, UUJ, UUM, UUN, U2S, U2X, U2Y, UAV, UYZ, UY5
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 09-08-44-013B (Section 08 - Body and Accessories).
USB Radio and MP3 Functionality
The USB (Universal Serial Bus) will be a USB 2.0 port on the radio faceplate, on the IP or in the center console. This interface will give the customer the additional functionality of iPod/MP3 command and control. Customers now have full radio control of the iPod/MP3 audio files via the USB cable. A single USB connection allows digital audio transferring from the iPod to the radio. The customer will also have playback capability with a USB memory stick (only MP3 and WMA files).
Note: Not all memory sticks are supported.
Customers have full radio control of the iPod/MP3 audio files via the USB cable. A single USB connection allows digital audio transferring from the iPod to the radio. The iPod will be charging while connected to the radio.
Note: Video from the iPod is NOT capable of being transferred to a Navigation radio display.
For the Chevrolet Cobalt, HHR and Malibu; Pontiac G5, G6, Solstice; and Saturn AURA, SKY, the USB port is on the faceplate of the radio. For all other models, it is located in the center console or IP.
For the Cadillac CTS only, a special iPod cable (USB and AUX cable) is needed. This special cable comes delivered with the vehicle. In all cases, the iPod will be charging while connected to the radio through the USB port when the vehicle is running or the RPA is active.
Problems with iPod Not Connecting
If the infotainment system does not operate properly when using a device connected through the USB port, this may be due to an incompatible media device.
Important: DO NOT replace the radio or multimedia interface module due to a customer device incompatibility issue.
Verify the customer's media device is validated for this system using the list below. If the customer's device is a validated device for this system, follow the SI diagnostic procedure to isolate the fault. If the customer's device is not on the validated device list, explain to the customer that their particular unit is not compatible with the system.Troubleshooting Tips for iPod Devices
  1. Check the version of the iPod/MP3 to confirm that it is supported. Unplug and Re-insert the iPod to verify the customer complaint. Verify the battery charge of the iPod. A low battery condition on the iPod may not allow it to connect to the radio. The iPod may need to be charged before it can be controlled by the radio.
  2. If the customer receives a "Device Not Supported" message on their radio or is having general iPod/MP3 connection issues (and they have a supported device), they may need to reset their iPod. To reset the iPod:
    For the iPod Nanos and Classic , Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
    For the iPod Touch and iPhone: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider.
  1. Have the customer check their cable for quality.
    Aftermarket cables can wear from use. The customer may need to purchase a new USB cable.
    Verify that cable extensions are not present. The extra capacitance may cause too large a signal drop for the iPod to communicate with the radio.
  2. If the customer receives a "Device Not Supported" message on their radio with an iPod connected (and they have a supported device), the customer may need to download the latest firmware from the Apple website (Please visit www.apple.com for more information).
Validated Apple Device - Both Charge/Support Digital Audio (For All RPOs)
For further information on identifying iPod models, please visit http://support.apple.com/kb/ht1353
Brand
Name/Description
Number
Apple
iPod Classic 5 & 5.5 Gen
1
Apple
iPod Nano 1Gen
2
Apple
iPod Nano 2Gen
3
Apple
iPod Nano 3
4
Apple
iPod Classic
5
Apple
iPod Touch 1Gen & 2Gen
6
Apple
iPhone (User must switch to "airplane mode")
7
Apple
iPod Nano 4 GEN
8
Other Validated Device-- Both Charge/Support Digital Audio for Buick LaCrosse, Chevrolet Camaro, Equinox Only (RPO KTA or KTB)
Important: : Must be set to MTP (Mass Transfer Protocol) in the MP3 Player device setting.
Brand
Name/Description
SanDisk
Sansa e280
Toshiba
Gigabeat
Philips
Philips GoGear
Sony
Sony NWZ-A828
Sony
Sony NWZ-S616F
Insignia
Insignia
Iriver
Iriver Clix
Iriver
H10
Samsung
S5J AB/XAA(4GB)
Samsung
T10
Samsung
Yepp S5
Microsoft
Zune (Gen 1 & 2)
Important: These devices (and additional MP3 players) may be capable of connecting to the other USB options by internally setting the MP3 device to MSC (Mass Storage Class) mode. In this mode, the USB port will see the device as a flash drive. Please have the customer refer to their MP3 device manual on how to set the device to MSC. If the device is not able to be set to MSC, the customer must use the AUX jack.
Note: MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content.
Non-Validated Apple Device
Important: The following devices are NOT supported by USB interface. Apple does not support digital media transfer from these devices through the USB port. The customer can still listen to their older iPod on vehicle by connecting it to the Auxiliary Input Jack using a standard 3.5 mm (1/8 in) stereo cable.
Brand
Description
Number
Apple
iPod Shuffle Gen1
1
Apple
iPod Shuffle Gen2
2
Apple
iPod mini Gen1&2
3
Apple
iPod Photo
4
Apple
iPod G4
5
Apple
iPod Gen3
6
Apple
iPod Gen2
7
Apple
iPod Gen1
8
Apple
iPod Shuffle Gen 3
9
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 01-09-2011, 06:53 PM   #8
oldfriend
Drives: Fiat 500 E
2SS
2G2BT
HEY .. PQ... you should have done FUESE REMOVAL [for 120 minutes ] before try do that , then you my be in for a WOW
Old 01-09-2011, 07:19 PM   #9
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
LOL!!!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 01-09-2011, 09:00 PM   #10
PQ
Booooosted.
PQ's Avatar
Old 01-09-2011, 09:04 PM   #11
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Another thing to consider is that unless the USB Hub is powered it might not have enough juice to power the plugged in items, but even still I don't think the Camaro can support such a setup.
9/26/09 Took delivery!
Old 01-09-2011, 09:06 PM   #12
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Would of been cool to be able to scroll through sources on the radio and pick from a couple diff phones or usb sticks
Old 01-10-2011, 08:14 AM   #13
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS
Yeah, it would be cool.. but given the size of modern day memory sticks.. why would you really need to? Throw a thousand MP3 files on a stick, and youll be sick of driving long before you run out of music. Just Saying...
SSFury is offline   Reply With Quote
Old 01-10-2011, 08:27 AM   #14
getarz4u15ster
getarz4u15ster's Avatar
Drives: Camaro RJT 2SS/RS
A powered USB hub should do the trick. Having a non powered USB splitter will not do any type of packet switching and routing to avoid collision detection, therefore cause data collisions in your head unit. A USB powered hub helps correct that problem, might not completely eliminate it though. Your head unit firmware might not support multiple USB connected devices. If that's the case... SUGGEST IT TO GM... that would be great! =o)
2010 RJT SS
Port and Polished, Milled .005 Heads
Patriot Valve Springs, Titanium Retainers&locks
Manley Race Valves
Comp Chromoly push-rods
Ported T/B
DT Headers, JBA H/F Catted mid pipes
Magna Flow Comp series exhaust w/ Xpipe
Comp Custom grind Cam
Tune and Machine work done by MPC
CAI Intake
getarz4u15ster is offline   Reply With Quote
i have an idea, but i need some help adub4185 Cosmetics and Lighting Modification Discussions 12 05-24-2011 05:06 AM
So, wanna work half the year and make lots of money... SSE 4 2SS Off-topic Discussions 20 12-16-2010 04:20 PM
Great story over the weekend roccky08 5th Gen Camaro SS LS LT General Discussions 36 12-09-2010 05:37 PM
Is this a good idea...or a great one? jebckr 5th Gen Camaro SS LS LT General Discussions 28 01-24-2010 01:03 PM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 10:17 AM
