Old 01-10-2011, 08:58 AM   #1
Larz29
Larz29's Avatar
Drives: 2010 camaro ss LS3 cyber grey
Rear sway bar
I ordered a rear sway bar for my car that is adjustable between 80/120/170 % stiffer than stock to address the understeer issue. I did not get the front bar because I had a bad expeirence with my mustang as a daily driver with a very stiff front sway bar.
Will I notice much of a difference with just the rear sway bar? What % stiffness should I have the new rear bar set at with the stock front sway bar to work in harmony?
Larz29 is offline   Reply With Quote
Old 01-10-2011, 10:29 AM   #2
AdamCzap
AdamCzap's Avatar
Drives: '10 TT SS / '07 Escalade
Yes you will notice a difference. I did mine about a month ago and did the rear one by itself at first, so I know what you will experience with only the rear. It's still a HUGE improvement! I bought the Pfadt adjustable bars. Mine is set to the stiffest setting possible. Definitely noticeable difference in cornering with just the rear. In fact, I don't really even know if I could distinguish a difference after I added the front bar! I haven't done any real testing though.
L99 Hellion Twin Turbo @ 7lbs 545rwhp, 560rwtq
Noweeds.net diverters
Pfadt solid subframe mounts, diff bushings, sways, trailing arms
Walsh Motor Sports tune
11.63 1/4 @ 123.5mph 1.87 60' on stock rubber
www.adamczap.com
AdamCzap is offline   Reply With Quote
Old 01-10-2011, 10:48 AM   #3
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Fishdadddy is offline   Reply With Quote
Old 01-10-2011, 10:53 AM   #4
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
+ 1
I added front and rear sway bars (adjustable) 1 day before putting my Camaro into winter storage. Only did a 30 minute test drive. Waiting for the end of the salt season to do some real testing.
Old 01-10-2011, 10:54 AM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Larz29. Give us a call. We can help you out.
Old 01-10-2011, 12:55 PM   #6
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Use the 80 or 120 setting if you are just doing the rear bar. This will effectively neutralize the understeer. The difference is very noticeable...
BMR guy is offline   Reply With Quote
Old 01-10-2011, 05:28 PM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
These two posts pretty well sum it up.
Old 01-10-2011, 05:59 PM   #8
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Chase do you sell just a rear bar?
Scott@Bjorn3D is offline   Reply With Quote
Old 01-10-2011, 06:54 PM   #9
Apex Motorsports
Yes sir, we have Pfadt and BMR rear sway bars.
Old 01-10-2011, 07:11 PM   #10
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
The setting will depend on the rear bar diameter and strength. The larger the bar, the thicker the wall in a hollow bar the stronger it will be. If you had purchased Pedders rear 27mm solid bar I would suggest the softest setting as it is such a strong bar. A 27mm standard wall hollow bar you could easily go to the second strongest setting. You get the idea.
Start on the softest setting and get to know how your car responds. You can work your way up from there. Pay attention to the endlink nuts. They lose their quench, the resistance to coming loose, as you take them on and off. You can use LocTite instead of new nuts, but use it sparingly or you may find you can't get them off.
Old 01-10-2011, 09:10 PM   #11
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
+1
I did my rear first as well and could tell a huge difference. I set mine to the middle hole and haven't felt the need to change it. I put the front on a few days later and could tell that it improved a little but near as much as the rear.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-11-2011, 06:51 AM   #12
Larz29
Larz29's Avatar
Thanks for all the wonderful feedback guys! I can't wait until Winter is over which I'm sure a lot of you agree!
Old 01-12-2011, 10:47 AM   #13
Jay_LHD3
Jay_LHD3's Avatar
Drives: 2017 Fiesta ST
Awesome thread!
I decided a long time ago to just go with the Pfadt Rear Balance Bar, which I will be buying in a few months. After passing on the awesome deals going on during SEMA, I started doubting my decision for not getting the Springs and Sways.
This thread reassures me that I made the right decision for my daily driver and in the process saved a couple hundred dollars.
I’m assuming that the Rear Balance Bar is the same as the Rear Sway Bar, just not adjustable due to it already being preset to perform best with the stock front sway bar.
Balance Bar
Rear Sway Bar
Jay_LHD3 is offline   Reply With Quote
Old 01-12-2011, 11:01 AM   #14
Fishdadddy
Fishdadddy's Avatar
Hotchkis versus Pfadt Sway Bars Avalnch Suspension / Brakes / Chassis 77 10-08-2010 10:37 AM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 09:17 PM
Hotchkis Front and Rear Sway Bar Kits Ethan@HigherPower Suspension / Chassis / Brakes 0 01-20-2010 08:28 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 12:06 AM
Pfadt Race Engineering Balance Sway Bar package PfadtRacing Wheels and Tires Talk Sponsored by The Tire Rack 0 08-17-2009 01:41 PM
