Jason 98 TA
Old 01-10-2011, 09:06 PM   #1
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
OE Quiet Endlinks with Spherical Function
Spherical endlinks have been a staple on race cars for years. Spherical endlinks are not perfect. They are either noisy when you bolt them on or will become noisy after you use them. The range of motion can also cause issues with your setup.
Pedders new endlinks use a unique process. Unlike a traditional cast ball and stud, Pedders endlink ball joint starts life as a ball bearing. The stud is friction welded to the ball bearing. There are NO bolts. The housing is a precision casting with an extreme high temperature epoxy coating for a virtually perfect fit.
For OE, Xa coilovers and brand-x coilovers order CAMENDLINKKIT1
For Supercar coilovers order Camaro Endlink Kit Supercar
Camaro Rear
The function is far better than thje lame picture I have on my laptop. There are better pictures available in out catalog, but I'll get a better one up when I am back in the office.
This just in from PRI
GM and Pedders? No, Pedders does not make the GM Race Endlink. Pedders and GM do use the same ball joints. Two Great Great Companies Thinking the Same Way.
Last edited by JusticePete; 09-26-2013 at 01:10 PM. Reason: Better Picture Inserted
Old 01-11-2011, 01:12 PM   #2
Coop
Drives: 2010 Camaro 1SS
Those front endlink rods do not look any beefier than stock or is it just a bad pic?
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 01-12-2011, 03:26 AM   #3
JusticePete
VIR Specialist
Really bad picture. I am away from the office at West Coast Customs. When I get back in the office I'll post up more detailed pictures.
Old 01-12-2011, 11:17 AM   #4
Robbie1227
Robbie1227's Avatar
Drives: 2015 Camaro Z28/2016 Jeep Sahara
Will these work with Pfadt sway bars?
2015 summit white Z28 #120 TRK DAY
-Sun-Tek PPF-C protection film on 2/3 of the car, Moreno Camber plates, American Racing 2" ceramic coated LT headers and X-pipes with No Cats, Taylor red performance wires, NGK plugs, BTR Stage III Cam, MSD Atomic intake, Nick Williams 102mm throttle body, Stage 2 CNC Ported Heads by WCCH, MGW short throw shifter, oil catch can, and a dyno tune to get me to 587 RWHP and 516 RWTQ
GONE:
2013 Summit White Camaro ZL1 M6
Roto-Fab CAI, Kooks headers and CAT delete, ATI damper and 10% pulley and balancer!
Results: 576 RWHP - 540 RWTQ
Robbie1227 is offline   Reply With Quote
Old 01-12-2011, 11:48 AM   #5
JusticePete
VIR Specialist
Yes sir.
Old 01-12-2011, 03:39 PM   #6
jomo45
jomo45's Avatar
Drives: 2010 SS/RS Silver Ice
Installed the Pedders bars and these end links last weekend, huge improvement, and they are quiet as advertised. I did have issues with the lack of instructions included with the parts, and the incomplete ones on Pedder's website... One example is these end links don't require drilling the existing mounting holes on the car as described in the online instructions, didn't discover that until after drilling. Good product though.
2010 SIM SS, 6spd Man, Pedders Sway's & End Links, JBA cats, CAI, MGW shifter, SLP Skip Shift, COR F1 Precise Monobloc, 20X9 & 20X11. Pfadt Coilovers, BMR Subframe bushing inserts, BMR rear trailing arms, Pedders Front Radius Rod inserts.
jomo45 is offline   Reply With Quote
Old 01-12-2011, 04:42 PM   #7
Rob@WretchedMS
Drives: His Wife Crazy
i've added these new parts to our site,
Rob@WretchedMS is offline   Reply With Quote
Old 01-12-2011, 05:47 PM   #8
larryt1026
larryt1026's Avatar
Drives: 2011 Camaro LT
will replacing this part quiet some of the odd noises that our Camaro makes? . I'm newbie with cars..just wanted to know what this does.
larryt1026 is offline   Reply With Quote
Old 01-12-2011, 06:00 PM   #9
Rob@WretchedMS
it's a replacement link that will be stronger than the stock links area, but typically not going to something that you replace to make the car quieter if it's still stock suspension wise.
The available aftermarket parts have been known to make noise, this hasn't been the case with the Pedders links, these are just as quiet as stock, but are much stronger.
Old 01-12-2011, 06:17 PM   #10
PartsGedder
Drives: -
Give me a call at the warehouse (830.522.4757) and we'll arrange getting you new ball ends with larger studs.
Regards,
Dan
Dan Morris
PartsGedder is offline   Reply With Quote
Old 01-12-2011, 06:18 PM   #11
Rob@WretchedMS
Dan's the man...
that can arrange for your larger studs, lol
Old 01-12-2011, 06:32 PM   #12
JusticePete
VIR Specialist
I would love to say yes and tell you to buy Pedders endlinks, but the answer is no. Your OE endlinks should be just as quiet as Pedders high efficiency endlinks. If they are not, they are covered under warranty.
Upgrading to Pedders high efficiency endlinks:
for stronger more durable ball joints.
to improves sway bar function.
for corner weighting adjustable length endlinks are essential.
are an excellent replacement for anyone tired of the noise from spherical endlinks.
Overall the Camaro is an exceptionally quiet car. Tell us about your noises.
Old 01-13-2011, 09:46 AM   #13
jomo45
jomo45's Avatar
Dan is the man!!! That's really awesome, thank you, great service!!!
Old 01-14-2011, 03:23 PM   #14
JusticePete
VIR Specialist
Better Pictures Part #1
Engine sounds so quiet jagan323 5th Gen Camaro SS LS LT General Discussions 15 04-14-2010 12:22 AM
Pfadt Racing new Camaro Endlinks available NOW! PfadtRacing Suspension / Brakes / Chassis 28 03-22-2010 01:00 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Spherical Rod Ends LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:59 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Spherical Rod Ends. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:44 PM
