Old 01-12-2011, 02:15 PM   #1
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
4L60E Goes out! 5 years old and 61k
*edit*
The sun shell gear went out. Great product here gm. He is looking forward to never buying a GM product again, and selling the hummer. It only has 61k on it.
My brother has a hummer h3. It is an 06. It is an automatic. He were sitting at the light, and went to get on the gas, and it acted like its in neutral, this was in park. The only gears that work are 1st (i think). And for sure 2nd and reverse, what could be wrong with it. If you put it into drive, it doesn't seem to engage, you can move the shifter without touching the button and it will go into neutral. Help would be greatly appreciated.
Thanks.
Old 01-12-2011, 04:22 PM   #2
shank0668
shank0668's Avatar
Any ideas?
Old 01-12-2011, 04:24 PM   #3
Camaro21
Drives: SOLD - 2013 M6 ZL1
I would start by checking the fluid level in the transmission.. If the fluid level is ok, then sounds like you may need some internal transmission work. If the fluid level is low, fill it up and while sitting still, switch back from Park to neutral, then drive back and forth several times. It does sound like you have internal issues though..
Keith
Camaro21 is offline   Reply With Quote
Old 01-12-2011, 04:27 PM   #4
nester7929
Rice Harvester
nester7929's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Sounds like that's a job for the shop, unless it's a fluid problem.
nester7929 is offline   Reply With Quote
Old 01-12-2011, 04:31 PM   #5
shank0668
shank0668's Avatar
It's weird because it doesn't even try and go into Drive or third. It is definitely neutral in those gears. I don't know why it would happen all of a sudden when you are in drive. And i think when you put it into first, it's actually in second.
Old 01-12-2011, 06:07 PM   #6
chain777
Drives: Slow
Maybe the shifter or linkage is broken.
chain777 is offline   Reply With Quote
Old 01-12-2011, 09:59 PM   #7
shank0668
shank0668's Avatar
Isn't everything electronic?
Old 01-13-2011, 01:24 AM   #8
REEFBLUE93
Drives: 1993 Rustang
Keith
+1 on checking the tranny fluid and/or filter. On another note, OMFG @ your 1/4 times with your 600+rwhp.... you should be deep into the 10's man
REEFBLUE93 is offline   Reply With Quote
Old 01-13-2011, 02:31 AM   #9
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
Not on those 20s and street tires. Smaller wheels and DRs and yeah he should be in the 10s.
Old 01-13-2011, 03:51 PM   #10
shank0668
shank0668's Avatar
Figured it out, edited first post. He is not happy.
PDIM Problem? ChuckBuSSter Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 31 09-25-2010 04:17 PM
Main Pulley out of Alignment. Problem? Die Zielscheibe Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-08-2010 04:51 PM
clutch/master cylinder/ problem. jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 03-20-2010 11:59 PM
pm problem drivingincamaro Site Related Announcements / Suggestions / Feedback / Questions 4 06-23-2009 11:20 PM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 10:22 AM
