HeadlightArmor
Old 01-12-2011, 09:06 PM   #1
Milkman20
Milkman20's Avatar
Drives: Red 2010 Camaro 2SS L99
L99 cam question.
so, i've been thinking about getting a cam for my L99 but i was told that i need a stall converter, which im guessing is a stall torque converter which ive never heard of. someone tell me if this is right, or whats the deal with installing a cam on an L99. thanks for the help.
,Steve
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers
Exhaust Clip: http://youtu.be/c_quv8eoVNQ
Milkman20 is offline   Reply With Quote
Old 01-12-2011, 09:41 PM   #2
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
You do not need a stall torque converter. You can have a cam make to suite your driving and power needs.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - Granatelli Brake Lines - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 01-12-2011, 10:04 PM   #3
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
i have a blower cam in my L99 with a stock converter, and it drives just fine.
comp cam 223-236/.610-.608 117+4 its got a little lope too. of course it has been converted to an LS3.
call shane at thunder racing he will hook you up.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 01-12-2011, 10:23 PM   #4
klatterblast
sorry i did not answer your second question about putting a cam in the L99 , in case you dont know its i little more complicated to just put a cam in the L99 and more expensive than the manual transmission LS3. the valve train has to be converted to the same configuration as the LS3. or get a vvt cam.
Old 01-12-2011, 10:53 PM   #5
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
,Steve
CCP is correct. A stall is not required for a cam. If you want a really big cam, you'll want to do an LS3 conversion. You can also go with a VVT cam, which won't make as much power, but will still give you that great sound and is a cheaper install.
Also consider whether or not you're going to buy a blower in the future. If so, I'd recommend waiting and choosing the right cam for the SC.
Old 01-12-2011, 11:00 PM   #6
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
BTW...I noticed in your signature you have a diablosport tuner listed. If you're running a canned tune with your headers you're probably leaving power on the table. Also, you're definitely going to need a dyno tune with a cam.
Old 01-12-2011, 11:16 PM   #7
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
,Steve
Swapping out the Torque Convertor in your Auto Transmission for a higher stall RPM is needed so the idle can be raised up to keep your car from stalling out. If you didn't change the TC you would have to stand on the brake at stop lights to keep the car from moving forward as the idle will be set shigher.
As some said you can get a small cam and keep the stock convertor, but I would recommend getting one. Even without a cam a TC is the best bang for your buck in the L99. Also your Diablo is pretty much worthless on an L99 since it will not tune the transmission and that's the best part of an L99 tune.
Hope this helps...
Old 01-12-2011, 11:19 PM   #8
Milkman20
Milkman20's Avatar
yea that was kind of a waste to buy cause i don't use it, i got it professionally tuned before i put my headers on. if you look in my sig there is a video of me getting it professionally tuned and he didn't use the diablosport. he did a really good tune also, but i got headers so i have to get it retuned, but i think ill wait for my cam for a year or so i can get the best one for whatever SC ill buy.
Old 01-12-2011, 11:23 PM   #9
Milkman20
Milkman20's Avatar
Hope this helps...
thanks, it does help, but do you a good place where i could buy a higher stall converter.
Old 01-12-2011, 11:27 PM   #10
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
I think that's a good call. I had my cam installed at the same time as my blower.
Also, don't think that I was preaching against a stall. I was just saying that it's not required. Mlee was exactly right about all the benefits, and as you can see in my sig I have one as well. I actually installed mine before my SC, as it is definitely the best bang for the buck.
Old 01-12-2011, 11:32 PM   #11
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
Mlee and I both bought the Circle D torque converter (3200 stall). You can order it directly from their site.
http://www.circledspecialties.com/p-...converter.aspx
Old 01-12-2011, 11:52 PM   #12
Milkman20
Milkman20's Avatar
Thank you @Dangeruss, @mlee and @klatterblast. Also the cam i was thinking about getting is the MTI stage 2 cam http://mtiracing.com/Purchase/New-20...10-Camaro.html. so if i were to get that cam would the torque converter be the only thing id have to do?
Old 01-13-2011, 07:59 AM   #13
mlee
www.CamaroFans.com
mlee's Avatar
Since you have an L99 you would need to swap out the DOD (displacement on demand) lifters with that cam. There are cams specifically made for keeping your lifters called VVT (variable valve timing). This would save pulling your heads. There are pros and cons to both... just do a search on VVT and you will find lots of info... my preference is to get rid if the lifters it's the weak point even in a stock L99.
As with any cam install, springs and pushrods are an easy swap also
Old 01-13-2011, 02:30 PM   #14
Awesome_SS
Jeff
Awesome_SS's Avatar
Drives: 2010 Camaro SS/RS
This might help you some. I also have the L99
http://www.camaro5.com/forums/showthread.php?t=123470
Awesome_SS is offline   Reply With Quote
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
L99 Catch Can Hose Routing Question mlee Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-17-2010 09:19 PM
L99 cam KTMracing09 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 09-13-2010 07:45 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Another L99 cam question....VVT! SS-screamer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 90 06-28-2010 07:41 PM
