| General Automotive + Other Cars Discussion Come chat about other cars. |
Thread Tools |
#426 | |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
Got everything buttoned up on the motor last night and will hopefully crank and run it tonight. Then we will have to check the tune to make sure everything is good....so hopefully I will get to drive it this weekend barring any hold ups...This way we will be able to tell if there are any other issues.
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
#427 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 1LT SIM; 91 B4C sleeper Z Join Date: Aug 2009
#428 |
and MR. HYDE
I have not as of yet...We are gonna have to see what works. The new brackets we had to install for the linkage of the throttle and kickdown cable is higher than a normal carb since it is a throttle body. Since it is only used for air and no fuel it is kinda low profile.....so a round one will not fit unless you put a spacer on the T.B. To me it looks funny that way.....
SO this is what I looked at today......The throttle body I have but thinking about putting this scoop/air cleaner on it.
#429 |
You're going to run into a linkage issue with that one as the butterflies are functional. I just get a kick out of knowing you get to drive it this weekend!
#430 | |
and MR. HYDE
From what I was told today the only thing that they would recommend would be adding a return spring so that it would close properly....Plus this should cover up some things that I wanted hidden. The issues is the bracket that holds the kickdown and TB cables it is kinda high so to clear it with a round air cleaner, which I do like, you would have to add a 1 1/2" spacer on top of the throttle body so it would touch the linkage.......we are going to try and lower the bracket tonight to its lowest position to see if that helps with clearance issues but my idea of a 2" spacer on top of the TB doesn't look to good..
#431 |
Oh, cool. Well that would look pretty cool sitting on top of the motor!
#432 |
and MR. HYDE
Just depends on how much it costs...for right now I may just get a 6" air cleaner to be able to test drive it.
We are gonna re-check all the fluids, change the oil and all that jazz...then Matt can check all the engine function stuff on his laptop...hopefully much did not change but I do know that it changed a little since we have so many vacuum leaks before and the readings were not consistent. Now that we have an intake that is port matched to the heads air flow should be ALOT better, plus we changed the fuel supply a little but any changes needed will be a simple push of a few buttons. Once he has the basic tune done then we can drive it so he can see what it is doing during normal operating temps, speeds etc......and maybe just maybe all the wiring we did, the re-doing of the gauges and balancing of the tires will allow us to get an accurate speed, with no vibrations and the motor to perform correctly. ALSO we came up with a solution about the rear tires being too far to the rear. I have ordered a new crossmember from CPP. It allows for it to be bolted in instead of the factory rivets so we will be able to move the rear wheels forward wherever we need them then bolt it down. The only issue with this is I will have to have the driveshaft cut down but that is no big deal. This is something we will do when it goes to get painted so we can have easier access to drill holes etc....plus the new crossmember has holes in the center of it so that you can run up to a 3" exhaust. It allows the pipe to go straight through the crossmember instead of below or above it...much nicer installation.
#433 |
So you'll do the crossmember deal with the bed of the truck off? Where in the world do you go to get a driveshaft shortened? This is some wild stuff to me.
#434 | |
and MR. HYDE
Once we get it to the paint shop and they disassemble it for paint then we can complete that install....Once it has been moved we will measure for teh driveshaft and have it cut down by a " Draftshaft" Shop. It is the driveshaft shop who builds driveshafts for Matts Boss's race cars. I am just leaving it all up to him.
#435 | |
#436 |
and MR. HYDE
I always have......
#437 |
"Kill it with flame!!!" Wait, no, we don't want to kill it. "Fix it with flame!!!"
#438 |
and MR. HYDE
Ghost Flames....LMAO
#439 |
![]() Drives: 1997 Camaro SS Join Date: Apr 2012
That is one b*tchin machine!
#440 |
ACE5 (Atlanta Group)
Drives: "Black Ice" Join Date: Sep 2010
Great progress John. Gettin' closer!
Honored to be Camaro of the Week:
[COTW 5/2/11] 2011 Two-Tone White/Black SS/RS Convertible See our Atlanta Social Group or home page: ACE5.org |
#441 |
Well? Did you get the drive in? All tuned and running? ..........................
#442 | |
and MR. HYDE
Just so happened that Matt got sick and has been for about 3 weeks...he had to stay out of the heat for a couple of weeks...but he is back on his feet now. We installed the tune over the weekend and it fired right up and idled great....problem is the idle air control sounds like a jet fighter sucking air and that has to be tuned out or down...Problem is when you change one thing you have to change a lot of other things...I have no clue ![]() We did let it run for a few minutes to check for leaks and things like that nad so far everything is good to go. This thing move A LOT of air and if you turn the IAC down to much it has trouble cranking so we have to find a happy medium on that so that the AF ratios are good. We are gonna try it again tonight with the update to the update. After we get the idle tune just like we want then we can drive it. It will run now and drive but not optimally...oooh big word. It did sounds good though, especially to hear it run. Matt did bring me a surprise.........A 3 1/2" Chevy Bowtie set of exhaust tips....gonna look oh so good. Speaking of which.......Dont know if you remember but the rear wheels set farther back and were not centered in the wheel well.....So I ordered a new crossmember from CPP and it came in. This will allow us to move the rear end forward or backwards to any place we like it...but this crossmember also has holes in the center of it as to allow the exhaust a smooth path to the rear. It allows for better flow and makes it look a whole lot better. We are gonna install it after we get it running right. 10 holes and we are done with that.....This should have been done along time ago.
#443 |
and MR. HYDE
FINALLY
We finally have the idle tune pretty much dead on. Still have to work on the IAC a little bit. A/F ratio is not perfect but running at 14.4 so I can't complain. We tested the idle at several different times, cranks right up and no hesitation. We were going to get the rest of the tune hooked up BUT the bottom radiator hose blew off didn't tighten the clamps up tight enough. Since the water temp was 189* we decided to wait till today to get that corrected.In the mean time we worked on the seat mounts...I decided to change the seats. The ones they had used were SUPPOSED to be new but in all reality looked like junk yard seats so I bought some seats from Summitt Racing....I will have them modified when I do the interior.....gonna make them shorter so they are below the back window. We are going to fabricate some 4" brackets to raise the seat up enough. Due to the way they steering column was installed we decided to change it as well. We are changing the transmission linkage to a cable linkage instead of a rod linkage. We are also going to sink the steering column 2" into the dash to give more room, couple that with a short steering wheel adapter it should give me 4" farther away from the seat than it is now. I wanted to drive it but Matt has refused until the air cleaner arrives...I ordered it yesterday and it should be here in a couple of days...no air cleaner means it doesn't move according to Matt:( We have about an hours worth of wiring left and a couple of other little things to get it running so we can test it. I finally got the front bumper installed as good as I could get it.....I guess they were not as aware of gaps in 1963.....the outside of the bumper is the same difference on both sides but the inside gap is a little different one each side and the only thing I can think of it the bumper....I cut a cardboard template of one side and then tried to math the bumper on the other side and it didn't match so that may be something I just have to live with...It is the original bumper so I guess that is to be expected. I was planning on re-chroming the bumper but the cost is way too much...it is cheaper to buy a new bumper...like 700.00 cheaper...Chrome is EXSPENSIVE. Since we fixed the radiator and heater lines we also tested the heater and it works great....We will be charging the AC before we drive it...Will have to pull a vacuum to make sure it is clean and doesn't leak, then fill it with freon....Luckily Matt has all those tools and is Freon Certified. GETTING CLOSER
#444 |
and MR. HYDE
More and more...sometimes I think the more I do the further I get behind...LOL
Worked on Ole Hyde this past weekend and got some thing accomplished but seems I have more to do. The new air cleaner came in Friday and of course it does not fit :( and will have to be modified so it can clear the throttle linkage bracket. Matt has a Mill at work and it going to do that today if he gets the new tooling in. He tried to finish up the seat brackets but the cutting bits broke and no one was open this weekend to get more:( So we did some other things while we were waiting. I relocated the gas pedal. It was too far to the left and didn't give you hardly any room. We removed it and moved it about 3" to the right. Funny thing is we had to unhook the throttle cable linkage. The linkage is held in by a c-lip retaining ring...Guess what? It didn't have one so the pin could have easily vibrated out ![]() Easy fix. We did get the Idle Air control adjusted so it doesn't sound like a 747. Checked all the hoses made sure they were tight. Changed the oil, topped off the radiator. I am still waiting on the transmission cable linkage from Summit, plus the other steering column items I needed so hopefully in a day or so it will be here. Just some thoughts on ole Hyde. It is amazing to me how much has to be modified especially when you are buying bolt on items...I guess not to much is truly bolt on especially on this thing..... We still need to work on the cold start up in the tune but that isn't too bad. Not really a whole bunch left before we can truly test drive it....just really waiting on parts.
#445 |
![]() ![]() ![]() Drives: "Bee" ZL585 Join Date: Nov 2010
Good to hear you're almost there...
I'm about to give up on the TVR... |
#446 |
and MR. HYDE
Peebee dont give up, dont ever give up.....One day it will be worth it...that is what I tell myself.
#447 |
and MR. HYDE
Got a bit more done last night...just seems like it is slow going but at least the things I am doing now are finishing things which is a good thing.
Got the throttle linkage adjusted and the c-clip added to the linkage. Drilled the other two holes for the transmission crossmember and got it bolted down. Drilling holes in a frame from 1963 is a tough job especially laying on your back...some tough stuff. Got the rest of the wiring under the truck tied up and placed against the frame.. Got the air cleaner installed....had to do some modifying to it to get it to fit so the throttle linkage would clear. Also got the Air Temperature Sensor installed in the air cleaner. Still have to get the linkage for the butterflies installed...of course it needs modifying... We punted on the seat brackets...just didn't seem to work like we wanted. We ended up making another bracket...more of a box version that runs the length of the seats...so will have to make three more tonight. Got an e-mail from Summit that the parts I ordered, transmission linkage, short steering wheel adapter and a couple of other things were shipping from the manufacturor and they are currently on back order....Man I just love it when they tell you parts are in stock and should be there in 2 days only to find out that it will be about 2 weeks. But at least day by day we are making progress ans THAT is a GOOD thing.
#448 |
Sounds good John! Sucks on the backorder though. :(
#449 |
and MR. HYDE
Yeah and I could get pissed but what good would it do...I still have a few things that I can do while I am waiting......My hopes are that you can here it run when we got to the fest.
#450 |
and MR. HYDE
Hey Norm I sent you a Text of the motor last night...did you get it?
| Thread Tools | |
| Coming Soon: 2010 LED Sequential Taillights | BADMAB | Exterior Parts & Accessories | 665 | 09-14-2011 07:14 AM |
| New Aluminum and Carbon Fiber Driveshafts coming soon | GFORCE1320 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 12 | 06-10-2010 08:47 PM |
| Where we are coming from (check inside) | ljustin293 | 2010 Camaro5 Fest (I) | 106 | 05-12-2010 11:31 PM |
| SONAX is coming to SoCal! | SoCal Shop Guy | Wash/Wax/Detailing and Cosmetic Maintenance Parts | 1 | 12-07-2009 03:53 PM |
| GM Totally Rocks!! CTF Cars Coming to Eufaula Alabama this Monday!! | Scott@Bjorn3D | 5th Gen Camaro SS LS LT General Discussions | 56 | 04-20-2009 08:04 PM |
