BeckyD @ James Martin Chevy
Old 01-15-2011, 04:28 PM   #1
lightner75
LoneStar Camaro
lightner75's Avatar
Drives: 2010 cyber gray 2ss
Headers
Hello all,
I need help...I recently purchased some used headers for an awesome price..They are ceramic coated but,does have some pretty good scratches in them..I was going to have them powder coated but was told that would not hold up to the heat..Is this true and if so what could be some other oppositions that i could do? Any suggestions would be appreciated..
thanks...
lightner75 is offline   Reply With Quote
Old 01-15-2011, 07:40 PM   #2
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
Originally Posted by lightner75 View Post
Hello all,
thanks...
Powder coating and store bought 'rattle can' header paint burns off... If you like the ceramic coating, and if they are ceramic coated, you will need to get them stripped and re coated i.e Jet Hot coating is a company that does this - not cheap!.
Now, if they are steel headers they will eventually begin to rust and even the ceramic coating will flake off. If stainless steel, they will look pretty longer, but I hear and have no visual proof, that they too will flake over time.
I purchased ARH headers, still in the box and wrestle with what do I want. Pretty and reduced temperature or leave them alone. I have got more opinions to just install them, let them turn the 'brownish' color and move on.
By the way, the other part of this is if they do flake, as the insides are also normally coated, they can collect and clog the 'kittens'.
Lastly, the high temp cermaic coating also lowers the engine bay temp - very effective I hear.
Hence, now you know why my own decision is difficult to make.
ADIO SS is offline   Reply With Quote
Old 01-16-2011, 08:11 AM   #3
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
Coat them, you won't regret it.
OP, don't powder coat them, they won't hold up. If the scratches bother you have them recoated with a ceramic coating.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 01-16-2011, 11:03 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Post some pics of the scratches.
If they are already ceramic coated you might be able to use some green sctoch brite to kind of sand them down a little and then polish them. Depending on the scratches they may not complety come out be will probably get you close.
Otherwise re-coat them.....probably cost you around $300 give or take a little.
http://www.camaro5.com/forums/showthread.php?t=105219
Build Journal
Old 01-16-2011, 11:09 AM   #5
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
I have ceramic coated headers on my Trailblazer SS for four years now and no flaking. It is a daily driver as well. IMHO worth the money.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 01-16-2011, 11:14 AM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
coatings are worthless unless it's a car that suffers from IAT problems... which these do not unless you put some sort of forced induction under the hood
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 01-16-2011, 10:02 PM   #7
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
I have gone back and forth over this decision myself. If you have the inside scoop on this I would love to know more. Where did you get the info from.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
Old 01-16-2011, 10:31 PM   #8
danhr
BAMF SS
danhr's Avatar
only gain is that you can touch your headers 15 mins after your turn your car off.
No real performance gains unless you have a setup that is plagued with high IAT's.
I have had jet hot coatings and factory coatings from hooker and edelbrock..... they have flaked off.
Money is better spent elsewhere imo, because I have yet to see anyone post any gains besides them rambling on marketing gimmicks.
Old 01-16-2011, 11:22 PM   #9
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
No one ever said there were performance gains with ceramic coating...
Many people say it helps reduce engine bay heat, I have no proof of this. However, when I can touch mine 10 minutes after shutting my vehicle off, I would imagine it remains slightly cooler in bay as well.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 01-16-2011, 11:30 PM   #10
danhr
BAMF SS
danhr's Avatar
people like to run the phrase (not in this thread but it's a popular excuse)
"coated headers keep the engine bay cooler, so it has to give lower IAT's, which makes more power, because you are getting colder air"
Old 01-16-2011, 11:44 PM   #11
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
danhr is right... Its mainly for bragging rights and if you want it to stay looking good. All the claims of cooler temps and all that are just for marketing. If you want the best advice, ask the ones that have actually done the mods like danhr, SuperchargedSS, Speedster, ect..., and not the ones trying to sell you a product.
BlaSSt Off is offline   Reply With Quote
Old 01-17-2011, 12:14 AM   #12
caverman
caverman's Avatar
I had mine coated for cosmetic looks only. Not for any performance reasons.....but that's me.
Build Journal
Old 01-17-2011, 08:47 AM   #13
danhr
BAMF SS
danhr's Avatar
The best reason to do any mod.
Old 01-17-2011, 10:03 AM   #14
Sack Rat 2SS
Besides cooler engine bay temps you reduce the radiant heat from the driver side header onto the engine oil cooler and on passenger side away from the starter and wires even though this side has a heat shield from the factory. Just another 2 cents worth.
Silver 2SS/RS Man/6
GM 3.91 Rear Gears
Review / Installation of OBX Long-Tube Headers! Hicompression Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 215 04-25-2011 12:09 AM
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 04:51 PM
2010 Camaro American Racing Headers FREE Shipping MoranoRacing V8 Bolt-Ons & Tunes 2 02-10-2010 09:45 PM
Doug Thorley headers and axle-back ROCKS! SPANKT U Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 01-07-2010 11:36 AM
