Old 01-17-2011, 11:50 AM   #1
porankazi
Drives: 2011 Camaro RS Synergy Green
does the 2011 require radio or head unit unlock code if the battery is unpluged?
i know most 2000+ cars require a unlock code when you unplug the battery and replug it in. my dealer did not give me a code. so i was wondering if the new camaros require such code? thanks
porankazi is offline   Reply With Quote
Old 01-17-2011, 11:55 AM   #2
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
No,It goes by your VIN....
Theft Deterrent
The radio theft deterrent system is intended to disable or limit radio functionality if incorrect vehicle information is received by the radio. The radio disables functionality if the VIN information received by the radio does not match the VIN information that has been learned by the radio. The radio receives this information via serial data. A possible cause of incorrect VIN info could be the radio was originally installed in another vehicle.
The radio has the following theft operating modes as part of the theft deterrent system:
• Normal Mode: The radio has learned a correct VIN sequence and the VIN information received via serial data matches the learned VIN sequence. In this mode the radio has full functionality.
• No VIN Mode: The radio has not received or learned a correct VIN sequence. In this mode the radio has limited functionality.
• Theft Detected Mode: The radio has learned a correct VIN sequence and the VIN information received via serial data does NOT match the learned VIN sequence. In this mode the radio may be disabled or have limited functionality. The radio display will indicate that theft protection is active.
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 01-17-2011, 12:37 PM   #3
porankazi
Theft Deterrent
thanks
Old 03-31-2015, 01:38 AM   #4
camarodriver23
Drives: 2010 Camaro 2SS
How can you override the theft detection mode? I bought a factory 2010 camaro from ebay, installed it and the damn thing is locked.
camarodriver23 is offline   Reply With Quote
Old 03-31-2015, 08:49 PM   #5
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
dealer should be able to flash the radio
GVA 45TH 2SS is offline   Reply With Quote
Old 04-28-2016, 05:33 PM   #6
JJholmes7
Drives: Chevrolet Camaro
Hey did you ever get your radio problem solved?
JJholmes7 is offline   Reply With Quote
Push Start button? CG'sSS Camaro DIY & HOW-TO instructions & discussions 158 06-06-2012 08:27 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
Radio Head Unit Defect ravensjeff Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 4 08-22-2009 11:37 PM
Bad news for anyone thinking of installing an aftermarket head unit fastball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 26 05-26-2009 11:18 PM
