Old 01-17-2011, 07:16 PM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
After market cam with stock springs?
So I have pushing the idea around with an LS9 cam swap in my LS3, reason being is that it is in my price range! They work with stock tune and stock valve train parts! The problem I have with it, is that from I understand there is no lope So my question is... is there any aftermarket cams that are close in spec to the LS9 cam that I could use with my stock springs ect. That will give me some cam lope?
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-17-2011, 07:20 PM   #2
SC2150
Are you doing the labor yourself? If not, thats not alot to save for a minimal gain....to go with a cam that will make noticeable gains you will need to match springs to the lift. Do it right and you won't regret it.
Old 01-17-2011, 07:30 PM   #3
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
The LS9 cam does have some sound to it at idle. It definitely doesn't sound stock. Check out the GM "hot cam" with the narrow lsa and .525" lift (I think). It's not that high in lift but I'm pretty sure it will require a tune. If you're paying for the install go with a true aftermarket cam as the savings will be minimal.
Irnwkrkev is offline   Reply With Quote
Old 01-17-2011, 07:30 PM   #4
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I agree. The springs are easy to replace with the right tool.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 01-17-2011, 07:38 PM   #5
Bad70supreme
Money is an issue...I would be doing the labor myself, so this LS9 cam swap would be super cheap! I keep hearing this cam sounds stock, thats the only thing that I dont want! All I want is a little lope and it would be totally worth it, I want to do that cam with long tubes and 1 chamber flowmasters... hoping it will sound tuff, kinda old school! I know a bigger custom is the way to go, but I just dont have the funds for that, I could always do that in a few years.
Old 01-17-2011, 08:28 PM   #6
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
Why the LS9 cam? Are you going with a blower soon? If not, the GM hot cam should be in the same price range. Or save for a little while more and get a full kit with a bigger custom grind cam.
LGM G6X3 cam, LGM headers, Vararam intake, throttle body and intake ported by ADM Performance, 477 hp 454 ft-lb tq, tuned by PCMforLess
jamesc1123 is offline   Reply With Quote
Old 01-18-2011, 01:20 PM   #7
hoffmk2003
The Hof
hoffmk2003's Avatar
Drives: 2010 IOM Camaro 2SS/RS
why would you not want to do springs.......when you increase lift you need to increase spring pressure because you have changed the resonance points of the valve....in other words you could get valve float without a higher spring constant valve spring.....
It will hurt upper RPM performance of the engine.........thats why you do springs...
If you just want a little more power get 1.8 rocker arms and leave the cam alone.
If you just want sound I'll mail you my single letter mass air meter...it reads on the low range and makes my car sound like it has a little cam to it.
Ken
#6 Bolt on Fast List...best ET 12.01@117 mph
http://www.streetfire.net/video/best...ro_2240734.htm
hoffmk2003 is offline   Reply With Quote
Old 01-18-2011, 01:39 PM   #8
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
I am not going to even read the first post
the title says it all "aftermarket cam with stock springs"
the answer is no
no matter what, no
no no no no no no no no
again... no
just no
NO
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 01-18-2011, 01:55 PM   #9
1stTimeV8r
War Damn Eagle!!
1stTimeV8r's Avatar
Drives: VR 2SS
Agree with this on the LS9 cam...I've got one and it does sound a little different than stock at idle but no "Hot Rod" lope like what you're wanting.
VR 2SS RS M6
Hot Wife, 2.8 KB, LS9 Cam, SPEC 3+ clutch, KW Variant 1 Coilovers, Pfadt F/R Sways, BMR Sub-Frame Connectors, BMR Tunnel Brace, LSR Performance Tri-Ax Shifter, BMR Trailing Arms, Kooks 1 7/8" LT Headers, MagnaFlow 3" Cat-Back Exhaust, Fesler Dual Gauge Pod w/AutoMeter A/F & Boost, ShowStopper UnderHood Accessories.....Tuned by John@APF = 627RWHP/542RWTQ
1stTimeV8r is offline   Reply With Quote
Old 01-18-2011, 02:22 PM   #10
Bad70supreme
Like I said its a cost thing, the Ls9 cam works with a stock tune and stock parts and makes 20rwhp alone and with addition of headers... ADM made 430hp at the wheels! So for my free labor I think its a good upgrade, I dont need a leason as why you need to replace springs with a cam, its just a question. The Ls9 cam works with stock springs, so I figured there might be somthing out there that is simular that may have some lope. I have not found anything, so I think I might just do this Ls9 cam for now.
Old 01-18-2011, 03:43 PM   #11
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
After spending $38,000 for a car, saving $300 bucks on a cam swap and stock springs isnt what you want to do.
Do yourself a favor and take it from guys that have been around for a while, Spend $300 on a decent cam, $300 on dual springs, and $150 for harden push rods. Save your $10K motor not a couple hundred bucks. If money is an issue, the performance game is not for you.
If you want to save money, increase your insurance deductible.
Tampa Tuning is offline   Reply With Quote
Old 01-18-2011, 03:49 PM   #12
ffrcobra_65
I find this so logical and funny at the same time.
Old 01-18-2011, 05:56 PM   #13
Irnwkrkev
Irnwkrkev's Avatar
Adding 1.8 roller rockers is way more expensive than even an aftermarket cam and it is recomended to change springs with them. With higher ratio rockers you are increasing the ramp rate and adding lift which brings you closer to coil bind. The LS9 cam is a FACTORY CAM and has virtually the same lift as stock but with more duration. I have reved my LS3 with LS9 cam to 6,800rpm without valve float. With the wide lobe separation angle big int/exh split the power doesn't drop off rapidly either. 20hp for less then $200 is a bargain. Now if you have to farm it out forget it. Spend the $600+ and go with an aftermarket cam because you'll be spending more then that on labor. I'm pretty sure the GM "hot cam" with .525" lift will work fine with the stock springs but with such a tight lobe separation angle it will most definitely require a tune.
Old 01-18-2011, 07:58 PM   #14
Bad70supreme
What do you mean save my 10K motor, the LS9 cam is a stock GM cam, how in the hell would that ruin my engine! I have been around cars for a long time, and I know big cams need matching springs! Thats not what my question was guys If I buy a aftermarket cam setup your talking ALOT MORE MONEY! Not to mention more money on a tune, and I dont want a tune yet! This cam works with stock tune and headers, ADM has already done this and sells this setup. The cam swap would be done by me, so its only a 200$ job for 20rwhp, why would you not do it!! You would rather spend $400 on a cold air...not me! That cam and long tubes will make some nice power and I will have money to spend on other areas of the car. Like make traction to put down the power!
Removing Centering Springs from Stock V6 Manual Shifter autobotaz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 04-19-2014 07:46 PM
ARH Headers & MTI Cam using stock mufflers (LS3) - Help! TinyToasta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-19-2010 03:11 PM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 11:32 AM
Phastek 1.5"/1.4" Drop Springs in stock Sean@Phastek Suspension / Chassis / Brakes 1 05-27-2010 12:22 PM
Pfadt Springs and Sway Bars In Stock! *Package Deal*! PfadtRacing Suspension / Chassis / Brakes 0 10-14-2009 06:41 PM
