Emblempros
Old 01-20-2011, 09:36 AM   #15
zr1gary
"Ad eundum quo nemo ante"
zr1gary's Avatar
Drives: 2010 SS2, Black/Black
One reason I went with Whipple too
Originally Posted by Z_Rocks View Post
If God asked you which one do you want as Lotto wining, a $2.3M or $2.9M, which one would you select?
zr1gary is offline   Reply With Quote
Old 01-20-2011, 09:50 AM   #16
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
Originally Posted by calbert1999 View Post
Why a Whipple and not a Magnuson or ProCharger.
Won't be whipping up anything in my SS anytime soon. I'll leave that for the stanger' dudes. LOL
94guy is offline   Reply With Quote
Old 01-20-2011, 09:56 AM   #17
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
A few reasons! First, the customer requested it which is one quite important reason. The Whipple is also 2.9L vs. 2.3L for the Magnusson, and more street friendly compared to the Procharger. The Procharger is an awesome system and makes sick power, but the torque down low that you get with a positive displacement blower is just insane. The customer never races the car and it is pure street car and he really likes this style blower.
We have installed them all, Whipple, Magnusson, Vortech, Kenne Bell etc and each one has it's benefits! We will be doing another Whipple next week and after that a 2.8L Liquid Cooled Kenne Bell with a cam is on the schedule!
Thanks guys, we are also very happy with the outcome!
/Erik
Erik@Torq is offline   Reply With Quote
Old 01-20-2011, 09:56 AM   #18
Erik@Torq
Erik@Torq's Avatar
Haha that's funny
Old 01-20-2011, 08:43 PM   #19
blufin
blufin's Avatar
Drives: Fire Engine
Great build guys. Very impressive.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 01-20-2011, 09:54 PM   #20
03ss
Drives: 03' Silverado SS/ TBSS 06'
Pictures Look great! I also like the rear black out panel. So what is the Peak boost you see with the Whipple? Curious how the long tubes and big 3 inch exhaust affected the boost. What power it put down with the Whipple tune?
03' Silverado SS
03ss is offline   Reply With Quote
Old 01-21-2011, 11:30 AM   #21
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
We have done a lot of Maggy setups and wanted to try the whipple as we use them almost exclusively on our Ford builds. Amazing quality, amazing fit and finish including hoses, fittings, etc are top notch. It is a bigger, more efficient blower.
Why we did not go with a Centrifugal blower - Simple. A roots/twin screw is way more fun for a street car.
Meister@Torq is offline   Reply With Quote
Old 01-21-2011, 11:34 AM   #22
Meister@Torq
Peak boost we saw, with the cut airbox (per Whipple's instructions) was a tick under 9psi. We typically do not see much of a pressure drop with the 1 7/8" headers and 3" exhaust.
Torq Dyno Results with Whipple Tune:
VEHICLE: 2010 6.2L
Manual Boost PSI: 8.7psi
Average AF: 11.9:1
RPM Limit: Stock
Exhaust: Kooks 1 7/8" Long Tubes w/ Catted X and MBRP Catback
Fuel: 93 octane
Temperature: 76.31° F
Barometric PSI: 29.98 In-Hg
Humidity: 45%
Hood: Open
SC RW SAE HP: 531
SC RW SAE TRQ: 487
Stock RW SAE HP: 355
Stock RW SAE TRQ: 342
We test every product we sell and provide our honest feedback. After installing Whipple's 2.9L supercharger on our customers 2010 Camaro SS with Whipple's tune we picked up a fantastic 177RWHP and 145RWTQ but were concerned with the amount of Knock Retard we were seeing both on the street and in our controlled dyno room.
We reset the ECM back to a factory stock calibration and began the calibration process. The final results with less timing and zero KR and a safer air fuel ratio were amazing. We picked up an additional 45RWHP and 23RWTQ! In addition to the WOT power and torque increases our tune provides additional throttle response and improved fuel economy and drive-ability.
Old 01-21-2011, 01:13 PM   #23
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Hahaha..... that's obvious, but 2.3 or 2.9 get a different pulley or cog unit to produce more boost depending on your application. So, a 2.3 maggie or any procharger would have most likely been adequate.
For example to produce the numbers on this setup, they used almost 9psi., there are numerous setups using 6psi. with a ProCharger and getting same results.
So, if we were talking $, I'd say 2.9, but we're talking SC's so 2.3 or 2.9 probably not making much of a difference unless you engine has been heavily modified, and in that case you'd probably want a ProCharger F-1 or higher.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 01-21-2011, 01:28 PM   #24
calbert1999
Camaro SS Lover
/Erik
That's what I'm planning as well (SC with my blower cam) but I'm leaning towards the ProCharger D-1SC, I've seen a HO P-1 system, with stock fuel pump making 640rwhp / 450 - 560rwtq on 6psi., and a custom tune.
Old 01-21-2011, 05:11 PM   #25
Meister@Torq
We compared a Maggy at the same boost level and same exhaust and the Whipple made about 27rwhp more with cooler IAT's.
Old 01-21-2011, 05:14 PM   #26
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Were both tuned, or using canned tunes, and did one run with the OEM airbox or otherwise?
Thanks
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 01-21-2011, 05:29 PM   #27
Meister@Torq
A couple of things to consider:
1. Our Mustang Dyno reads lower than what most are showing, which is on a dynojet. We know 575rwhp on our machine is 610rwhp on a dynojet.
2. We just finished a Maggy at 8.5psi with our blower cam and it made 610rwhp/540rwtq. On a dynojet this would be about 630-640rwhp and like 570rwtq.
3. Stock fuel pump is good to about 560rwhp on a Mustang Dyno. Fuel pressure will start to drop hard making AFR uncontrollable not allowing a tuner to hit target afr
4. A Maggy/Whipple will make way more power and torque under the curve so if there is traction that car will be faster. It is quite simple. A car that accelerates faster will be faster
Look at the graph below 4500. Above 4500 the procharger fell on it's face because it was 130F in the shop and IAT's were through the roof on the procharger setup
Old 01-21-2011, 07:06 PM   #28
Meister@Torq
Thanks
Both were custom tuned on our dyno. The maggy had a K&N and the procharger had the procharger inlet.
The reason I mentioned do not look above 4500 is that the spark really started to drop off on the procharger car with the super high temps.
2010, 2ss, camaro, torq, whipple
Nitrous info CamaroSpike23 Forced Induction - V8 63 06-20-2017 11:15 AM
BIG RED - The WORLDS BADDEST CAMARO and its '69 Z/28 non the less (True Story) NOODLESgoneWILD 1st & 2nd Generation Camaros 12 10-01-2014 10:15 AM
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
Nitrous Info Milk 1027 Wiki 0 08-12-2009 07:26 PM
