Old 01-17-2011, 11:30 PM   #1
ronniels3
Drives: 2010 Camaro SS/RS
Quietest and Simplest Headers
I am looking to get a little more performance out of my new SS. However I do not want it to be that loud. I will use the stock mufflers. Which company makes the quietest headers? I also want to use as much of the factory exhaust as possible. Companies that appealed to me were Stainless Works, Borla, and B and B. I do not want to change all the pipes back to the mufflers at this time so I am not interested in ARH or Kooks.
Thank You
ronniels3 is offline   Reply With Quote
Old 01-17-2011, 11:34 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Just to let you know....almost every major header Mfg (including ARH and KOOKS) sell just the headers and connection pipes to hook up to your stock exhaust system. They are also going to be about the same loudness no matter what the brand is you get.
If you just want a little more performance without all the money you could go with a High Flow cat setup from JBA or SOLO. Won't be as good as long tubes and will be about the same in the loudness category.
Build Journal
Old 01-17-2011, 11:50 PM   #3
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
"Quietest and Simplest Headers"
No such thing
Old 01-18-2011, 12:10 PM   #4
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Get a set of Kooks or ARH headers with catted connection pipes. Use the factory cat back exhaust and you are all set. Anything else is not worth the time/money/effort IMO.
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 01-18-2011, 12:13 PM   #5
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
Got stainless works. They sound awsome and very nice quality. Talk to Apex motorsports.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 01-18-2011, 12:42 PM   #6
SS 376
SS 376's Avatar
Drives: IBM 1SS
No such thing
This is correct. There is no meaningful difference in volume between brands. Just make sure to use high flow cats rather than straight pipes.
SS 376 is offline   Reply With Quote
Old 01-18-2011, 01:16 PM   #7
ronniels3
Are the headers louder without the cats? Im in Florida and there are no emmisions here so I can get away witout them but being to loud is my main concern. I had a vette with 1 7/8" ARH with cats with Corsa Indies and it was F*ckin loud.
Old 01-18-2011, 01:18 PM   #8
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
No cats would be louder.
If you want to keep noise down, get shorties, keep your stock cats, resonators, and mufflers, and call it a day.
The "Quietest" (kind of an oxymoron) LT headers set up would be Long tubes with high flow cats, resonators and stock mufflers.
Just pick the one that sounds the best to you.
Old 01-18-2011, 01:20 PM   #9
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Garnet red 2016 Camaro 2SS
Without cats, your ECU will throw codes and would require you to tune the sensors out. Unless you can live with constant engine management warnings, install HF cats. My opinion.
2016 Camaro 2SS, Garnet Red Metalic, 8A, NPP, Nav, Sun Roof, upgraded silver wheels, lit door sills, Ash gray interior.
Previous Performance Cars:
1966 Chevelle SS 4M 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto
2002 C5 Corvette 6M
2006 Corvette Auto
ParisTNDude is offline   Reply With Quote
Old 01-18-2011, 01:20 PM   #10
ronniels3
I see that stainless works sells this setup and it is fairly cheap. What are the prices to go this route with Kook's or ARH? I want an American made header.
Old 01-18-2011, 01:47 PM   #11
Wilburbeest
Think With Your Dipstick!
Wilburbeest's Avatar
Drives: 1997 Camaro Z28
Loud is pretty subjective. I thought my 4th gen was quiet with the Flowmaster it came with when I got it, but most begged to differ. Considering the 5th gen is dead quiet stock, you would probably still be pretty quiet if you were to do LTs, high flow cats, and keep the stock gas can mufflers/resonators. Once you get the stock cats removed or replaced the stock exhaust actually flows pretty good apparently. Even with high flow cats though a tune is still a good idea with LTs.
- Willy
1997 Camaro Z28 (LT1/T56): K&N CAI | Kooks 1 3/4" LTs | 3" Custom Duals | UMI LCAs w/ relocation brackets | UMI adj. panhard bar | UMI adj. torque arm | Koni SA shocks | Strano Springs | Ram Powergrip clutch | Pro 5.0 shifter | skip shift eliminator kit | WS6 Store rotors | Hawk HPS pads
Wilburbeest is offline   Reply With Quote
Old 01-18-2011, 02:01 PM   #12
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
It is all personal pref...I personally can't stand LTs without Cats. I think it is stupid loud and sometimes a lil stanky.
There is a huge difference between too loud and versus having a great tone. With that said, I agree with the posters that told you to go Hi-flows first. It will save you a TON of money as opposed you dropping cash on LTs (approximately $1,000 for a decent set) and then you hate the sound. At least with hi flows you can always move up to LTs if it still too quiet.
2011 2SS/RS
Performance: 439 RWHP A6: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, FTI Converter, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
Appearance:Smoked side markers and black bowties. Blk / Blue Carbon Fiber interior trim.
Next in order: F14s, 3.70 gears, DSS Axles, End links/Toe rods/trailing arms, Ported heads, S/C.
1100 7/02 Ordered
3800 8/09 Order produced
4200 8/13 Shipped
6000 8/24 HOME!
brantley847 is offline   Reply With Quote
Old 01-18-2011, 04:53 PM   #13
2010 4 DW
Drives: White 2010 RS/SS
Shorties would be exactly what you have asked for.
DW
2010 4 DW is offline   Reply With Quote
Old 01-18-2011, 07:17 PM   #14
AFblueSS
U.S.A.F. Retired
AFblueSS's Avatar
Drives: Imperial Blue 2010 Camaro 1SS / 6MT
Send a message via Yahoo to AFblueSS
Stanky
Current Mods: Muffler delete (straight pipes with stock tips), K&N Panel Filter, light blue pin stripes around Silver OEM Rally Stripes.
AFblueSS is offline   Reply With Quote
