Old 01-18-2011, 10:30 AM   #1
mantoneshyn
Drives: 2010 Camaro SS
no cats?
If im to remove the cats out of my exhaust, will the car throw and engine code? Am I going to have to drive around with my engine light on all the time?
2010 Camaro SS, TVS2300 supercharger with 3.4" pulley, 60# injectors, CAI, Fesler dual gauge pod, Autometer Cobalt fuel pressure & boost gauges, Magnaflow cat back exhaust, ADM dual fuel pumps, Stainless Works long tube headers w/high flow cats, ADM stage 2 Blower Cam, 1400hp axles, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, Pfadt trailing arms, Hurst short throw shifter, Forgestar F14 Piano Black wheels w/Hugger Orange pin stripe, Nitto NT05 rubber, JL Audio stealth box with 3 JL Audio W3 subs.
mantoneshyn is offline   Reply With Quote
Old 01-18-2011, 10:34 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
I think if you have a tune you probably won't because the tuner should have taken out that CEL message.
The question is though....why would you?
In your sig you show that you already have KOOKS with HF cats. If I remember correctly Janetty did a test with and without HF cats and there was basically no change at all. You might do some searching before you just pull them off.
Build Journal
Old 01-18-2011, 10:46 AM   #3
mantoneshyn
Ya, it was just a thought. I wasnt sure if they would make much of a difference or not.
Old 01-18-2011, 12:00 PM   #4
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
Yeah, I remember reading where there isn't really any difference in high flow cats and no cats. I'm sure it would throw a code if not tuned.
first one is offline   Reply With Quote
Old 01-18-2011, 12:20 PM   #5
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
The cats that come with most of the commom brand are light years ahead of the factor cats. Also on my first vette I ran cattless and it was impossible to drive with the top off or windows down without smelling like raw unburned fuel.
Snake Slayer is offline   Reply With Quote
Old 01-18-2011, 01:14 PM   #6
hoffmk2003
The Hof
hoffmk2003's Avatar
Drives: 2010 IOM Camaro 2SS/RS
I like that smell......
#6 Bolt on Fast List...best ET 12.01@117 mph
http://www.streetfire.net/video/best...ro_2240734.htm
hoffmk2003 is offline   Reply With Quote
Old 01-18-2011, 03:28 PM   #7
Synyster
Synyster's Avatar
Drives: 2006 F150 Lariat
Synyster is offline   Reply With Quote
Solo Performance LS3 and L99 High Flow Cats GOINGSOLO2 V8 Bolt-Ons & Tunes 169 04-20-2015 07:15 PM
Dynojet results for intake, headers, exhaust with SOLO hiflow cats! topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 07-02-2010 07:52 AM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
Ohhhhh C-A-T-S Cats Cats Cats!!!!! acscamarochick06 Off-topic Discussions 1 01-14-2008 03:57 PM
