Gen5DIY
Old 01-18-2011, 04:21 PM   #1
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
ECS Big Blower Cam installed - full how-to write-up coming
I started my cam swap project in the garage a couple of weeks ago, took my time doing a little bit at a time and finally finished it up yesterday. I took pictures and documented the entire process and have about 80 or so pictures to post in a how-to thread I'll be doing hopefully by the end of this week.
The cam is East Coast Supercharging's Big Blower Cam (www.eastcoastsupercharging.com), its specs are listed as duration in the 220's and lift in the 580's, the cam gets a ton of great feedback in the vette forums as a lot of guys are using it in the LS3's over there. The exact specs they keep close to their chest as they have done a lot of internal development on the cam
I went with the blower cam because I will eventually be putting ECS's Paxton Centri Blower kit on the car and it supposedly has a little better drivability with not as much overlap as the cams they use in the N/A setups. From the dyno sheets I have seen from ECS the big blower cam in a car with a CAI and Long Tubes usually lands in the 460RWHP range on LS3's and I am running a RotoFab CAI and Kooks 1 7/8" Long Tubes so I would expect to be right around there as well and am getting 404RWHP and 428RWTQ with my current setup. I am just waiting on my VMax ported throttle body and NOWEEDS Exhaust Diverters to show up and then I will head down to ECS to get the car tuned.
In the meantime, here is a video of the first turn of the key after everything was buttoned back up and then a warm start and idle to show it has a little lope to it.
Edit: Here is the DIY LS3 Cam Swap Post
Another Edit: Full Cam Results Posted
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
Last edited by robertway; 02-11-2011 at 11:25 PM. Reason: Added link for DIY cam swap thread
robertway is offline   Reply With Quote
Old 01-18-2011, 05:48 PM   #2
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
Finally an LS3 write up!
Sounds good man!
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline   Reply With Quote
Old 01-18-2011, 07:49 PM   #3
Slowhawk
Drives: 1999 Trans Am
Very nice. They ussually sell the 224/230 on 115 Cams for the blower cars.With there blower you can make 650rwhp easilly enough.
Slowhawk is offline   Reply With Quote
Old 01-18-2011, 10:00 PM   #4
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Sounds good, can't wait for the write-up.
1977and2010 is offline   Reply With Quote
Old 01-18-2011, 10:17 PM   #5
afireinside
Firefighter/Medic
Drives: 2010 Camaro 1SS LS3 IOM, 2008 Z71
ditto
Mods: LSR Sway Bars, LSR Short throw shifter, MPD1 spoiler, Heritage Grille, 5% Limo tint
afireinside is offline   Reply With Quote
Old 01-19-2011, 03:53 PM   #6
East Coast Supercharging's Avatar
Drives: 8 second C5 Drag Car, C6 Road racer
Good luck on your swap!!
East Coast Supercharging is offline   Reply With Quote
Old 01-19-2011, 05:21 PM   #7
robertway
robertway's Avatar
Thanks guys, the swap is all done, just waiting on a couple other things to show up and then I can give you guys a call to schedule having it tuned by Doug....
Old 01-19-2011, 07:31 PM   #8
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
Also waiting for the write-up!
The car sounds fantastic...I guess I need to add another cam to the potential list.
Kilo-9 is offline   Reply With Quote
Old 01-19-2011, 10:12 PM   #9
robertway
robertway's Avatar
Thanks... I am about 3/4 of the way done with the write-up, should have it posted tomorrow in the DIY section but I will post a link to it in here as well.
Old 01-20-2011, 10:15 AM   #10
Stark
Stark's Avatar
Drives: fair to good
Sounds GREAT !!!
Stark is offline   Reply With Quote
Old 01-20-2011, 12:46 PM   #11
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Aren't you spending enough money my friend?
BTW robertway,car sounds great
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 01-20-2011, 03:47 PM   #12
robertway
robertway's Avatar
LS3 Camshaft install is now posted in the DIY Section;
http://www.camaro5.com/forums/showthread.php?t=125123
Old 01-20-2011, 08:35 PM   #13
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
I don't know what you're talking about...as far as my wife knows, I've spent very little.
:emoticon7:
Old 01-21-2011, 12:43 AM   #14
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
next time (when you finish your mods) open those noweeds during the video... i bet that is going to be nasty.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
BIG RED - The WORLDS BADDEST CAMARO and its '69 Z/28 non the less (True Story) NOODLESgoneWILD 1st & 2nd Generation Camaros 12 10-01-2014 10:15 AM
Camaro Brembo Big Brake Kit, Installed!! SS Mike Suspension / Brakes / Chassis 125 09-09-2010 01:34 PM
Okay FI crowd...convince me to drop a blower on my car instead of a cam..... Huggerorange73 Forced Induction - V8 30 06-20-2010 04:51 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 04:09 PM
