JUICEDMOTORSPORTS
Old 01-19-2011, 01:12 AM   #1
ewoolsey
Drives: Victory Red 2011 Camaro SS/RS
What is the difference between the Vararam tune and no-tune otr intakes?
I was Just curious. I am planning on ordering the vararam but I want to get the right one
ewoolsey is offline   Reply With Quote
Old 01-19-2011, 08:19 AM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
No-tune has a MAF screen to help the MAF sensor read closer to what it would in the stock airbox. Also the shape of the opening is more of an oval on the no-tune. Again for the same reason.
If you are going to tune your car right away, then the tune version has more HP potential. If you are not going to tune right away, or not at all, then the No-Tune is the one to choose. fwiw, only the tail section of the two versions are different. If you go with the No-Tune and later decide you want to tune, you can order just the one piece and convert it over.
Even though MarylandSpeed has the best pricing, go over to vararam.com and read the Air Meter write-up. You will want to check the coding on your air meter or MAF sensor first. Takes 5 minutes, unless you drop a screw.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-19-2011, 08:41 AM   #3
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
Indeed, do you have to check the MAF if you are going to purchase the tune model?
I only plan on doing LTs, cats, and exhaust but I will be tuning those once installed. Am I better off just buying the tune model then? I was reading up on maryland's site and there does some to be more HP potential but vararam's site states the no tune goes well with the same bolt ons I wanted to do.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 01-19-2011, 09:53 AM   #4
IndeedSS1
IndeedSS1's Avatar
I believe a tuner can tune around the lazy MAF. Me I would want the better one no matter. Honestly I would call VaraRam and let them know what you are wanting to do.. They are really nice people and should be able to steer you in the right direction. For me it was No-Tune or nothing.
Old 01-19-2011, 12:39 PM   #5
sales@vararam.com
sales@vararam.com's Avatar
Drives: 2010 camaro
Call us and talk to Patrick and he can set you on the right course!!!! 866-507-2648
Thanks
Steve
Vararam Industries
sales@vararam.com is offline   Reply With Quote
Old 01-19-2011, 03:36 PM   #6
ewoolsey
thank you for the fast replies! also I was wondering if i could drive my car with the tune model installed for a few months before i brought it to the dyno or would it be hard on the engine?
Old 01-19-2011, 03:52 PM   #7
IndeedSS1
IndeedSS1's Avatar
Probably will have idle issues along with surging and bucking. But best to talk directly to them.
Old 01-19-2011, 04:24 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Yeah...when I talked to them I think that was pretty much a NO. You could probably drive from your house to the shop if you don't live that far but other than that you probably shouldn't.
I would just wait it out and do it with the tune....or just go No Tune version.
I don't think there is like a 10 - 20 hp difference between the two. Actually if I remember from talking with them, until you get to where you add a cam and stuff you probably won't see much of a difference. The No Tune was setup to include cars with the intake, headers, and exhaust.
Build Journal
Old 01-19-2011, 06:41 PM   #9
ewoolsey
Thank you so much. I think I am probably going to buy the no-tune model. I dont see enough of a benefit to spend 650 on a dyno tune for 5 extra horses. I plan on eventually doing a dyno tune but it's not worth it until I install some more hardware.
