Flowmaster Exhaust
Old 01-19-2011, 11:45 AM   #1
TooCool5
TooCool5's Avatar
Engine Misfire when cold, Check Engine Light
OK so its about 10 degree's out and I start my Camaro to warm and charge it up and my LLT V6 engine is jumping really bad. Couldn't be good for the timing chain.
Then the idle comes down, engine smoothed out and I get the MIL lit up.
I remember there was a service bulletin for this (P10284) and I set DTC P0306 cylinder 6 misfire.
Forecast is for daytime highs only in the 20's.
No big deal, its off to the dealer for a re-flash of the ECU computer.
I'll have to wait for the roads to dry out and the salt to dust off them though.
Here are some pics.
Old 01-20-2011, 09:22 AM   #2
larryt1026
larryt1026's Avatar
Drives: 2011 Camaro LT
Oh man..hope your car gets fixed up soon. How did you hook up your laptop to the car like that? What would you need to run something like that?
larryt1026 is offline   Reply With Quote
Old 01-20-2011, 11:51 AM   #3
TooCool5
TooCool5's Avatar
You can hook your laptop up by getting a USB diagnostic cable, and it comes with the software to read multiple vehicle OBDII platforms.
Old 01-23-2011, 05:23 PM   #4
TooCool5
TooCool5's Avatar
The roads finally dried up, bringing my Camaro in tomorrow for the re-flash.
Update:
May have not been a problem after all. I put dry gas in the car as it is below
zero out.
Car started and ran smooth as a button in the bitter cold. So I asked the Dealer
if I have you re-flash the computer could it effect gas mileage? Service manager said
it could as they probably enriched the mixture in the new program.
So I decided to ask my Camaro5 friends who had the re-flash done.
Can anyone chime in, has it effected mileage, any other changes you have noticed?
Old 03-26-2011, 11:01 AM   #5
vinman
The BBOMG fill-in husband
vinman's Avatar
How much, where did you get it, does it void the warranty?
UPSTATE C5 MEMBER
Old 03-26-2011, 11:11 AM   #6
TooCool5
TooCool5's Avatar
Got it on Ebay for under $20.
I don't use it to change anything or delete codes, just read them.
Check with the dealer on the warranty question, when I brought it in they read the same codes and cleared them for me with no issues.
Old 03-26-2011, 08:04 PM   #7
transamguy
Drives: 10 camaro LT(syn)
the check engine light is a common problem for V6's in the cold i had the issue about 6 times over the winter GM has no fix for it so far
transamguy is offline   Reply With Quote
Old 03-27-2011, 02:02 PM   #8
TooCool5
TooCool5's Avatar
There is a fix......
Old 03-27-2011, 04:15 PM   #9
transamguy
i did read the thread the dealer had reflashed mine way back in december, the problem came back and so far there is no fix yet from gm canada the problem occurs with all of the 3.6L v6s so it is being adressed my car however did not experience any signs of a miss fire no jumping around as you put it, i think we may have had two seperate problems
Old 03-28-2011, 01:18 PM   #10
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
I hate to hijack the thread but could you link me to the exact OBDII item you bought on EBAY please? I'd love to have one of these handy.
Thanks.
TheHorse13 is offline   Reply With Quote
Old 03-29-2011, 11:17 AM   #11
TooCool5
TooCool5's Avatar
I think I had water in the gas or a valve hanging up in #6, but the dealer found 5 or 6 codes set when they scanned it.
http://www.camaro5.com/forums/showthread.php?t=136285
Thanks.
Here is a link, just make sure it is compatible with your PC operating system.
http://cgi.ebay.com/OBDII-OBD-II-2-O...item5643528484
Old 03-29-2011, 01:58 PM   #12
TheHorse13
TheHorse13's Avatar
Thanks for this!
Old 03-29-2011, 06:52 PM   #13
jls
jls's Avatar
Drives: 2016 1SS
Back in Feb. on a cold -11 day car shook like crazy on start up, shut down and restarted it was ok except check engine light. multiple codes p1380 (miss fire detected , rough road data not aviable)po300 to po600 (missfire detected all 6 cylinders) GM addressed this concern with document #2542524- updated calibration is aviable for the engine controle module. The ecm was reprogramed nd I have not had that condition since. Hope this was helpful.
jls is offline   Reply With Quote
Old 03-29-2011, 08:03 PM   #14
Merk247
Merk247's Avatar
Drives: 2003 Subaru wrx
i believe and as far as i can diag most often this issue is a result of a fuel blend mismatch/poor fuel. winter blend fuels have a composition to better burn in colder temps so poor gas quality or not as many agents in the fuel causes poor ignition of the fuel and misfires. your gas mileage shouldnt drop as warm up open loop fueling differs form while your driving plus summer blend fuels should be coming out which allow better mileage..
ASE MASTER TECH
GM TECH
DRIVETRAIN/DIESEL SPECIALIST
Merk247 is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
Check Engine Light... Missionboi Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 01-08-2011 02:02 AM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
help can't get my check engine light off? race87 3rd Generation Camaros 9 05-08-2009 10:32 PM
