Jason 98 TA
Old 01-19-2011, 04:44 PM   #1
SS-Rider
Drives: 2010 Camaro SS 2SS RS Black
Flowmaster AMT Catback inlet size?
Does anybody know the inlet size for the Flowmaster AMT catback? I hate the tips for the ground effects and want to change it to the SLP square tips. I assume its a 3".
SS-Rider is offline   Reply With Quote
Old 01-19-2011, 04:50 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Should be 2.5" inlet in order to hook up to the factory mid-pipes. However...the overall cat-back is a 3" I believe so if your asking the inlet on the tips it should be 3".
Build Journal
Old 01-19-2011, 04:53 PM   #3
IROCanSS
Drives: 89 IROC 350
You dont want to know the inlet size... you want the outlet size but whatever...
The inlet (at the cats) is 2.5" for about 6" then flares out to 3" and is 3" all the way back and in and out of the mufflers then flares out again to 4" at the tips for the NON gfx kit. So your answer is 3". I think the gfx kit is just 3" without the 4" flare and chrome tip. If you have the GFX kit from Flowmaster you want a 3" tip. You may have to weld it on if the tip is 3" OD. You'd need 3" ID.
I just went out and looked
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 561 04-11-2018 12:05 AM
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 257 03-27-2018 01:52 PM
My Flowmaster catback review. CDN SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 09-11-2010 02:49 PM
Are Flowmaster exhaust available yet? quanine10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 115 04-11-2010 05:19 PM
FLOWMASTER Releases Stainless Steel Catback For GM Body Kit Jason@Phastek Performance Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 11-24-2009 10:40 AM
