sjm autoprod
Old 01-20-2011, 07:57 PM   #1
garygerlach
Drives: 2011 camero 2ss with rs pagk
95 Camaro knocking noise
I replaced opti- spark and when doing so I forgot to note position of balancer.Could this have something to do with it, I dont notice any unbalance in the motor. I set no. 1 cyl. ,TDC,compression stroke and installed balancer with arrow pointing up.
garygerlach is offline   Reply With Quote
Old 01-21-2011, 04:33 PM   #2
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Way over my head man, you got me
Old 01-21-2011, 08:21 PM   #3
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
I'd consult a shop manual to see if it says anything about positioning of the balancer prior to removal of the distributor. You just don't go setting #1 to TDC and just chuck the coil back on. Did you pull all the plugs and note the position of the cylinders in reference to firing order?
Could be that you also have a misfire in there..
Zabo is offline   Reply With Quote
Old 01-21-2011, 08:59 PM   #4
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Did you make sure the optispark was aligned properly when you installed it? Sounds like your rotor is potentially out of timing.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 01-24-2011, 11:40 AM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
- X
unless he damaged the opti or the cam dowel, you can't incorrectly install the opti.
I piss excellence
and fart awesomeness
Old 01-24-2011, 01:22 PM   #6
garygerlach
95 camaro knocking noise
I disagree , on later 95 opti-spark with vent you can't make a mistake on timing, as the cam is doweled and it will only go in flush one way.WHAT was in question was the position of the balancer which has an arrow on it,to the crankshaft (HUB),two parts,which the hub has three ears and the balancer itself can be put on in many positions maybe causing a inbalance. This car idles and performs like factory new as the car also looks.Just this winter it had to sit outside in the cold and is my everyday driver now,hate that but collecting to many car, 2011 Camaro in garage now.Still hear that noise, some say its normal in extreme cold and call it piston slap on 5.7 LT1's. Ever heard this? I always thought these 95 5.7 were LT1'S. WHAT year and cars were these LS1'S andLT1'S in?
Old 01-24-2011, 01:44 PM   #7
CamaroSpike23
Truth Enforcer
LS1s were/are well known for piston slap, LT1s on the other hand aren't.
most likely your knocking is probably lifter tapping given the cold weather. what grade oil are you running? when was the last oil change?
oh, also
this:
is correct. arrow pointing up with #1 on TDC compression
I piss excellence
Old 01-24-2011, 02:28 PM   #8
garygerlach
95 Camero
Doesn't go many miles, just enough to warm it up,to and from most of its life.I know this isn't good but thats the way its life has always been. Change oil couple times a year not because of miles but to keep it from turning to a slug motor, was always using Castrol 5w-30, After I kept hearing this in the morning I just changed it again using 10w-30. Dont think this was right thing to do as its cold out but was a little quiter in morning. Sometimes it does it more than others. Dont remember this motor ever making such noise, but than it was newer and garaged.It now has 83,000
Old 01-24-2011, 02:50 PM   #9
CamaroSpike23
Truth Enforcer
how warm is "warming it up"? up to full operating temperature? how long of a drive to warm it up? or do you just do it in the garage? jw.
I piss excellence
Old 01-24-2011, 03:05 PM   #10
garygerlach
95 Camaro 5.7
I always start it and let run for at ten minutes in this weather, enough for it to defrost itself.Its driven then about 4to 5 miles to work, sits all day, and home again. Driven all weekend around town and gets good and warm. Temp always runs 180 never gets real hot even out of defrost , not like some everyday drivers,if you know what I mean.
Old 01-24-2011, 03:19 PM   #11
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
what's oil pressure and what does the oil look like?
lt1's are only 2 bolt mains.... they are known to spin main bearings and cam bearings
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 01-24-2011, 03:30 PM   #12
garygerlach
95 Camaro 5.7
oil pressure around 30 oil ,oil looks ok, I mean between oil changes I can't complain 83,000 and original injectors. Car still performs , no hesitations
Old 01-24-2011, 03:44 PM   #13
garygerlach
I guess I'll wait till warm weather and check those lifters since your info says this 5.7LT1is not suppose to have piston slap
Old 01-25-2011, 10:56 PM   #14
Xanthos
PWA Relapse
Xanthos's Avatar
Sorry. I was thinking of my 93. Forgot 95 was the change year.
- X
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
