BeckyD @ James Martin Chevy
Old 01-23-2011, 07:37 PM   #1
Bill 1ss/rs m6
Drives: 1ss/rs ls3
What size mufflers?
Thinking about buying mufflers for the beast instead of just the muffler delete. What size inlet/outlet? Not sure if it's 2.5 or 3 inches? Also thinking of taking out the resonator as well. Thoughts?
Bill 1ss/rs m6 is offline   Reply With Quote
Old 01-23-2011, 08:18 PM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
just buy a axle back
Old 01-23-2011, 08:23 PM   #3
Bill 1ss/rs m6
Drives: 1ss/rs ls3
I'm not going that route because I think they cost way to much money. I can buy a couple of mufflers, go to the local muffler shop and spend a couple hundred vs a thousand or so.
Old 01-23-2011, 08:36 PM   #4
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
They are 2.5" in and 2.5" out to the tips.
But what is your goal? Do you want to keep it quieter than the muffler delete? Then it doesn't really make sense to take out just the resonators as it will most likely just add some drone. If you want some better flow then you should take out the entire H-pipe and replace it with an X-pipe. Also, Maryland Speed has some pretty good deals on axlebacks.
MileMAN402 is offline   Reply With Quote
Old 01-23-2011, 08:44 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You can get a good axle back for not a whole lot more than a set of quality universal mufflers and the muffler shop labor. While cat backs do often run in the $1000 neighborhood even brand name axle backs can be had for closer to half that.
To answer your question you will want 2.5 inch inlet and outlet.
Old 01-24-2011, 09:22 AM   #6
andredmg
Big Nasty
andredmg's Avatar
Drives: Chevys lots of em
Kind of depends on what your future plans are as well? 500hp is the over under for 2.5 to 3 inch piping.
andredmg is offline   Reply With Quote
Old 01-24-2011, 09:24 AM   #7
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
i think the op has the right idea....
2x 2.5 mufflers = ~$150
sounds better than a muffler delete and will perform the same as an axle back...
and as mentioned before... 2.5" in and out.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 01-24-2011, 02:55 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The resonators typically don't add/subtract drone from the system. Drone is taken care of in the helmholtz tube in the OEM muffler.
OP:
If you're looking for a different sound, i'd suggest getting rid of the resonators and replacing it with a Xpipe. Cruises like stock but has a more aggressive sound when you put the gas to it. If you still want more, add your mufflers or axleback. If you decide to go full catback, know that most already have the Xpipe in it. Apex has some great deals or you can keep an eye out in the "forsale" section.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-24-2011, 03:20 PM   #9
Russell James
Russell James's Avatar
Drives: Camaros
The advantage of an an axle back from a quality supplier is it has been tuned for the application. Many people have put on universal mufflers only to have it sound like crud.
Let someone else do the R & D for you instead of trial and error with universal parts.
Old 01-24-2011, 04:12 PM   #10
danhr
BAMF SS
danhr's Avatar
wtf needs to be tuned in an axle back?
there's about 2 feet, total, of exhaust piping there.
not much rocket science there.
Old 01-24-2011, 04:56 PM   #11
mikeSS
mikeSS's Avatar
Drives: 2015 c7
you read that wrong . it wasn't saying tuned as in tune the engine.
Old 01-24-2011, 04:58 PM   #12
Russell James
Drives: Camaros
Sound. I know someone that put some universal Flowmasters on a Camaro. The drone rattled your brain.
A muffler shop suggested some Flowmasters that they happened to carry in stock. They were cut off the next day.
I should have said - they fine tune the muffler in the axle back for the application.
Old 01-24-2011, 05:03 PM   #13
andredmg
Big Nasty
andredmg's Avatar
If you just plan on goin for sound delete the mufflers and it will sound good, if you buy aftermarket mufflers and use your stock piping you will need 2.5 inlet and the out doesnt matter. Delete the mufflers keep the resonaters (sounds the same), ad aftermarket mufflers delete the resonaters. Im just wondering if you will be happy with that or go crazy with mods and what not in the future like some of us thats why I said it depends on your future plans? If you are gonna be making more than 500 at the wheels go with a 3" upgrade headers all the way back. Do it right the first time and plan for the future, just my opinion.
Old 01-24-2011, 05:11 PM   #14
danhr
BAMF SS
danhr's Avatar
Sound. I know someone that put some universal Flowmasters on a Camaro. .
lol
well there's your first problem.
Just Installed the SS mufflers on my V6 FISHTAIL Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 391 04-21-2017 07:01 AM
MagnaFlow Axle Back w/ Mufflers - Install and Review (now with drone!) themossman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 07-12-2010 10:56 AM
Properly maximized Factory mufflers ! 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 02-09-2010 12:14 PM
Stainless Works Mufflers sav1 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 01-28-2010 02:26 AM
4-Sale Stock LS3 Mufflers $40.00 >>>>>>>> 01pewterz28 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 01-14-2010 04:10 PM
