Solo Performance
Old 01-26-2011, 06:39 AM   #1
getarz4u15ster
getarz4u15ster's Avatar
Drives: Camaro RJT 2SS/RS
What is this 160* Thermo..
Okay, Why in the world is everyone putting a 160* thermostat in their cars??? I mean i can see if your running it at the track ALL THE TIME, and you want it the water to circulate at a lower temp... but to much circulation and not enough time in the radiator isn't smart either.... PLEASE on this topic school me the concept.
2010 RJT SS
Port and Polished, Milled .005 Heads
Patriot Valve Springs, Titanium Retainers&locks
Manley Race Valves
Comp Chromoly push-rods
Ported T/B
DT Headers, JBA H/F Catted mid pipes
Magna Flow Comp series exhaust w/ Xpipe
Comp Custom grind Cam
Tune and Machine work done by MPC
CAI Intake
getarz4u15ster is offline   Reply With Quote
Old 01-26-2011, 07:51 AM   #2
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
What does MPC say about it?
2SSCAMARO is offline   Reply With Quote
Old 01-26-2011, 09:57 AM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
What you are thinking about is taking the thermostat out. That does provide too much circulation so the motor doesn't have a chance to transfer the heat efficiently to the coolant, so you might actually run hotter. The 160* thermostate is AWESOME and i have one in every car i own.
With as many 100*+ days we have down here in Texas a thermostat is a must while sitting in traffic with the A/C blasting.
Plus a cooler engine ( to a certain degree) is more efficient.
SUX2BU is offline   Reply With Quote
Old 01-26-2011, 12:46 PM   #4
getarz4u15ster
Didn't ask them...
I didn't ask them, they didn't build my motor, i built it. I'm asking because i don't think it would be prudent to do unless you lived in a hotter climate where it stayed in the high 90's to 100's everyday. Here in Maryland .. not to much. Just curious to find out what people's ideas are on it. that's all..
2010 RJT SS
Manley Race Valves
Ported T/B
CAI Intake
Old 01-26-2011, 12:58 PM   #5
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I saw a diagram showing beyond 180 wasn't good. Had something to do with cylinder wash. I'm sure not adusting the fans too low may help.
I ran a 180 drilled in my Impala for a few months. On a 26 mile drive during the dead of winter the engine never heated up enough to be able to heat the inside of the car. I didn't like it and was pretty sure is wasn't good for the engine to run that cold either.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-26-2011, 01:00 PM   #6
IndeedSS1
IndeedSS1's Avatar
Found it. Scroll to the bottom. http://www.performanceunlimited.com/...hermostat.html
Old 01-26-2011, 01:01 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
just another way to help the engine run a little cooler. some do it in DD's some do it in weekend racers.
I piss excellence
and fart awesomeness
Old 01-26-2011, 01:01 PM   #8
2SSCAMARO
2SSCAMARO's Avatar
The ECM uses engine coolant temperatures as one of the parameters to determine alterations of fuel trims and timing. IMO if you were tuned using a 186 degree stat and you don't experience a lot of hot 90+ degree days, you should stay with your 186 degree stat.
Old 01-26-2011, 01:08 PM   #9
mpiper
mpiper's Avatar
Drives: 2011 Black 1LT RS
Basically, a cooler thermostat allows the radiator fluid to START flowing sooner, and then has a slightly higher flow rate. It doesn't really add any power, it keeps the car from getting as hot and all the related side effects.
A cooler car has less chance of detonation, so you can run more advance. A cooler engine means a (slightly) cooler engine bay, so a bit denser air going into the engine. A cooler engine also prevents premature oil breakdown (not as important with synthetic, but still happens over time) meaning the oil/engine should last longer.
That's about it. Does it mean more in hotter locations? Possibly, but once an engine starts running, the engine bay temperature goes pretty hot pretty fast. So it may not be as important in 10 degree weather as it is in 90 degree, but it will still benefit some.
Of course to cold of a temperature outside (below 0, -10, etc.) and 160 might mean the engine cools too much and never gets to best operating temperature. It really depends on how well your engine bay flows air and cools off when moving.
Last edited by mpiper; 01-26-2011 at 01:11 PM. Reason: Forgot about temperatures below 0
mpiper is offline   Reply With Quote
Old 01-26-2011, 01:11 PM   #10
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
Originally Posted by IndeedSS1 View Post
all the info right their
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 01-26-2011, 01:48 PM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
So....taking a quick look it sounds like a 180 would be best but I've only seen 160 for the Camaro.
Watching the coolant temps in my DIC I'm usually running around the 200 mark.
I'm thinking about adding the 160 so I'm curious to hear how this has been working for those driving the Camaro as a daily driver and have a 160.
Build Journal
Old 01-26-2011, 02:57 PM   #12
Slowhawk
Drives: 1999 Trans Am
The 160's we do run about 176-180 cruising on the highway with constant flow over the radiator. Heat works just fine and the cars heat up quickly.
The lower temp can help detenation,this doesn't mean you add a ton of timing,just it can handle the timing you have now easilly.
I love how people compare track cars to street cars.What you learn on the track transfers to get top performance on the street.The track is a better tuning tool than a dyno.
The stock radiator has enough capacity to control a 160 t-stat so it cycles.
Everybody can run what they see fit. We run alot of the 160's from what we've seen in the past on LS motors.
Slowhawk is offline   Reply With Quote
Old 01-26-2011, 03:45 PM   #13
Never Satisfied
220/221 whatever it takes
Never Satisfied's Avatar
Drives: See sig....
Yup, got a 160 in mine and it runs right around 180 on average out on the highway.
Brent
2017 Scat Pack Shaker A8 (Daily Driver)
2016 Challenger Hellcat A8
Never Satisfied is online now   Reply With Quote
Old 01-26-2011, 03:56 PM   #14
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
SlowHawk is right again....like aways! Trust what he says if you interested in learning
I run a 160 degree thermostat. I cruise on the highway at 172 consistantly.
Tampa Tuning is offline   Reply With Quote
For sale: SLP 160 degree thermo topgun1 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 3 09-03-2010 10:22 AM
Help! car overheating after SLP 160 thermo install.. topgun1 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 8 07-27-2010 07:43 PM
Heatsoak as bad as LS2? BackinBlackSS/RS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 05-09-2009 07:16 PM
