Old 01-26-2011, 10:13 AM   #1
TX_Shane
Drives: 2010 2SS RS A6
Cam package/kit needed for L99 to LS3
Going back to lurking
TX_Shane is offline   Reply With Quote
Old 01-26-2011, 11:05 AM   #2
Sully
Sully's Avatar
Drives: Orange 2SS/RS LS3
check in the vendor parts section. most vendors on here are very quick with their responses and are tons of help!
Sully is offline   Reply With Quote
Old 01-26-2011, 07:03 PM   #3
Eric Baker
Drives: Black/Black 2SS/RS 6M
Jannetty Racing sells a complete conversion kit.
Eric Baker is offline   Reply With Quote
Old 01-26-2011, 07:22 PM   #4
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
This page has Ted's cam packages as well as the L99 to LS3 conversion kit
http://jreperformanceparts.com/gm/20...s.html?cat=331
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 01-26-2011, 07:31 PM   #5
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
futral motorsports is who i went with . got everything you will need .
1 BAD RS 2 SS is offline   Reply With Quote
Old 01-26-2011, 08:21 PM   #6
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
I got my conversion kit here http://www.lingenfelter.com/mm5/merc...gory_Code=C379.
Busy_Boi is offline   Reply With Quote
Old 01-26-2011, 08:26 PM   #7
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Livernois motorsports sells it. Jannetty Racing sells it and LG motorsports sells it.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 01-27-2011, 09:30 AM   #8
Jason 98 TA
Drives: Camaro
We have the complete conversion kit if you want to remove the VVT. Have you studied VVT? The main reason shops sell VVT delete kits is they don't have experience with VVT to run it properly.
VVT allows you to run the same duration camshafts you currently run, only with the ability to control the camshaft throughout the entire rpm pull? Why wouldn't anyone want that ability? It's one of the better advances the LS motors have made in several years.
Think of it this way
Does more advance make more power down low in the rpm band? Yes
Does less advance pickup power up top in the rpm band? Yes
Does VVT allow you to have the best of both worlds? Yes
Do you want the best possible power at every rpm point? If the answer is yes then you want VVT.
Jason 98 TA is offline   Reply With Quote
Old 01-27-2011, 11:29 AM   #9
Ben
Drives: 2011 RJT 2ss/rs l99
Wait so the deal with these ls3 conversions is that they pretty much turn your auto into a manual?? Or am I missing something?
Ben is offline   Reply With Quote
Old 01-27-2011, 11:51 AM   #10
robertway
robertway's Avatar
The man has a point.....
It really just "converts" your L99 that comes in the Auto to an LS3 that comes in the manual cars. Does nothing to the transmission. The L99 has Variable Valve Timing (the camshaft advance/retard changes depending upon where in the rpm range you are) and the L99 has DOD (displacement on demand, shutting off half the cylinders under certain conditions), the LS3 has neither of these and is a more traditional pushrod V8.
Old 01-27-2011, 12:02 PM   #11
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Can you go with a full spec range of camshafts w/ VVT... Answer = No
Old 01-27-2011, 12:06 PM   #12
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2016 Charger Hellcat
Does somebody sell a decent blower cam for the L99 w/vvt? Also, is there an upgraded lifter available as well?
lewylew is offline   Reply With Quote
Old 01-27-2011, 02:57 PM   #13
mlee
www.CamaroFans.com
mlee's Avatar
LS7 lifters are the replacement. There are lots of blower friendly cams for VVT out there.
Old 01-27-2011, 04:30 PM   #14
robertway
robertway's Avatar
Originally Posted by TX_Shane View Post
Thanks for everyones input.
Let us know what you do.....
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
what Cam? LS3 with TVS2300 shooting for 600+whp walhan_qtr Forced Induction - V8 54 10-11-2010 01:24 PM
LS3 with cam allmotor Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 07-12-2010 08:49 AM
TTP Annihilator V.2 Cam, FAST LSXr LS3 - 503rwhp/471rwtq Sales @ ECS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 03-03-2010 10:44 PM
ls3 cam experts needed.. opinion.. mark_p Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 07-25-2009 03:20 AM
