Jason 98 TA
Old 01-26-2011, 01:31 PM   #1
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
Removing the intake manifold, do I need to replace injector o-rings?
I am pretty close to getting a Catch Can and would like to take the intake manifold off to clean it out and start with a clean manifold. I had thought I read somewhere that the fuel injector o-rings should not be reused and was wondering if that is indeed the case and if so any idea what the GM Part# would be for their replacement?
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 01-26-2011, 03:03 PM   #2
Russell James
Russell James's Avatar
Drives: Camaros
I wouldn't take the intake off. More likely to mess something up that isn't messed up now. That little oil in there won't hurt a thing. It's an engine, oil is it's friend. Your already fixing the larger problem of excess oil usage with the catch can, so I'd leave it at that.
It is real easy to take off the throttle body. You could pop that off and just wipe off the back of the throttle blade. That gasket is reusable, so it's a very easy on and off job.
Old 01-26-2011, 03:07 PM   #3
thesnoopster
thesnoopster's Avatar
Drives: '10 SIM SS/A6 - '12 SIM Equinox LT
Good question because I was looking at taking mines off (intake and throttle body) to get ported. But I didnt want to mess with the injectors and stuff.
2010 SIM Camaro 1SS/A6
Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone"
Old 01-26-2011, 03:50 PM   #4
robertway
robertway's Avatar
I will be swapping the throttle body out by the end of this week for one of the VMax CNC Ported ones from SC2150 so I may just clean off what I can reach. Not really concerned about messing anything up to be honest just wondering about the o-rings.
Thanks for the feedback...
Old 01-27-2011, 10:41 PM   #5
ODN13x
Drives: 2011 M6 2SS/RS
pull it all apart, you wont mess anything up, after removing fuel rail clean off injector o-ring and apply touch of lithium grease to them before reinstalling. it will take you all of 30min to remove the intake. Simple, o-rings arent old enough to worry about. If an o-ring comes off inspect it for a tear, no-brainer, if all good wipe clean and reinstall.
ODN13x is offline   Reply With Quote
Old 01-28-2011, 06:45 AM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
no... you only have to replace them if they have high mileage (~50k miles)
That's one of the benefits of these LS motors, you can rip off the intake and put it back on without replacing a single gasket.... a lot of the motor is like that.. re-useable gaskets ftw!!
The only thing to look out for is when you take the intake manifold off, that the hose coming out the back of it doesn't catch on your oil pressure sensor and break your sensor. then you will have to replace your sensor, and i think it's like $~35 or something.
then when you put the intake back on, you have to tighten them down in sequence, or else the o-rings (intake gaskets) won't seal properly
You should make two passes... the first pass, just hand tighten them, and then the second pass, torque them down to 7 ft lbs or 89 inch lbs
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 02-10-2011, 05:39 AM   #7
AntzV
AntzV's Avatar
Drives: blacked out 2010 Camaro
Are there any DIY on removing the intake manifold??
AntzV is offline   Reply With Quote
Old 02-10-2011, 08:33 AM   #8
thesnoopster
Good question...anyone?
Old 02-10-2011, 11:23 AM   #9
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
Really like the graphic and the info. Saving that for later.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
INTAKE MANIFOLD COVER REMOVE FOR PERFORMANCE ablackburn99 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 01-31-2014 02:29 PM
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! AutoAgenda V8 Bolt-Ons & Tunes 438 11-23-2013 10:49 PM
**For Sale :: 2010 L99 Intake Manifold :: Fuel Rails + Injectors Included SonnyakaPig V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 6 11-05-2012 10:49 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 10:35 AM
