Cold Air Inductions
Old 01-26-2011, 05:00 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
Strut Tower Brace Clears Magnuson Superchargers MTI Racing
This new 4-pt Strut Tower Brace from Hotchkis will clear your Magnacharger Supercharger. Check out the details below.
Hotchkiss 4-pt Strut Tower Brace #20109 for 5th Gen Camaro
Description:
Like most street driven cars, the new 2010 Camaro suffers from chassis flex. Under hard cornering and when driving over uneven surfaces the unsupported strut towers momentarily distort, reducing stability and control. The new Chassis Max Strut Tower Brace from Hotchkis Performance adds necessary rigidity to the Camaro by eliminating strut tower flex.
The Chassis Max Strut Brace ties the strut towers together at four mounting points, offering maximum support in tension, compression and twist. The four point design offers a distinct advantage in strut tower support over a two point design, and also maximizes the performance gains from other chassis improvements like sport springs and sway bars. This product is a must for spirited street and track day driving.
Bonus feature: It CLEARS the Magnuson TVS2300 Supercharger!
Fabricated from strong, lightweight 1-¼" DOM steel tubing and 100% TIG welded with laser cut brackets and corner gussets, the brace is designed to fit over stock and Magnuson supercharged engines. Some drilling is required, and the brace bolts on with simple tools. A unique reservoir relocation bracket is also included.
Finished in durable semi-gloss black powder coat, the Chassis Max Strut Tower Brace includes installation hardware and detailed instructions. Like all Hotchkis Performance products the brace is designed, track tested and manufactured in the USA using domestic materials.
Features:
-Fabricated from strong, lightweight 1-¼” DOM steel tubing with laser cut brackets and gussets
-Four-point mounting system for maximum strut tower strength
-Works with naturally aspirated and Magnuson superchargers
-Straightforward installation with included hardware package
-Finished in durable semi-gloss black powder coat
Benefits:
-Reduces sub-frame flex, which makes the suspension work better.
-Increases chassis rigidity, so you can corner flatter and faster.
-Improves handling responsiveness for better race times.
-Will clear Factory engine shield and Magnuson superchargers.
Application Note: This application has been designed and tested to work on the V8 models. Will not fit Vortech or Kenne Bell supercharger. Will not fit V6.
MTI Racing Kevin is offline   Reply With Quote
Pedders Camaro Strut Tower Brace ? Markus Wheels and Tires Talk Sponsored by The Tire Rack 8 02-17-2011 09:41 PM
Discounts for our Military Personnel from MTI Racing MTI Racing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 07-07-2010 01:22 PM
Discounts for our Military Personnel from MTI Racing MTI Racing USA - Southeast 0 07-02-2010 12:14 PM
1993-02 Camaro/Firebird Shock Strut Tower Brace dpizzardi Suspension / Chassis / Brakes 0 06-15-2010 08:40 PM
Pfadt Strut Tower Brace INTRO Sale IPS Brandon Suspension / Chassis / Brakes 25 06-04-2010 10:21 AM
