Emblempros
Old 01-28-2011, 08:08 AM   #15
caverman
caverman's Avatar
Drives: '69 SS Convertible
I would think that just removing the bottle and cutting out the section right behind the grill would definately be better than nothing. I even thought about doing that just to try it out but then decided WTH.....the scoop made a difference with the CAI it has to only help out. After adding the scoop I'm definately glad I did. It's a nice piece and has to help directing the air up.
The washer bottle is blocking to much air for those CAIs that pick-up air from the fender well area.
I'm sure the Roto-Fab would perform alot better as well with at least the bottle gone and the whole cut.
I need to lookin into getting some software for my laptop so I can at least learn to look at the A/F ratio things like that.
Build Journal
Old 01-28-2011, 08:14 AM   #16
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
If I recall correctly, another member tried just the cutout without the scoop and noticed no difference! He said that adding the scoop had a signifcant improvement. Must need the scoop to direct air flow directly up to the intake filter!
Not a Camaro but it works for now!
Old 01-28-2011, 12:02 PM   #17
Halltech
Drives: 2010 Halltech Camaro SS, 2008 C6Z06
Can't wait to see the results.
Jim
Halltech is offline   Reply With Quote
Old 01-28-2011, 02:03 PM   #18
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Even though I have the SCT, I'm just going to use one of these. http://www.aeroforcetech.com/products_interceptor.html
I'd do a dual with A pillar pods, but I had a triple gauge setup in my last car and it drew way more attention than I wanted.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-29-2011, 04:53 AM   #19
Hesh
Hesh's Avatar
Drives: 2010 IOM Camaro Vin 34334
Love the Torque program for my Android phone. cost $5 for the program, $30 for the bluetooth adapter, and it will do as much as some $300 scan tools. Works great for me so far.
Hesh is offline   Reply With Quote
Old 01-29-2011, 08:58 AM   #20
caverman
caverman's Avatar
Is there anything like that for the iPhone?
Build Journal
Old 01-29-2011, 01:41 PM   #21
Hesh
Hesh's Avatar
Yep its called Rev. Its $40 and you can use the same bluetooth adapter that I got for my phone. Its called an ELM 327 bluetooth adapter. They sell them on EBAY. There are some cheaper ones that will have to come from China, or from the U.S. like I got for a little more and showed up alot quicker.
Old 01-29-2011, 01:43 PM   #22
looks real good
Old 01-29-2011, 03:59 PM   #23
caverman
caverman's Avatar
Thanks.....I'll look into it.
Build Journal
Old 01-31-2011, 11:01 AM   #24
caverman
caverman's Avatar
Added the OEM cap to the water bottle and painted it Flat Black to blend in more. I think it came out pretty good.
Build Journal
Old 09-01-2011, 09:58 AM   #25
DieselDork
DieselDork's Avatar
Drives: 2010 RS/SS
Dude, that is SO, SO AWESOME!!! I LOVE IT! Fantastic job!
DieselDork is offline   Reply With Quote
Old 09-01-2011, 10:52 AM   #26
malloyevelyn110
Drives: jeep
good job. how long did it take?
malloyevelyn110 is offline   Reply With Quote
Old 09-04-2011, 02:52 PM   #27
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
I installed the ADM Race CAI and scoop on my Camaro. The Race CAI lid does not have a provision for the factory washer bottle. I relocated the washer pump down by the scoop. The washer bottle I used is from Roto-Fab. It mounts to the body and looks clean. Here are a few pictures.
And yes that is a Factory Strut Tower bar on a 2010. We are working on custom brackets right now.
MRGOODWRENCH3 is offline   Reply With Quote
Old 10-08-2011, 02:07 PM   #28
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
I just did my ADM Scoop this morning.
It was a simple process. It took a while though. I didn't have a metric wrench so I had to go to lowes to get my horn bolt off. Also, the washer and nut was painted over so it was stuck. I had to get my dremmel and cut the bolt off so I could use the provided bolt and washer/nut that came with the scoop.
It took me about 2.5 hours with the trip to lowes and extra cutting. I haven't connected my washerbottle yet. I have the Schwinn bottle, painted it, put the little nozzle fitting in, used some liquid nails, rubber gromets, and washers. It's setting, I just need some longer nuts and bolts and to decide where I will place it. The pos battery post is kind of hard to reach with a drill so I'm not sure I'll try there. I think I will go with the side of the heat shield from my K&N. I have never used my washers EVER. The tank weighs a ton, there's got to be a gallon of the stuff... O_O there's some weight saving for you.
I also duct taped up the little perforations in the scoop (overkill? probably).
Tips: make sure you have some metric ratchets for this one. When removing the washerbottle make sure you know what you're going to do to plug the stock washer motor, I undid the tube thinking it would need to be on to allow the fluid to flow. I was wrong. I had to plug it, then uses some of the tube I intend to use for the bottle to motor conection and kinked it and then put a rubberband over the kink. I still had a little puddle of fluid on my floor. Also, if you have compressed air, the little plastic shavings are everywhere and you could blow them out with that or just let the highway air do it.
next up is that heater hose relocation and the plenum insulation removal...
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
ADM Intake Scoop Data at the track ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 01-22-2012 11:05 PM
Halltech Yellow Jacket Install Question? LemmingRush Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 06-01-2010 09:16 PM
Halltech Yellow Jacket 1 week sale starts tonight!!!!!! Halltech V8 Bolt-Ons & Tunes 5 05-02-2010 03:26 AM
***Halltech Yellow Jacket CAI For Sale. Very Good Condition*** SonnyakaPig V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 3 04-21-2010 11:29 AM
Halltech Yellow Jacket nuptualnemesis Vendor and Seller review / feedback / experiences 0 10-27-2009 11:23 AM
