Caryle Racing
Old 01-29-2011, 08:08 PM   #1
mikeeee
Drives: 2011 Camaro LS SS
2011 Double Din Installed Today!
Just installed a Double din with cd,dvd,tv,nav,bluetooth, sd card slot,ipod connection, am/fm, with 7" screen and 11" head rest monitors w/video inputs for your playstation,xbox. Radio has pip while navigation is on. Load up all your music videos on the sd card and go! Screen is touch screen. Yes onstar still works perfect as does all other functions. Radio also has built in radar detection that shows you where the radar is on the nav screen long before you get to where the radar is!
Used the metra kit. Metra kit did need some modification. It is not plug and play as they say. I can detail a little more or be glad to help walk you through an install if you decide to do one. Radio delivered to home under $300. Headrest monitors $179 free shipping. Metra kit 99-3010s $189 free shipping. Kinda grainey cell pic attached.Will upload more/better pic tomorrow. 2011 Camaro LS non-amplified system.
Name:  2011 Camaro Double Din Installed 1.jpg
mikeeee is offline   Reply With Quote
Old 01-29-2011, 08:11 PM   #2
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
looks good, what head did you get? and what mods did you have to do to the metra?
do you actually have passengers in your car to need headrest monitors? can barely get my 6 & 7 yr olds back there!
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 01-29-2011, 08:30 PM   #3
mikeeee
Head unit is a no name version from ebay. But so far it works great and has features you cannot find in $1400 head units. Picture is fab. Monitors are for other drivers! Couple of mods in the metra kit. Had to splice into harness of metra kit for the front speaker wires.+and- Kinda weird why the harness was done that way. Also could not intially get 12v switched power so radio would not come on. Instructions said connect a blue wire of the harness to the brake wire of the head unit. When you look at the blue wire though it has right rear+ stamped on it. Called metra and they said they make the harnesses out of whatever wire is available during manufacturing. I said thanks for stating that in the instructions. Anyway it works great!
Old 01-29-2011, 08:39 PM   #4
mikeeee
Here is a pic of a few of the wires!
Name:  2011 Camaro Before Completion of double din install.jpg
Old 01-29-2011, 08:53 PM   #5
dmartin7700
dmartin7700's Avatar
Drives: convertible
Where did u get the metra kit for at 189
dmartin7700 is offline   Reply With Quote
Old 01-29-2011, 08:59 PM   #6
mikeeee
ebay on the metra kit 189 free shipping. search ebay and you will find it.
Old 01-30-2011, 12:00 AM   #7
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
Holy shit!!! How did you get that thing in your dash with those wires all crazy? I'm assuming you bundled them up with either tape and zip ties and tucked them away in the dash?
And yes, there is some slight modification to the speaker wires. Metra assumes you will be using amps so it ships the harnesses with RCA plugs on the ends of the speaker wire. You can either buy an RCA to 2-wire adapter or you can cut off the RCA's and splice.
Good find on the metra kit for 189. I got mine for $200 also with free shipping.
Good luck with the head unit... sounds like it has some sweet options.
Darth Martel is offline   Reply With Quote
Old 01-30-2011, 12:01 AM   #8
looks awesome
Old 01-30-2011, 12:07 AM   #9
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
if you gotta have it I guess...it just takes away from the look of the dash panel....looks cheesy...cheap JMHO
THE "MENACE"
Capthowdy is offline   Reply With Quote
Old 01-30-2011, 12:14 AM   #10
Darth Martel
Darth Martel
The silver finish is what I think makes the metra kit look cheap. Painting it makes it look A TON better. See my thread for comparison.
Old 01-30-2011, 08:21 PM   #11
mikeeee
The wires pic was while i was testing everything. Actually the silver blends in with the rest of the trim pretty good I think. As far as cheap looks go,it is all plastic. I didn't want to paint it, but I guess if you want to, everyone has their on style. Wires were wire tied then hidden behind head unit. The space hog was the huge 44pin factory harness plug and the metra interface. It was a tight fit. Next up 2 amps and 2 or 3 15's or 12's! Radio has 50 watts rms, not a rump shaker but it will do till I get the amps and subs in. May not put in subs though. Might just use the 6x9's from The loudest.com I had a pair in my other ride and them boys, with the right amp will make your hair stand up!
Old 01-31-2011, 10:41 AM   #12
jhintz20
jhintz20's Avatar
Drives: 2011 Black 2SS/RS L99, 05 IBM Goat
What headunit do you have?
jhintz20 is offline   Reply With Quote
Old 01-31-2011, 12:29 PM   #13
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
When I did mine I made a battle plan, took all of the harnesses and made a couple of long bundles outside of the car with everything connected or soldered. There's really too much going on to do it in the dash properly IMO. Then when I installed used velcro wire bundlers to put it all together. Zip ties are too hard to remove.
Also, I covered the dash plastic with tape and had a towel over everything low...
xxlbeerz is offline   Reply With Quote
Old 01-31-2011, 12:36 PM   #14
99prbms
Drives: 2010 2lt
how is that screen working out for you? i have a kenwood double din nav.. but a freind of mine is looking to get a screen, i might recommend he tries one like you have.
99prbms is offline   Reply With Quote
* * * 2011 Camaro / SEMA Special Edition News * * * CamaroScotty Camaro Price | Ordering | Tracking | Dealers Discussions 16 11-06-2010 07:43 AM
DOUBLE DIN IN DASH DVD 2011 COUPE JuanT Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 16 09-06-2010 09:49 PM
Synergy Green 2011 1SS Ordered Today Autofind Camaro Price | Ordering | Tracking | Dealers Discussions 31 08-07-2010 07:58 PM
double din video nav instead of gauges Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 12-01-2009 08:02 PM
