Old 01-29-2011, 10:00 PM   #1
MaRoFreK
MaRoFreK's Avatar
Drives: IOM 1SS w/factory Hurst
LSR or MTI short throw
I'm looking into getting a short throw shifter and I've narrowed it down to the LSR and MTI six shooter. Does anyone have any opinions on which one woud be better, anybody have either of these? Any input and opinions would be great. thx
"Success is following the pattern of life one enjoys most."
Stainless works Catback with Flowmaster Single Chamber Mufflers, Vararam, Factory Hurst, SLP SS emblems, SLP Skip Shift
MaRoFreK is offline   Reply With Quote
Old 01-30-2011, 08:54 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The MTI shifter is sweet. That and the Hurst are my two favorite.
Old 01-30-2011, 08:55 AM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
This.
I piss excellence
and fart awesomeness
Old 01-30-2011, 09:08 AM   #4
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
MTI.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 01-30-2011, 09:47 AM   #5
michael's maro
RAM'S CAMARO
michael's maro's Avatar
Drives: 2010 camaro ss
I've had my MTI shifter in my car for well over 1 year, 1 of the best mods I bought so far.
michael's maro is offline   Reply With Quote
Old 01-30-2011, 10:41 AM   #6
MaRoFreK
MaRoFreK's Avatar
Do you have any pics of it by chance? I was wondering how tall it was.
Thanks for the input, I appreciate it guys.
Old 01-30-2011, 11:04 AM   #7
flht99b
flht99b's Avatar
I believe the MTI shifter is stock height. In fact I use the stock leather knob so it looks OEM. However MTI offers many different knob options so you can tailor the shifter to your personal preference. Shift throw is about 28% shorter that stock and all the "rubber" feeling the OEM shifter has is gone. I've had my MTI shifter for over a year and it feels as tight and smooth as it did the day I installed it. I have also never experienced any noise from it which several aftermarket shifters are known for.
Ed M.
Old 01-30-2011, 11:12 AM   #8
MaRoFreK
MaRoFreK's Avatar
Ed M.
Did you notice any wobble, Like the Hurst had? How hard was install on it? I assume install was pretty straight forward but I read you had to lower the transmission.
Old 01-30-2011, 05:07 PM   #9
flht99b
flht99b's Avatar
No wobble but didn't have any wobble with the stock shifter either. I modified the instructions that MTI sent which in my mind made the install easier. In a nutshell I didn't remove the entire OEM shift assembly and build the MTI unit on a bench and then try and install the entire unit as MTI suggests. Instead I put it all together from underneath the car and I did not drop the exhaust system. It requires patience and careful assembly which any of the shifters require. All of the shifters I know of require you to remove the transmission cross member so the transmission moves away from the body a bit.
Ed M.
Old 01-30-2011, 05:12 PM   #10
Apex Motorsports
Wobble?
Old 01-30-2011, 07:36 PM   #11
MaRoFreK
MaRoFreK's Avatar
Wobble?
Yea I knew they said it was caused due to install error. I'm just real Scared to risk getting the Hurst and end up with that stinking wobble. Ireally like the way the Hurst looks and I know it has the shortest Throw 44% I believe. I have also read people saying it takes alot of effort to shift with the Hurst. My buddy has a Hurst in his 2008 Mustang I would assume there set up the same and I love his. Im just worried.
Old 01-31-2011, 08:28 AM   #12
2quick
Drives: none
pm sent with some info. Thanks for considering LSR for your purchase.
2quick is offline   Reply With Quote
Old 01-31-2011, 09:10 AM   #13
Stewcam
Stewcam's Avatar
Drives: 2010 Camaro SS/RS
No wobble with hurst....
Yellow SS/RS
LMR Twisted Slayer 650 RWHP, ARH Headers, Hi-flow cats, Carbon/Organic Twin Disc/Pfadt/BMR/Hurst Shifter/D2forged VS1's
Stewcam is offline   Reply With Quote
Old 01-31-2011, 10:41 AM   #14
steeleshark2
steeleshark2's Avatar
MTI all the way!!
If you installed MGW short throw: Infern0 Transmission / Driveline 14 03-07-2010 11:22 PM
Phastek Performance - Hurst TRUE Short Throw Shifters!! Sean@Phastek Transmission / Driveline 3 02-15-2010 10:33 AM
Short Throw Hurst Shifter Not Available Matster 5th Gen Camaro SS LS LT General Discussions 51 11-09-2009 11:03 AM
Short Throw Shifter Constrained?? josh1147 Camaro Price | Ordering | Tracking | Dealers Discussions 75 02-19-2009 01:51 PM
