Old 01-30-2011, 07:33 AM   #1
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
advantage of aluminum vs steel flywheel???
has anyone just replaced the stock steel flywheel with an aluminum one and kept the stock clutch? what is an advantage or disadvantage of doing this? im concidering doing this to drop a few LBS from the drivetrain and free up a few horses. if you have done this please post up what flywheel you went with.
http://www.gofundme.com/n7ne44
2010_5thgen is offline   Reply With Quote
Old 01-30-2011, 10:12 AM   #2
SC2150
The pluses are for road racing the rpms will drop less between up-shifts and the motor can rev quicker. The negatives are in a drag race application the heavier flywheel will store more energy/inertia that allows a harder launch.
Old 01-30-2011, 10:22 AM   #3
2010_5thgen
and since im more into road racing than drag racing, this would be ideal for my car....right?
Old 01-30-2011, 11:13 AM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Light flywheels make it a bit more difficult to leave a stop. You will need to rev it more and slip the clutch a bit more... But it is "livable"...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-31-2011, 09:56 AM   #5
2010_5thgen
rev it more? how much more do i have to rev it?
Old 01-31-2011, 10:13 AM   #6
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Not really reving it more at launch...it will just bog down a little more due to less inertia. Also the lighter flywheel will not keep your car running when loping on its own..you have to be tuned very well. But it will spin up fast for you even on the drag strip. I would not waste time doing a flywheel without doing the clutch though..jmo!
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 01-31-2011, 10:37 AM   #7
hypurone
hypurone's Avatar
Hard to say as every car is a bit diff but with our V8's torque you'd prob need to add 500-1000rpm to get away smoothly, more if you want to leave aggressively...
Coming Soon! RAM Twin Disc Clutch and Flywheel! Taking Pre-Order List @BMC Peformance Kris@BMCPerformance V8 Bolt-Ons & Tunes 7 02-18-2010 07:00 PM
Software upgrade to put 20" polished aluminum wheels/tires on LS? craigger Wheels and Tires Talk Sponsored by The Tire Rack 11 07-30-2009 10:29 AM
POLISHED ALUMINUM v. MIDNIGHT SILVER SuperSport2010 Wheels and Tires Talk Sponsored by The Tire Rack 15 06-10-2009 08:06 PM
