JUICEDMOTORSPORTS
Old 01-31-2011, 09:08 PM   #1
Asian Zero
Asian Zero's Avatar
Drives: 2010 IBM Camaro 1LT RS
Interior rear quarter panel removal?
Anyone know how to take out the lower rear seat quarter panel (the panel with the armrest)? thanks
Asian Zero is offline   Reply With Quote
Old 01-31-2011, 10:04 PM   #2
GearHeadPeter
US Navy Vet
GearHeadPeter's Avatar
Drives: 2011 2LT/RS, 65 Mustang GT Fastback
First you start by unsnapping the covers, be careful, that go over the driver/passenger door sill area.
The rear bottom back seat comes out by pulling up on each side and it will come out. For the rear upper seat area just unbolt the 5 bolts, pull down on the rear seat release and take the entire assembly out.
Each rear side panel is held in place by snaps. Start at the upper part of the side panel where it meets the B pillar, and just keep unsnapping all the way around until it comes off. Repeat for the other side.
Key to all of this is to be gentle otherwise you will have broken snaps or panels.
Good luck.
2011 - 2LT/RS - RY, A6, Gray Interior - Team LLT:
3rd Camaro on this forum to have a Mylink installed. Installation by GEN5DIY, Heritage Grill, Lloyds Premium Ebony Camaro RS floor mats, Empire Billet Camaro Black sill plates, AAC: LED footwell & interior lighting, Rear Courtesy Lights, LED side markers/turn signals, Plasma P13W DRl bulbs, Formula 1 Pinnacle Series tint, Roto-Fab Yellow CAI & Fuse cover, Technostalgia Afterburner LED taillights, EmblemPros custom V6 hydrocoated carbon fiber/RY engine cover, Pfadt Sport sway bars, Ofer's Backup Camera, and full Brembo brake conversion.
GearHeadPeter is offline   Reply With Quote
Old 01-31-2011, 10:33 PM   #3
Asian Zero
Asian Zero's Avatar
thanks, you wouldnt happen to have pics or a link to a thread that does?
Old 01-31-2011, 10:54 PM   #4
cool376
cool376's Avatar
Drives: 2010 Camaro 2SS/RS
I have two pics of mine when I had to disassemble it along with the rear c pillar garnish and upper b pillar garnish for a antenna wire replacement. Sorry there not better pictures.
cool376 is offline   Reply With Quote
Old 01-31-2011, 10:57 PM   #5
cool376
cool376's Avatar
You probably already know but don't forget to torque the seat back when you reinstall it.
Old 02-01-2011, 09:31 AM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
You do not need to unbolt the 5 bolts for the top, There is a latch at the bottom of the 2 sides it metal in color and you can move it all the way to the open point and lift only the seat.
Old 02-01-2011, 10:13 AM   #7
cool376
cool376's Avatar
I agree with the latch to remove the seat, I noticed that when I was in there but it seemed to be more trouble than it was worth. I gave up trying that method, it was easier for me to just unbolt it. Has anyone noticed the clips at the bottom of the quarter trim? Mine were not installed I found them in the body cavity behind the quarter trim just laying in there.
Old 02-01-2011, 10:16 AM   #8
GearHeadPeter
US Navy Vet
The latch on mine would not release on one side so I opted to take out the assembly. If you can get them both to release as 2SSRS indicated it would be easier. I have attached what another Forum member had posted on taking out the rear seat, panels, and door sill covers. Sorry just found it this morning and hope it helps.
Old 02-02-2011, 12:04 AM   #9
Asian Zero
Asian Zero's Avatar
thanks for the help i got them out. took me awhile to get the bottom out, seat belt buckles were the problem after that it was easy. took my quarters out so i could paint them. ill get pictures out once i put them back in.
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 53 07-17-2013 02:16 PM
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran 5th Gen Camaro SS LS LT General Discussions 114 04-16-2012 04:04 PM
How much does the part for quarter panel cost? nardox 5th Gen Camaro SS LS LT General Discussions 6 10-03-2010 10:58 PM
Quarter Panel Removal?? CamaroDude Camaro DIY & HOW-TO instructions & discussions 7 09-24-2010 07:14 PM
