Cold Air Inductions
Old 02-02-2009, 02:53 PM   #1
pandalove182
Drives: 1985 camaro Z28,2000 camaro SS
first look
Im leaving to buy my first car this friday. I just want to post this to see if there are any suggestions for me to look out for when I take a look at the car. Im not to sure what I should check when I first take a look. Also, when I drive it, its a 6speed, what should I feel for? Any comments would be appreciated.
Also, does the 2000 camaro SS have the LS6 intake?
pandalove182 is offline   Reply With Quote
Old 02-02-2009, 06:09 PM   #2
MrCool
MrCool's Avatar
Drives: '95 Z28
You should look to see if the car runs smoothly, does it do anything abnormal or rough? (IE: idle rough, make abnormal squeaking noises or sounds, does it launch and drive fine, ect.)
If you have time, I found this website on google.
In particular, look at the section "Test Drive."
That is just what I've come up with in ten seconds...anybody else have anything to add?
MrCool is offline   Reply With Quote
Old 02-04-2009, 02:56 AM   #3
Lumina SS
Corvette Z51
Lumina SS's Avatar
Drives: Corvette Z51 476rwhp & camaro
you should take the car to a michanic to check the engien transmission and the rear axle.
if you here a noise from the rear axle it's ok all the camaro like this but the noise should not be so loud because if it's so loud go and check it and yes the 2000 has the ls6 intake and check the car he crash on it or not.
check the milege to.
Lumina SS is offline   Reply With Quote
Old 02-04-2009, 08:05 AM   #4
pandalove182
Its carfax history checks out, it has 18k on it, I was also wondering does anyone know if all SS camaros come with cruise control?
Old 02-07-2009, 11:23 PM   #5
Lumina SS
Corvette Z51
Lumina SS's Avatar
yes they all come with a cruise control
