Cold Air Inductions
Old 02-01-2011, 08:51 AM   #1
erk5000
erk5000's Avatar
Drives: 2010 Camaro 2SS L99 SIM
Send a message via Yahoo to erk5000
What should I get next?
I'm about to receive my Doug Thorley Catback system for my 2010 Camaro SS L99 as listed here: http://www.camaro5.com/forums/showthread.php?t=125385
My question is what should I get next, Doug Thorley Shorty Headers or cold air intake? I also want to do a tune right after I get either of those that way I can tune the AFM out. The reason why I want to get shorties instead of LT's is because I don't want to deal with the whole inspection stuff and especially since I'll be moving to California within the next 2 months. Thanks.
erk5000 is offline   Reply With Quote
Old 02-01-2011, 08:58 AM   #2
ron10
Drives: 2010 2SS IOM L99
CIA definitely.
Old 02-01-2011, 09:00 AM   #3
IROCanSS
Drives: 89 IROC 350
Originally Posted by ron10 View Post
CIA definitely.
CAI, exhaust and tune wont pick up much as far as numbers go but the car will feel MUCH better on the butt dyno.
Old 02-01-2011, 11:25 AM   #4
erk5000
erk5000's Avatar
What type of CAI do ya recommend?
Old 02-01-2011, 11:50 AM   #5
kook
kook's Avatar
Drives: 2010 2SS Yellow
ROTO-FAB
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
Magnaflow Street Cat-Back
DOD Delete
Forgestar F-14's and Pedders XA + PKG
Custom grind cam from Cincy Speed
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Cincy Speed Build and Tune 540rwhp
kook is offline   Reply With Quote
Old 02-01-2011, 12:09 PM   #6
Tie Rod
Drives: 2011 Camaro 2SS/RS
I have a Vararam cai and I love it. Do some readingon some of the other ones out there. Also Throttle body, tune. Also read about a catch can, they are worth it down the road. No H/P but will help keep your engine clean.
Tie Rod is offline   Reply With Quote
Old 02-01-2011, 12:17 PM   #7
ADM
Old 02-01-2011, 12:29 PM   #8
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
The shorty headers are not going to do much for you. Not sure bout the shorty cost. I recommend going to rear gears with your L99. 3.70 for a street driven car. You will really wake up performance. When you tune out the AFM you insert the new ratio. Cost could be a little more for the gears but performance gain huge compared to shorty's.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 02-01-2011, 12:46 PM   #9
Jason 98 TA
Drives: Camaro
Shorties made no power gains when we tested them for a customer that brought them to be installed. You might run a search for my post to check it out. We offer camshafts that are CA friendly, and we can help you with other bolt ons like intakes & pulleys!
Give us a call if we can help!
Jason 98 TA is offline   Reply With Quote
Old 02-01-2011, 01:07 PM   #10
Soloshawn
With a Corsa Cat back and a CAI cold air induction and a dyno tune I gained 28 HP on my 2011 2SS/RS. The CAI gathered about 80% of the HP gain. Check out the Jannety tests on CAI and make your choice
Soloshawn is offline   Reply With Quote
Old 02-01-2011, 04:21 PM   #11
erk5000
erk5000's Avatar
So far I like the sound of Vararam and the HP gains it gets. Ill keep looking for more.
Old 02-01-2011, 05:12 PM   #12
2010SSRSM6
2010SSRSM6's Avatar
If your moving to CA none of the CAI's are C.A.R.B. approved and will not pass visual inspection. You have to have your car smog tested to get the registration changed to CA. Get what you want and put it on after your car registeration has been changed to CA.
Then go with LT's and a good CAI.
