Solo Performance
Old 02-01-2011, 03:15 PM   #1
copper3000
(aka) Troy & Maria
copper3000's Avatar
Drives: 2018 ZL1 Camaro
HID Bulb Replacement
I need help to make sure I don't ruin my HID bulbs when I replace them.
Is there anything I need to disconnect to make sure I don't damage the old bulb or the new ones when I change them. I want to put in 6000K bulbs so they will match my AAC DRLs better. I've heard there may be some residual voltage on the connection that could burn out the electronics. A friend of mine blew three bulbs changing his.
Can anyone help me so I don't make the same mistake?
copper3000 is offline   Reply With Quote
Old 02-01-2011, 03:31 PM   #2
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
a bulb swap is just that, unless you're changing ballasts? Pull the fuse if you're concerned about stored voltage???
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 02-01-2011, 03:40 PM   #3
copper3000
(aka) Troy & Maria
copper3000's Avatar
Okay. Do you think those other bulbs blew from some voltage on the lines?
It really freaked him out... One original bulb and two new ones.
DIY - 2010-2011 Camaro D1S HID bulb replacement instructions and photos GearHeadPeter Cosmetics and Lighting Modification Discussions 49 05-25-2016 07:00 PM
HID bulb replacement... 2010IBMSS Cosmetics and Lighting Modification Discussions 19 02-08-2011 08:00 AM
Cant get a replacement bulb socketed ??? jtzako 5th Gen Camaro SS LS LT General Discussions 6 01-22-2011 03:02 PM
daytime running lamps HID bulb replacement topgun1 Cosmetics and Lighting Modification Discussions 5 03-13-2010 11:59 PM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 02:07 AM
