Cold Air Inductions
Old 02-01-2011, 03:53 PM   #1
Alain
Alain's Avatar
Drives: 2010 SS, RS, Manual. 2012 F150, FX4
MBRP exhaust question
Does MBRP make any of their exhausts in 2.5 inch diameter at the connection with the CATS or are all their setups 3 inches?
I have Kooks high flow CATS on my car hooked up to long tubes and spent a good amount of money on them. the CATS are 3 inches at the connection with the headers and 2.5 inches at the other end.
Just wondering if i MBRP makes an exhaust to fit this set up or if there is a way i can work around the difference in diameters.
Alain is offline   Reply With Quote
Old 02-01-2011, 05:49 PM   #2
HtownSS
Drives: Silver 2SS, 68 Firebird 400,70 vett
They will work just fine, I have the same set up, Kooks headers with there high flow cats, the MBRP is 2.5 where it meets the cats then goes to 3in, you even use the OE wide band style clamp to mate the two together. The system goes together nicely, fits well.
HtownSS is offline   Reply With Quote
Old 02-01-2011, 10:56 PM   #3
Alain
Alain's Avatar
really!?!??!?!
that's awesome news !! good to know i wont have to throw away the kooks high flow cats when it comes time for me to upgrade to the MBRP system
thanks for the info
Old 02-01-2011, 11:05 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
That will go for any cat-back that will hook to the factory headers/mid-pipes. Unless you buy and exhaust from header to exhaust tip the cat-back will more than likely have a 2.5" inlet....even if it's a 3" exhaust.
Build Journal
Old 02-02-2011, 01:04 PM   #5
Alain
Alain's Avatar
makes sense now that you put it that way.
thanks !!!
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Question about potential exhaust setup. Xanthos Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 22 07-29-2011 11:59 AM
Please help me choose.... sfgiantsfan9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 11-22-2010 11:34 AM
MBRP exhaust in stock GmPartsDirect.com V8 Bolt-Ons & Tunes 4 11-21-2009 10:51 PM
2SS exhaust, 2 part question. HELP!! 2SS is mine!! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-16-2008 07:51 PM
