Emblempros
Old 02-01-2011, 02:58 PM   #1
St33lsinger
Emerald Coast Camaros
St33lsinger's Avatar
Drives: 2010 1 RS/SS
Ceramic Vrs Chrome..Heat Rise??
I know there would be a rise in heat in the engine compartment but would it be high enough to effect performace??
Had: 69' RS, 78' Z28, 98' SS Have: 2010 1RS/SS
St33lsinger is offline   Reply With Quote
Old 02-01-2011, 03:29 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Most intakes are sectioned off from the engine bay so it shouldn't be a problem. Even the OEM intake is built that way.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-01-2011, 10:18 PM   #3
St33lsinger
Sorry I thought I put it in there...Ceramic vrs Chrome Headers.
Old 02-01-2011, 10:26 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Chrome? Haven't heard of anyone putting chrome on their headers for the Camaro.
I would think ceramic coating would be better than chrome for headers.
Build Journal
Old 02-02-2011, 07:55 AM   #5
St33lsinger
Really chrome headers have been around forever.
I have no doubt ceramic is better I was just wondering if the heat rise is that much more.
Old 02-02-2011, 08:17 AM   #6
motorhead
Drives: POS MOPAR
Don't waste your time with chrome unless you don't plan on driving your car. Ceramic is cooler and will last much longer.
Old 02-02-2011, 09:43 AM   #7
caverman
caverman's Avatar
Yeah...I've seen chrome headers but not on a Camaro.
From my understanding, chrome is only for looks.....which for the most part so is ceramic IMO.
Wouldn't ceramic be much cheaper than chrome? And doesn't chrome tend to turn yellowish/blue with the extreme heat?
I would say that if you're looking for some kind of performance (by having reduced heat) you may not want to do either. Ceramic is supposed to cut don't on heat but I doubt it would be enough to do anything for you unless you are running a twin turbo or something where temps make a significant difference.
For looks I would go ceramic. It's nice and shiney but not over the top shine like chrome. I think of chrome headers being on motorcycles, high boys, and bucket-T. But that's just me.
Build Journal
Old 02-02-2011, 10:23 AM   #8
St33lsinger
Thanks guys.
Old 02-02-2011, 01:30 PM   #9
Cully
Drives: 2011 1SS/RS Synergy Green Camaro
I think the "chrome" he is referring to is the highly polished headers some are offering. Like the xspower, and OBX and such. I would go Ceramic for longevity.
Cully is offline   Reply With Quote
Old 02-02-2011, 01:40 PM   #10
Anthony@ARH
Drives: Black s2000, 749 ducati dark
With a quality 304 SS like ARH offers, you don't have to coat them unless your going for looks. The 304 will last a lifetime.
Anthony@ARH is offline   Reply With Quote
Old 02-02-2011, 01:47 PM   #11
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Ceramic is definitely worth the extra cost - they reduce engine bay temperatures dramatically - they can reduce external header surface temps by up to 50%. You can tell the difference just be holding your hand near them...
I know so many people that have burned up starter motors, wiring harnesses, and plug wires before switching to ceramic coated headers.
Note: you do want to get them coated inside and out
Old 02-02-2011, 01:51 PM   #12
Georger
Drives: 1979 camaro
The coating of a 304S/S header has nothing to do with the longevity of the product. It has to do with heat retention. Coating a header will retain more of the engines expelled heat in the primary. It will also keep radiant heat levels down in the engine compartment by roughly 15%.
Georger is offline   Reply With Quote
Old 02-02-2011, 09:19 PM   #13
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I think you mean stainless steel not chrome. Chrome is not a wise choice for high temp applications such as headers. Chrome will discolor very badly due to the heat after a short amount of time which can not be repaired (the discoloration for stainless can be repaired) and will eventually crack and flake off after being exposed to heat for prolonged periods of time.
Old 02-03-2011, 07:43 AM   #14
St33lsinger
Thank you, yes they are chrome coated, probably steel under the coating.
I think I'll be going with the 304 stainless steel and if I have the money the ceramic coated ones.
Thanks again
BBK Shorty Headers V8 LS3/L99 - Chrome, Ceramic Coated, or Stainless Steel Sean@Phastek V8 Bolt-Ons & Tunes 10 06-09-2010 12:30 PM
FS: 2005 Harley Davidson V-ROD MR. FBDY Autos For Sale / Wanted 0 02-23-2010 08:57 AM
Upgrade:SS with Painted GFX or Chrome? Mr CLuTcH Cosmetics and Lighting Modification Discussions 29 02-05-2010 02:51 PM
CGM w/ black or chrome license plate frame, what do you think? Matt'sSS Camaro Photos | Spyshots | Video | Media Gallery 14 08-04-2009 03:11 PM
Camaro Custom Billet Fuel Door - Heat Metal Heat Metal Cosmetics and Lighting Modification Discussions 7 06-24-2009 04:27 PM
