Old 02-01-2011, 09:17 PM   #1
4RD H8R
Beating 5.0's since 1988
4RD H8R's Avatar
Drives: 2010 RS SS M6
Help me make a decision!
OK here are the options I am considering.
Option #1 TSP 231/236 camshaft package and dyno tune
Pros- great sound and good power increase
Cons- no long tubes currently (planned for later but $$$)
Projected cost @ 1600.00
Option #2 Set of rear drag wheels and slicks
Pros- Increaed traction for quicker ET and more consistent
ET and reaction times.
Cons- More likely to break things (just bought spare set of stock axles),
probrably need a line-loc
Projected cost @ 1700.00 (incl line-loc)
Car is a 6 speed stick
Current mods- Solo cats, x pipe and flowmasters, CAI cold air intake
Future mods- both of the above + Headers, U/D pulley, 2 step, mabey a gear (4.11 or 4.33) but major $$$$,
Upgraded rear suspension.
Having to re-tune after putting headers on later will run @150.00 ish
So,input???
Beating the crap out of my Camaros for 23+ years 1973, 1970 1/2, 1979, 1968, 1971, 2010
4RD H8R is offline   Reply With Quote
Old 02-01-2011, 09:27 PM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i feel long tubes are the first step to getting gains from your car. you going to put them on sooner or later. why not put them on now?
Old 02-01-2011, 09:34 PM   #3
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Camshaft, without a doubt. Worry about the slicks once you're putting more power down. (Might I suggest a cam? )
Old 02-01-2011, 10:09 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
I say headers before cam.
Get you some headers and new tune, go buy you some trailing arms, and maybe add some rear-end busings/cradle inserts.
Then you can work on tires if needed. That's the route I would go.
Build Journal
Old 02-01-2011, 10:17 PM   #5
4RD H8R
4RD H8R's Avatar
While I agree that long tubes will be needed, I would guess that Long tubes and a tune would give me less of a performance increace that the cam replacement. I have the solo cats so I dont think I would pick up the 40 hp that many report from the headers. The main drawback is that it would cost me more money for the additional tune if I don't do the cam and headers together, no matter which order it's in.
However, your vote is now counted!
Headers 1
cam 0
slicks 0
Old 02-01-2011, 10:23 PM   #6
caverman
caverman's Avatar
Alot of times the price to install a cam has tune included with it.
Now...if you install the cam yourself, you'll probably need to pay to have it re-tuned. But then you just saved a ton on install labor.
Build Journal
Old 02-01-2011, 10:27 PM   #7
4RD H8R
4RD H8R's Avatar
I hear ya on the cam. I would imagine that the cam would be a .2-.3 (maybe .4) decrease ET in the 1/4.
As far as the slicks go. The car is a stick so traction is a major issue now. Unless riding the clutch just right you can't get a good 60' or 1/4 mile. (Somehow when the clutch sticks, a common problem, it seems to stick about 3/4 way up and the car has it's fastet passes this way! Once shifted to 2nd the clutch releases fully and all is good).
Headers 1
Cam 1
Slicks 0
Old 02-01-2011, 10:37 PM   #8
4RD H8R
4RD H8R's Avatar
Another vote for headers? Hmmm? I just don't thing the headers will net as much as the cam. I realize that I need both eventualy but I think I'll be down 10-20 hp cam only vs. 20-40 hp headrs only (assuming that with cam, headers, tune I could gain 30-60 hp overall)
The only advantage I see to tires only would be delaying the cam/headers till I could afford both together, which would save me a little $$ since no retune. I am really afraid of the axles if I go that route. I will be doing the cam, headers, etc. install myself. Mechanicly I'm good but tuning, not familiar enough.
Headers 2
Cam 1
Slicks 0
Old 02-01-2011, 10:49 PM   #9
Sawyer
Sawyer's Avatar
Drives: '13 5.0
Headers 1st. Increased sound and drop some weight..
Sawyer is offline   Reply With Quote
Old 02-01-2011, 11:12 PM   #10
caverman
caverman's Avatar
I would tell you to take the time to call Andy @ ADM or Jennetty and talk to them about it.
I think if you add to big a cam right now you'll be restricted by the less flowing OEM headers. So then you either go with a smaller cam or leave HP on the table with the bigger cam. Don't expect to see those 50-60 rwhp gains from a cam when you'll be using the OEM headers.
You're kind of in a tuff spot. I agree with you that adding just headers/tune won't net you the 40 rwhp gains others are seeing but I bet you'll see 20-25 rwhp. I would bet that adding a big cam without headers you'll probably be looking at the same rwhp as well. Maybe just a little more.
It almost seems to me that you should just sit tight and save until you have enough to do headers, cam, tune all at once.
Getting the right combination is key.
Build Journal
Old 02-01-2011, 11:41 PM   #11
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I agree with the rest on the headers thing. Open that thing up. But you are right. A cam could blow through and give more gains. Sucks you can't do both together. And remember this.... some shops will do a retune at no additional cost if you let them do the upgraded mods in the future.
So I guess my vote is cam if headers is not an option.
You can learn how to launch on stock wheels and the added power will be funer for every day action.
Old 02-01-2011, 11:50 PM   #12
4RD H8R
4RD H8R's Avatar
So I guess my vote is cam.
Yea, I'm kinda in no mans land. Unfortunatley since I would be doing the install myself, the initial tune prices I'm getting are about 600.00 and retune about 150.00. I did call a friend of mine that owns Atlanta Chassis Dyno (Brad Brand, runs a Twin turbo mustang Dixie Pro mod) to see what ideas he has, but he hasn't made it back from the races this weekend.
Headers 3
Cam 2
Slicks 0
Old 02-01-2011, 11:52 PM   #13
mikeSS
mikeSS's Avatar
Drives: 2015 c7
believe or not, thinking back i was in the same boat as you are. i had the same setup up as you with a tune. and i wanted to get a cam. but people were telling me i was leaving to much power on the table so i got headers instead. and then got my cam last week. happy i went down this route
Old 02-02-2011, 01:19 AM   #14
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
My vote is the rims and tires, I have been racing for years and whats the point of all that power and not putting it down! Your running good times for your mods, imagine what you could do with a good 60ft... I bet you see 12.20s once you figure out how to launch on the drag tires. Then put the headers or cam in it... and your running 11s just like that, and not worried about launching the car and you will see what it can really do. 18" drag rims will be alot of rotating mass of the car and that will help pick up in ET also.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Guillermo ~ G ~ Godfather ~ Mr. A ~ is turning 30!!! Hoddi California Meets and Events 113 02-06-2011 11:37 PM
Can we get enough people to make them make camaro SS? GQ4Life 5th Gen Camaro SS LS LT General Discussions 14 12-23-2010 07:46 AM
So, wanna work half the year and make lots of money... SSE 4 2SS Off-topic Discussions 20 12-16-2010 04:20 PM
Can't make a decision FFPM73 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 09-27-2009 01:35 PM
Can't Make up my mind... Sell me on Camaro! WhiteCrane Chevy Camaro vs... 13 09-21-2009 01:40 AM
