Cold Air Inductions
Old 02-02-2011, 02:27 AM   #1
crewxp
Drives: 2LT RS Summit White Camaro
Wiring Question: Can AAC Footwell Lights be wired to ambient controls AND a switch?
Quick question. Dotting all my i's and crossing my t's ;P
Trying to mentally figure out how I want this wired. Can the interior footwell lighting be hooked up to the ambient control system (brightness and dash lights toggle) AND also maybe put in a switch in between? (If the footwell ever gets annoying being on 24/7, so I can just shut it off?)
crewxp is offline   Reply With Quote
Old 02-02-2011, 07:41 AM   #2
jdouglas
jdouglas's Avatar
Drives: 2010 Camaro 1SS RS cgm
do you mean something like this?
http://www.camaro5.com/forums/showthread.php?p=1224402
jdouglas is offline   Reply With Quote
Old 02-02-2011, 07:56 AM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes it can. I believe it is the purple wire in the door panel. Then just wire a switch between that and the light.
Click to view my build thread
Old 02-02-2011, 12:03 PM   #4
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
I'm not sure you would want to dim footwells if they are CCFL...you could damage the inverter. IF its LED its a different story tho...LED's can dim. And yes a switch can be done...you may also need a diode in there as well.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 02-02-2011, 03:49 PM   #5
crewxp
yeah, its LED. Thanks for the input. This is how Im going to wire it. Now I just have to see if someone has a DIY on it already on taking apart the wiring and how to install the switch. Another member posted the ambient lighting switch schematic, so that will help.
hardest part now I think is actually getting the console apart to get to the wires
Old 02-02-2011, 08:51 PM   #6
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
some cars came with extra abl plugs .one is be hind the panel that covers the fuse panel on the drivers side .not sher all cars came with this plug thow.
chevy 3 is offline   Reply With Quote
