Old 02-02-2011, 02:42 AM   #1
khalsa013
Drives: 2ss & ZL1
Send a message via AIM to khalsa013 Send a message via Yahoo to khalsa013 Send a message via Skype™ to khalsa013
whats the difference?
maybe just the quality of the RS headlights?
i want to change my non rs lights to rs ones and i was wondering if i could just find a plug and play set and not have to do any electrical work....i want all the light options(hi,low,fogs). i found these on eBay same quality any electrical differences?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
khalsa013 is offline   Reply With Quote
Old 02-02-2011, 02:45 AM   #2
decepticon
decepticon's Avatar
Drives: 2010 camaro
I don't understand this
  • BOLT-ON STYLE , EASY TO INSTALL
  • HALO WIRE NEED TO SPLICE TO THE FACTORY PARKING LIGHTS
decepticon is offline   Reply With Quote
Old 02-02-2011, 02:58 AM   #3
khalsa013
Drives: 2ss & ZL1
yup exactly i don't want to order a pos and ruin my electrical work....
i want to have it a plug and play and the halos run daytime and all functions work as the normal rs cars would
Old 02-02-2011, 10:14 AM   #4
AUS10BMX
AUS10BMX's Avatar
Drives: 2010 2LT RY, 2014 Silverado
Is your friend.
This is a better option because you can use them, and run them how YOU want... The true RS Halos do no have the options these do, because they are already wired a certain way. When you wire your halos to the DRL, such as your turn signals up front, the halos will come on when the vehicle does and stay on. It is very simple just to tap this wire into the existing DRL wires of the car.
http://www.camaro5.com/forums/showthread.php?t=100103
Read this whole thread, very simple.
Hypertech | Airaid | JBA Exhaust | RX Catch Can/CNC TB/Black Ice-Olator | Ported Intake/Heads | 1LE Brembos | F14's | RS Headlights | ZL1 Grille
AUS10BMX is offline   Reply With Quote
Old 02-02-2011, 11:57 AM   #5
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
This is an aftermarket reproduction. As AUS10BMX stated, someone else has already done this change. But the difference between these headlights and true RS are that these ebay ones use cold-cathode fluorescent lighting (CCFL) which is very sensitive & shorter life span compared to GM's Light emitting diode (LED) version. Just my two cents.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
So..what exactly is the difference between Kooks and Knockoffs? (in pictures) MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 327 08-31-2011 02:16 PM
Did the deed and the difference is incredible c6vettepilot 5th Gen Camaro SS LS LT General Discussions 54 06-01-2010 12:12 PM
400 - 425 HP What's The Difference??? ParisTNDude 5th Gen Camaro SS LS LT General Discussions 20 04-16-2010 10:35 PM
CAI Sound Difference? kdbolt70 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 02-10-2010 09:25 PM
Sound difference with Cold Air Intake drtwo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 01-03-2010 05:39 PM
