JDP Motorsports
Old 02-02-2011, 01:43 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Engine animation..... pretty cool.
I was surfing around looking for my next mod and found some pretty cool animations on a engine and the rotating assembly, VVT, and such.
Shows how the whole intake, compression, spark, exhaust, cam, lifter, etc....... works and how VVT works too. The VVT is something I just didn't know much about. Pretty cool stuff I thought.
The first in not an LS series engine but it's a pushrod engine so same type and same process. The second is only a 4 cylinder and overhead cam, not pushrod but a good representation of intake, compression, spark, and exhaust with the valves. The VVT one is overhead cam but gives a little insight of what the cam is doing in a VVT situation.
Feel free to correct the vids if they are wrong or if you can give any insight.
Old 02-02-2011, 01:49 PM   #2
garcmol
garcmol's Avatar
Interesting. My wife's Vibe has VVT. Didn't know how it worked though.
Old 02-02-2011, 01:55 PM   #3
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
Nice finds! I'll have to watch them again on a bigger screen (than my iPod) when I get home!
LoneStar is offline   Reply With Quote
Old 02-02-2011, 01:57 PM   #4
ga0358
ga0358's Avatar
Drives: 2010 ABM LS
That IS cool! Thanks!
ga0358 is offline   Reply With Quote
Old 02-02-2011, 01:58 PM   #5
cool
Old 02-02-2011, 02:01 PM   #6
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Now once you get your head around that, try to get it wrapped around this (with its 3 moving parts!):
http://youtu.be/6BCgl2uumlI
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 02-02-2011, 02:22 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
EWE!!! IT LOOKS LIKE A STINKY WINDSOR ENGINE!!! EWE!!! lol
That's pretty cool, but it looks like they have the intake and exhaust timing backward on the V8... I must not be seeing it correctly...
Have you done a search on valve float? That's SICK!
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 02-02-2011, 03:37 PM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Now, speed it up so that it does that it cycles about 10 times a second, thats roughly how fast an engine will spin at idle. 6k rpm = 100 times per second.
Wankles make my head want to explode.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 02-02-2011, 03:42 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That was the best animation I've seen; I still got an aneurism trying to watch and understand it.
Old 02-02-2011, 03:44 PM   #10
hypurone
hypurone's Avatar
Wankel's make my head want to explode.
I would still be driving my twin turbo RX7 if the Camaro wasn't reborn this way and they made better torque.... :(
Old 02-02-2011, 03:45 PM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
So are the rotors considered cylinders, per se?
Old 02-02-2011, 04:00 PM   #12
hypurone
hypurone's Avatar
Well, the rotor themselves would be "considered" the "pistons as it were". The housings are the combustion "chambers". And to really twist your brain, the path that the rotors travel is "epitrochoidal".
Old 02-02-2011, 04:06 PM   #13
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
Its funny how people nowadays think VVT is so new and cool. In all reality honda has been doing variable timing since the early 90s. So when I see a company talk about VVT im not impressed.
Sent from my DROIDX using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 02-02-2011, 04:17 PM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Each rotor is akin to 3 cylinders (well, pistons if you want to be picky). But since it completes the equivalent to a 4 stroke cycle (suck, squeeze, bang, blow) it will fire 3 times each cycle, which is the same as what a 6 cylinder engine does.
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 01:09 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 01:28 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
