JDP Motorsports
Old 02-02-2011, 07:40 PM   #1
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
How to get my Amber Halo's as DRLs?
I got the amber halo's from aac and I finally got to installing them a few weeks back.
I have the 2LT NON-RS
One thing I've learned is that you really have to look for the halos if you are looking head on, which makes sense considering you would be looking into the headlight. And Amber is not really a bright color.
But if you are looking at the headlight from an angle, it actually looks really good.
What I am wondering is if I could get power from the parking lights so that I could just turn off my headlights and have the halos on... Basically I would want it to look like this.
Does anyone know what wire i would have to tap into or what steps I would have to do to make this possible?
Thanks,
Roshan
Old 02-02-2011, 07:42 PM   #2
c-dub
It's that guy
c-dub's Avatar
Drives: 2011 SIM SS/RS
Not that it's my business, but...isn't it illegal to have red/amber lights on while you drive around?
We mortals are but shadows and dust.
c-dub is offline   Reply With Quote
Old 02-02-2011, 09:26 PM   #3
H3LL1ON
H3LL1ON
H3LL1ON's Avatar
Drives: 2010 1LT Camaro Synergy Green
I think in most cases the amber is ok as it is marker/signal color. Red is a ticket waiting to happen if you are driving with them on. Best to use red on private property and be parked ie: car shows.
It's Green, really Green! C5
H3LL1ON is offline   Reply With Quote
Old 02-02-2011, 09:36 PM   #4
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Amber is illegal, reserved for construction, and road signs, etc. YELLOW, like turn signals isn't illegal. But more to your point OP... just tap into the Parking lights if you want them on with the parking lights lol... simple as that.
Or, wire them up with a switch, so you have more control over it.
jagan323 is offline   Reply With Quote
Old 02-03-2011, 01:44 AM   #5
SummoneR
Paul
SummoneR's Avatar
Amber is the color of turn signals. It is an amber lens or bulb. The temp tape you place over the top is typically called amber as well. It's yellow yes but the technical term and actual color is amber. It's like Cyan is blue... but technically and properly it is called cyan.
In CA it is legal to have front turn signals either Amber/Yellow/Orange or White. Rear is red or amber not sure about white.
"Amber is one of several technically-defined colors used in automotive signal lamps. In North America, SAE International standard J578 governs the colorimetry of vehicle lights,[2] while outside North America the internationalized European ECE regulations hold force.[3] Both standards designate a range of orange and yellow hues in the CIE colorspace as "amber". In the past, the ECE amber definition was more restrictive than the SAE definition, but the current ECE definition is identical to the more permissive SAE standard. The SAE formally uses the term "yellow amber", though the color is most often referred to as "yellow". This is not the same as selective yellow, a color used in some fog lamps and headlamps."
So really Amber is used pretty loosely I guess LOL. Meaning turn signals and emergency construction flashers etc, can all be classified as amber or yellow, if they fall within the SAE range.
Old 02-03-2011, 08:50 AM   #6
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
I wired mine to my marker lights for that exact reason.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 02-03-2011, 10:39 AM   #7
ihaveacamaro
I like teeth.
Drives: #198
Under Federal Law, it is required for a car to have amber marker lights on the front of the car. REQUIRED. Thus, all I have to say is that my rings are amber marking lights and it's legal
I've done research many months back on the web, and also have talked to several police officers in my area. They all agree. And I even asked that since my halos look more orange than amber if that would be fine and they said yes.
Roshan
Old 02-03-2011, 10:41 AM   #8
ihaveacamaro
I like teeth.
Drives: #198
Do you remember the color of the wire for the marker lights that I have to hook the power up to?
I don't have a voltmeter on me :(
Thanks
Old 02-03-2011, 10:41 AM   #9
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Not only is Amber Legal, it is REQUIRED by FMVSS.
AACstyle is offline   Reply With Quote
Old 02-03-2011, 10:42 AM   #10
AACstyle
AACstyle's Avatar
Roshan
Ah, you beat me to it! lol
Old 02-03-2011, 10:44 AM   #11
AACstyle
AACstyle's Avatar
Amber *strobe lights* are reserved for construction and tow vehicles.
Old 02-03-2011, 10:45 AM   #12
CamaroCowboy
Thanks
If I recall there are only two wires going to the marker lights. A black one (ground) and the Gray one (power)
Old 02-03-2011, 10:49 AM   #13
Penaw001
Penaw001's Avatar
Drives: 2010 Cyber Grey 2SS
Thanks
That one is purple on the driver side and brown on the passenger side. I got that off of a diagram that some one put on here.
Does the marker light give you constant power or do you have to have the park lights on?
Penaw001 is offline   Reply With Quote
Old 02-03-2011, 10:55 AM   #14
AACstyle
AACstyle's Avatar
There are 2 markers, lets get everyone on the same page. There is the headlight marker (turn signal doubles as marker on the non-RS) and there is a side marker (sidemarker). The sidemarker has 2 wires that you can tap into,
2) Locate the Green Plug going into the Sidemarker. Lock a T-Tap around the + line (Pass side= Brown, Driver side= Purple) you can use pliers to snap into place.
3) Now plug the Connector into the T-Tap:
Pic Request: Interior or Ambient Lighting (white or blue) / Amber vs Blue Halos crewxp Camaro Photos | Spyshots | Video | Media Gallery 13 01-31-2011 03:35 PM
Halos as DRLs on NON-RS Cars MagnumForceGB Cosmetics and Lighting Modification Discussions 3 08-23-2010 04:46 PM
how-to: Halo's as DRL's? Captain McFunk Camaro DIY & HOW-TO instructions & discussions 3 05-14-2010 04:15 PM
AMBER Halos Installed for member Double O Nick! AACstyle Cosmetics and Lighting Modification Discussions 93 05-09-2010 01:28 PM
AMBER HALOS IN NON RS INSTALLED FOR SALE !!!! orange10s.c. Exterior Parts & Accessories 21 02-24-2010 09:41 PM
