SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 02-03-2011, 09:08 AM   #1
GRASSHOPPER
Drives: 1987 z28
3rd gen wheels
ok so all the reading i have been able to do it seems to me that the wheels and tire fitted on the irocs are 245/50/16 and they are mounted on 16x8 rims. so, are all 3rg gens able to accept these wheels and tires or do the irocs have a little wider wheel well? and is that as wide as we can we fit in there without mods? also, is that size for the front and the back or is the front a little narrower?
GRASSHOPPER is offline   Reply With Quote
Old 02-03-2011, 09:24 AM   #2
MaRoFreK
MaRoFreK's Avatar
Drives: IOM 1SS w/factory Hurst
If I'm not mistakin on an Iroc the wheels are a staggered set up the rear has a differant offset then the front. So the rear have to stay on the rear and front have to stay on the front. I think it actually says Front on the front wheels and rear on the rear wheels. And yes you can put the Iroc wheels on any 3rd gen. I had 89 Iroc wheels on my 86.
"Success is following the pattern of life one enjoys most."
Stainless works Catback with Flowmaster Single Chamber Mufflers, Vararam, Factory Hurst, SLP SS emblems, SLP Skip Shift
MaRoFreK is offline   Reply With Quote
Old 02-03-2011, 09:25 AM   #3
IROCanSS
Drives: 89 IROC 350
I have an 89 IROC. First, not all IROC wheels are the same. There are 15" and 16" style. The ones with double lines in the spokes are 16". That's what I have. Also the front and rear wheels are different. Not exactlly sure how but the back wheel is visually a deeper dish. I'm sure it has to do with offset.
Those 16" wheels should fit right up to any camaro. I don't think the rear is any wider, just a different offset.
Hope that helps!
Old 02-03-2011, 09:26 AM   #4
IROCanSS
Drives: 89 IROC 350
They say FRONT and REAR.
Old 02-03-2011, 09:42 AM   #5
IROCanSS
Drives: 89 IROC 350
Here are the different wheels IROCs got. Single and double stripe. I believe, but not sure the single stripe had a 15" and 16" option. The doubles were all 16". The non ttop and stripe delete car is mine.
Old 02-03-2011, 12:19 PM   #6
GRASSHOPPER
Drives: 1987 z28
ok, so is 245/50 the widest they can handle without rubbing?
Old 02-03-2011, 12:25 PM   #7
IROCanSS
Drives: 89 IROC 350
I honestly have no idea what you could squeeze on.
Old 02-03-2011, 01:16 PM   #8
MaRoFreK
MaRoFreK's Avatar
I plan on putting 275s all the way around Mine I have the same wheels for my 87 also.
Old 02-03-2011, 02:30 PM   #9
IROCanSS
Drives: 89 IROC 350
I see youre missing a center cap. I don't know about those style but on the style I have I needed 2 and I could only find a set of 4 and those little buggers were expensive!!!
Old 02-03-2011, 03:44 PM   #10
MaRoFreK
MaRoFreK's Avatar
Well My buddy picked the wheels up for me today actually lol. But anyways he has all 4 but I guess one was popped out. Hopefully its not broken. Cause you're right those things are pricey!!
And also the biggest tire I could find was a 255.
What song are you listening to right now Muscle Master Off-topic Discussions 6390 01-05-2018 10:22 PM
3rd Gen Camaro Street Stock build thread (dialup beware) zlathim 3rd Generation Camaros 7 02-20-2013 12:04 AM
4th gen wheels with small brakes !!!( drag setup ) Bad70supreme Wheels and Tires Talk Sponsored by The Tire Rack 7 12-30-2010 09:16 AM
Smoked Taillights on a 3rd gen Firebird Rman91Bird 3rd Generation Camaros 2 10-30-2008 09:21 PM
