Gen5DIY
Old 02-03-2011, 10:20 AM   #1
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: SW 11' 2SS/RS LS3 Vert, Blk/Blk
changed bracing for 3" exhaust upgrade???
Has anyone who's upgraded their SS had to change or modify the undercarriage bracing to fit the 3" pipes? And for those who used the stock bracing, do you have any rattle from the exhaust touching? Thanks!
Drago77 is offline   Reply With Quote
Old 02-03-2011, 10:26 AM   #2
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
I had the stock tunnel brace and my pipes would rattle on it. I changed it out to a billet aluminum one and no more rattle.
bpoirier is offline   Reply With Quote
Old 02-03-2011, 10:35 AM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
I have the Magnaflow 3" with the stock brace. It clears the factory brace easily.
Which cat-back are you using?
BTW...there are a handfull of Mfgs that make braces for a 3". Barton is one that comes to mind off the top of my head. About $100 I think.
Otherwise, I've read others just put a few washers under the factory brace to make it clear.
Build Journal
Old 02-03-2011, 10:45 AM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
this.
a few washers and longer bolts. ~$5.00 at the hardware store vs $100+
I piss excellence
and fart awesomeness
Old 02-03-2011, 12:09 PM   #5
Drago77
Drago77's Avatar
Yeah, that's kinda what I was thinkin (the washers). Im lookin at the Flowmaster American Thunder, was just curious about the clearance issue.
Old 02-03-2011, 12:26 PM   #6
caverman
caverman's Avatar
Buy the washers and give it a try. Should be all you need. Worst case you still have to go buy an aftermarket brace but you won't be out alot on the washers.
Build Journal
Old 02-03-2011, 01:38 PM   #7
Mark Myles
Mark Myles's Avatar
Drives: 2010 2SS/RS IBM / Silver Stripes
I have the Flowmaster and stock brace. I was able to do my exhaust on a lift, so it made things easier. 1) You need to make sure the pipes are facing the correct way per the directions. 2) Once everything is connected, push up on the pipe while tightening them down. This helps prevent them from saging and hitting the brace. An extra pair of hands really helps, along with a lift and air tools....
I used the stock brace with NO washers and mine clears fine. It will only hit if I hit a big bump in the road, which shakes the entire car! But to be safe, washers are your friend.
M
Mark Myles is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3463 04-12-2018 02:44 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 08:43 PM
NEED SOME LEGAL ADVICE. WAS PULLED OVER TODAY AND GOT REEMED!..:( moiy1983 USA - Texas 26 12-07-2010 09:32 PM
Need Help with upgrade exhaust and Electric cutoffs Camaro007 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 04-19-2009 09:44 AM
GMPP track pack exhaust upgrade? HP junky Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 37 04-01-2009 10:51 PM
