Emblempros
Old 02-03-2011, 06:43 PM   #1
Wildman!
Wildman!'s Avatar
Drives: 2010 2SS/RS White/Orange Stripe
GM PP Exhaust Upgrade w/Ground Effects
My 2010 SS has the GM PP exhaust upgrade. It also has the ground effects package. I am concerned about the end of the exhaust not coming out to the edge or extending beyond the square ports of the rear diffusor. It looks as though there should be a tip on there, but the dealership says there aren't any tips for this PP exhaust upgrade. I'm worried about burning, melting or discoloring the ports and/or diffusor. Can someone who also has these two options installed tell me if there should be any tips or not? Should I have tips installed from someone other than GM?
Wildman! is offline   Reply With Quote
Old 02-03-2011, 07:41 PM   #2
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
Welcome to the forums! I have the GFX, but stock exhaust so I can't answer your question, but I'll give you a bump so someone that does might be able to answer your question.
first one is offline   Reply With Quote
Old 02-03-2011, 07:48 PM   #3
wrbear
Banned
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10
I installed the MBRP tips for my GFX...they look purdy!
Name:  2010-12-07 00.05.02.jpg
Name:  2010-12-07 00.06.52.jpg
They used a 1 1/2" to 3" coupling to make the connection.
wrbear is offline   Reply With Quote
Old 02-03-2011, 10:20 PM   #4
Wildman!
Wildman!'s Avatar
I like those.....I was thinking of the retangular shape to match the ports. My pipe is 2 1/2" so I would need a 2 1/2" x 3" coupling. How much too short were your pipes? I'm about 3" to 4" from the outer edge.
Any other suggestions out there?
Old 02-03-2011, 10:38 PM   #5
wrbear
Banned
Take it to a muffler shop to have it done. I would suggest you have them bolt everything together not welded. That will give you room to adjust the tips to your liking. Let them do the math on the actual cuts etc.
Old 02-04-2011, 03:15 AM   #6
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
yah what wrbear said was right, that those tips would look good with the GFX. but with your question@wildman!, that the exhaust burning the diffuser, not likely. if you touch the inside of the chrome tips, their made of metal . i have the SLP Loudmouth II's installed with the square tips, but they dont stick out toward the edge of the chrome tips as they would with those MBRP tips. one thing though they get dirty often.
jonathanmoguel is offline   Reply With Quote
Old 02-04-2011, 05:58 PM   #7
MIKENSC2SS
MIKENSC2SS's Avatar
Drives: BLACK 2014 Camaro ZL1
I have the GMPP exhaust upgrade and the GFX and I do not have tips on. The exhaust extends right to the mid section of the metal exhaust bezel which I painted to match the GFX.
MIKENSC2SS is offline   Reply With Quote
Old 04-01-2011, 09:27 PM   #8
palmdog
palmdog's Avatar
Drives: 2010 camaro SS
Put some MBRP square tips on three weeks ago and the chrome job on the tips I got, well SUCK! Rusting bad.. I have a suggestion for MBRP... POWDER COAT!!!! I have a flowmaster 3 inch exhaust and have loosened up entire system to get these tips to center in the factory ground effects. I love to work on hotrods, My three year restoration of my 73 charger proves such. I love a challenge and love to modify! Well I haven't given up on these tips but, I have tried everything.. modified factory rubber hangers, and even as a last attempt used hose clamps to manipulate the mufflers.. ugh! Its time I guess to put some black mesh to hide these rusty off centered eye sores... I will jack up my car one last time and try to correct them, then its time to hide them... powder coating these pieces of crap is on the menu... Or maybe I am just being anal.... NAaaaa.. They suk...
palmdog is offline   Reply With Quote
MAGNAFLOW Cat-Back / Axle-Back Exhaust Systems | FREE Shipping Apex Paul V8 Bolt-Ons & Tunes 134 01-24-2011 01:56 AM
Please help me choose.... sfgiantsfan9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 11-22-2010 11:34 AM
Questions on Exhaust Upgrade ppolgar Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 05-27-2010 05:30 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
v6 exhaust upgrade kellyjrt Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 7 11-02-2009 10:27 PM
